Ilikethedesert05 Samba Member
Posted: Mon Aug 15, 2022 5:22 pm Post subject: Are those leads on correctly? |
Just want to see if these leads were placed in the right order. Thanks
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76941 Location: Sneaking up behind you
Posted: Mon Aug 15, 2022 5:31 pm Post subject: Re: Are those leads on correctly? |
Looks so
1-4-3-2 clockwise _________________ Glenn
Member #1009
#BlueSquare |
rosevillain Samba Member
Joined: December 28, 2005 Posts: 1290 Location: roseville, ca
Posted: Mon Aug 15, 2022 8:10 pm Post subject: Re: Are those leads on correctly? |
If 1 is 1. |
KTPhil Samba Member
Posted: Mon Aug 15, 2022 9:17 pm Post subject: Re: Are those leads on correctly? |
rosevillain wrote: |
If 1 is 1. |
Yes, they are sequenced right, but maybe clocked wrong. Set the engine to TDC on #1, then pull the cap and see if the rotor is pointing to the #1 wire. |
veedweeb Samba Member
Joined: May 23, 2018 Posts: 150 Location: Greater Manchester UK
Posted: Wed Aug 17, 2022 1:09 am Post subject: Re: Are those leads on correctly? |
The leads look to be in the right order, but I noticed the rubber sleeve that goes from the dispstick tube to the body is missing so that might cause a mess when you're driving. _________________ 1963 Turbo WBX Bug
2000 Sedan Clasico Mexican Bug
1972 Type 3 Squareback |
Posted: Wed Aug 17, 2022 9:26 am Post subject: Re: Are those leads on correctly? |
veedweeb wrote: |
The leads look to be in the right order, but I noticed the rubber sleeve that goes from the dispstick tube to the body is missing so that might cause a mess when you're driving. |
Yeah I know, I need to order one before I get it on the road. Much work to do. |
