A/C Advice--I messed up
Forum Index -> Eurovan Share: Facebook Twitter
menko
menko is offline
PostPosted: Sun Aug 14, 2022 5:51 pm    Post subject: A/C Advice--I messed up Reply with quote
Hi everyone,
I just put a transmission cooler on, and while reading the directions to remove the bracket holding the power steering cooler on I accidentally unscrewed a torx bolt that released AC refrigerant instead. I quickly closed it, but it shot a bunch of yellow goop all over and not surprisingly my AC no longer cools.
What I wasn't sure of is whether this opened my system to air and I need to replace anything, or if I can take it and have them recharge the refrigerant level to get it 700 +/-50g of charge again. The AC worked perfectly fine prior to this, so hopefully no underlying issues. I just wanted to be sure if I took it a local AC person I knew what I was getting into.
Thanks in advance!
TheOneTrueQuux
TheOneTrueQuux is offline
PostPosted: Sun Aug 14, 2022 6:03 pm    Post subject: Re: A/C Advice--I messed up Reply with quote
menko wrote:
Hi everyone,
Thanks in advance!
It kind of sounds like you ran a screw through the condenser. There shouldn't be any screws that, when removed, release refrigerant. Is it possible that when you re-installed it you punctured the condenser?
Abscate
Abscate is offline
PostPosted: Mon Aug 15, 2022 6:05 am    Post subject: Re: A/C Advice--I messed up Reply with quote
Have to system evacuated , pumped down for a few hours, then test to see if it hold vacuum. Then recharge by weight.
No need to replace drier if it has been exposed for less than 24 hours, you ve been open much less than that
Internet sheep might bleat differently.
.ssS!
TheOneTrueQuux
PostPosted: Mon Aug 15, 2022 6:36 am    Post subject: Re: A/C Advice--I messed up Reply with quote
Baaa!
Seriously though, it might be helpful if the OP posted a picture here of the area of the leak, and annotate that picture to show which screw was removed. That way we'll all have a better idea of what happened.
menko
menko is offline
PostPosted: Mon Aug 15, 2022 3:49 pm    Post subject: Re: A/C Advice--I messed up Reply with quote
Here's a close up of the screw I accidentally opened. Photo borrowed from whatavan.com as I had already put my grille back together.
I also should clarify, I loosened it only until the r134 shot out, and quickly tightened it back down--it never fully came out, but enough leaked out to make a mess.
Abscate
Abscate is offline
PostPosted: Mon Aug 15, 2022 6:18 pm    Post subject: Re: A/C Advice--I messed up Reply with quote
…which means you never let any air or moisture into your system as it never fell below atmospheric pressure. Find a good Ac shop and charge back by performance , no need to evacuate.
.ssS!
menko
menko is offline
PostPosted: Mon Aug 15, 2022 6:30 pm    Post subject: Re: A/C Advice--I messed up Reply with quote
Sounds like I finally made a minor mistake instead of a major one Wink Thank you for the help!
MJ
MrPulldown
MrPulldown is offline
PostPosted: Mon Aug 15, 2022 8:00 pm    Post subject: Re: A/C Advice--I messed up Reply with quote
Can't he just shot some more refrigerant in.
2002 EVC
Stripped66
Stripped66 is offline
PostPosted: Tue Aug 16, 2022 5:09 am    Post subject: Re: A/C Advice--I messed up Reply with quote
He can, but unless he has a set of A/C gauges/manifold, it will be a guestimate whether he adds the correct amount.
66brm wrote:
Bodacious wrote:
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor.
I don't think electrickery works that way
subdewd
subdewd is offline
PostPosted: Tue Aug 16, 2022 6:34 am    Post subject: Re: A/C Advice--I messed up Reply with quote
Option a: shoot some in
b: use gauges
c: evacuate and add by weight
I choose c
Abscate
Abscate is offline
PostPosted: Tue Aug 16, 2022 10:42 am    Post subject: Re: A/C Advice--I messed up Reply with quote
b: use gauges
I choose c
Except C requires going to an AC shop anyway to recover charge.
If you blow charge into our breathing air you are a prick of epic proportions. This includes the people who just need to 'add a can each summer to get AC"
If you take it to the right shop, they can add charge to performance.
.ssS!
subdewd
subdewd is offline
PostPosted: Tue Aug 16, 2022 11:14 am    Post subject: Re: A/C Advice--I messed up Reply with quote
So b and c require going to a shop. Labor prevalent an hour either way so why not go by weight which is the proper. Plus while it's drawn down check for leaks. Just a thought
Abscate
Abscate is offline
PostPosted: Tue Aug 16, 2022 2:06 pm    Post subject: Re: A/C Advice--I messed up Reply with quote
MJ
On the scale of Foxtrot Uniforms, it was a minor Charles foxwalk, yes.
Laughing Laughing Laughing
.ssS!
menko
menko is offline
PostPosted: Wed Aug 17, 2022 11:45 am    Post subject: Re: A/C Advice--I messed up Reply with quote
Thanks everyone, took it to the shop today and they are evacuating and recharging it. Next up, transmission cooler =)
Reply to topic    Forum Index -> Eurovan All times are Mountain Standard Time/Pacific Daylight Savings Time
