yel-mel Samba Member
Joined: May 07, 2015 Posts: 421 Location: Tampa Florida
Posted: Mon Aug 15, 2022 4:31 pm Post subject: Need a glue / adhesive recommendation ( please ) |
My engine compartment air cleaner elbow hose has cracked and pulled apart. This is the fitting that goes right onto the top of the carb and goes to the oil-bath. I know they sell replacement ones, but I want to try and save the orig..Mine is in 2 pieces now.
Does anyone recommend a strong glue I could use to repair. I'm thinking just reg super glue Or JB Weld 🤔. What do you guys think ?? |
74 Thing Samba Member
mondshine Samba Member
Joined: October 27, 2006 Posts: 2769 Location: The World's Motor Capital
Posted: Mon Aug 15, 2022 7:51 pm Post subject: Re: Need a glue / adhesive recommendation ( please ) |
74 Thing wrote: |
I would just buy a new or used intake tube. |
X2. Engine movement/vibration vs. the fixed location of the air cleaner will quickly separate any glue joint. Besides, it will be very difficult to make a neat job of the repair.
It's a 211 part number, so also check the Bus universe for a used one.
Good luck, Mondshine |
germansupplyscott Samba Member
Posted: Thu Aug 18, 2022 7:28 am Post subject: Re: Need a glue / adhesive recommendation ( please ) |
I agree that the intake snorkel is an easy part to find either good used, new reproduction or even NOS. On my car I used orange high temperature silicone and it held up well. I've since replaced this with an NOS part but this was fine. You have to clean the rubber well before using the silicone or it won't adhere.
_________________ SL |
Posted: Thu Aug 18, 2022 12:30 pm Post subject: Re: Need a glue / adhesive recommendation ( please ) |
Thanks for the info guys. The silicone might be a good short-term fix, until I order a new one. I like that it may be a little flexible, as my guy likes a shot of starting spray every so often....so I end up lifting it off at least once per month. |
Posted: Wed Aug 24, 2022 11:43 pm Post subject: Re: Need a glue / adhesive recommendation ( please ) |
Shoe Goo will work as will a polyurethane roofing caulk. As mentioned you will want a quality replacement in the long run. |
