Crankey Samba Member
Posted: Sat Aug 13, 2022 3:40 pm Post subject: Re: Wheel Spacers Needed? 1987 Weekender-2WD |
Thanks for the story Westy46. Your lucky to have a cool shop like that in your area. 👍 |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17115 Location: Retired South Florida
Posted: Sat Aug 13, 2022 4:50 pm Post subject: Re: Wheel Spacers Needed? 1987 Weekender-2WD |
To the original poster. It looks to me that you have tire sidewall clearance. If you’d like a little more, the arms are stamped sheetmetal and someone good with a hammer could get you a little more clearance if you find the sidewall rubbing the arm. I’ve never been a fan of spacers. Some are better than others and as recommended Christopher at T3 is who I’d reach out to. I have GW 16s on our 82 2wd. Been there since the beginning. Not had any rubbing problems up front and the sliding door just clears the R/R tire. For something that bolts up , doesn’t require crawling through junkyards, and machining, for the price I feel the GW alloys are a good overall value. No affiliation. _________________ ☮️ |
Westy46 Samba Member
Joined: June 27, 2015 Posts: 92 Location: South Dakota
Posted: Sat Aug 13, 2022 5:01 pm Post subject: Re: Wheel Spacers Needed? 1987 Weekender-2WD |
Thanks, I have emailed T3. I will discuss with Subaru next week also. Slider door opening is a new concern. |
1988M5 Samba Member
Joined: January 23, 2016 Posts: 674 Location: Santa Cruz, CA
Posted: Sat Aug 13, 2022 6:01 pm Post subject: Re: Wheel Spacers Needed? 1987 Weekender-2WD |
Old knowledge shared now. "Offset" is the exact opposite of "ET", beware the numbers may not not jive for a fundamental reason(s). Don't try to "google" your way out of this mess. Consult Chris @ T3.
BK _________________ 1991 tin top GL
Some BMWs. |
Franklinstower Samba Member
Posted: Sat Aug 13, 2022 6:57 pm Post subject: Re: Wheel Spacers Needed? 1987 Weekender-2WD |
Take the freaking wheel off and find out your et! Don't listen to the subaru dealer. There only goal is profit.
You need to know the offset of the rim and width.
Then decide if spacers are even to be considered. You need to find the information of what you have before you go relying on random internet replies.
I doubt your rims are et 23 that close to the upper ball joint, but what do I know? Maybe they are, but 8" wide? You have the info...find it and use it, then reach out to whom ever. It's not rocket science, there is a thread with 100+ pages about wheels. Maybe start there. _________________ '89 Westy - EJ25/22 Frank 4.44 5mt
'75 Miami Blue Sunroof FI Standard Bug
Last edited by Franklinstower on Sun Aug 14, 2022 9:21 am; edited 1 time in total |
jimf909 Samba Member
Posted: Sat Aug 13, 2022 7:57 pm Post subject: Re: Wheel Spacers Needed? 1987 Weekender-2WD |
If he's got these wheels it's a 7.5" wide rim with ET23. A 215 wide tire can appear pretty close like in the photo.
OP: I ran 215/16 65 Nokians WRC3s on these rims for years w/out spacers but it looked close like you're seeing. GW provided spacers with the early big brake kit after they had a warranty problem but I don't believe I used them (not helpful, I know).
https://gowesty.com/products/16-alloy-wheel-hardwa...5002594469
Also, cool story about your shop. It sounds like a dealer that actually likes cars. _________________ - Jim
Abscate wrote: |
Posted: Mon Aug 15, 2022 6:40 pm Post subject: Re: Wheel Spacers Needed? 1987 Weekender-2WD |
Conclusion to the spacer question:
I received feedback from Chris at T3 Tech. and I will NOT be adding spacers to the wheels. I have pasted the comments from Chris at T3 Tech below for all to read and learn.
Chris's T3 Tech comment below:
There’s no problem with that amount of clearance. In fact, that’s quite a bit of clearance compared to many of the installations I’m used to dealing with. The rule of thumb is that if you have 3mm or more clearance, you are good to go. I know that sounds like very little, and it is, but it’s plenty.
Definitely DO NOT add spacers. That would be the incorrect thing to do. Those ASA wheels are already pushed outward too far as it is. Adding spacers will push them outward even further. The correct offset should be closer to ET30 (30mm). The wheels you have are ET23 (23mm). when the offset gets reduced too much poor handing/stability can happen because it negatively alters the scrub radius. You won’t notice it much when driving in a straight line, but it will rear its head during hard braking/emergency maneuvers
I learned once again and thanks for the comments.
Sodo Samba Member
Joined: July 06, 2007 Posts: 9603 Location: Western WA
Posted: Mon Aug 15, 2022 11:36 pm Post subject: Re: Wheel Spacers Needed? 1987 Weekender-2WD |
My preference is enough wheel clearance that using snow chains is an option.
Sometimes they are required.
I wonder what is the recommended clearance for snow chains?
Edit re:Jim909. (Ooops).
I use 4 chains at times on my F150 and brain-farted about this 2wd situation. I’ve never used chains on my Vanagons. _________________
....KTMs, GasGas, SPOT mtb
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3431 Location: Dartmouth, Mass.
Posted: Tue Aug 16, 2022 8:24 pm Post subject: Re: Wheel Spacers Needed? 1987 Weekender-2WD |
Sodo wrote: |
I wonder what is the recommended clearance for snow chains? |
I run snow chains often but w/ a 2WD w/TBD I put them on the rear wheels (okay for snow and my conditions aren't icy enough to require chains up front).
My guess is that these chains would not work up front.
Chains + 2WD + Peloquin has meant no haul outs yet (but I'm pretty cautious).
Abscate wrote: |
r39o Samba Polizei
Posted: Tue Aug 16, 2022 8:58 pm Post subject: Re: Wheel Spacers Needed? 1987 Weekender-2WD |
campism wrote: |
It's hard to see the detail in your photo. Here is a pic of the trial fit of a Mercedes CLK wheel on my 2WD '87. No contact yet in thousands of miles.
Now you make me want to look also!
I decided on no spacers with my CLKs.
No spacers front or back.
ET32 as I recall. 5mm not worth it. Plus no rear stud replacement needed in back.
I just slapped them on. No rub. Correct balls on nuts.
Me too, many thousands of happy miles and on my second set of 215/65-16 also.... _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
nemobuscaptain Samba Member
Posted: Wed Aug 17, 2022 3:55 pm Post subject: Re: Wheel Spacers Needed? 1987 Weekender-2WD |
Sodo wrote: |
It takes a special kind of mechanic to work on them and if the shop has only 'normal' mechanics they can't take in this kind of work. |
It means your local VW service is shit, not surprising me given how pathetic VWOA in general is. They can't overcome their penis envy of Mercedes and BMW and think just ACTING like an expensive German carmaker will one day make them one.
HERE (midwest) the dealerships work on anything if you will pay the freight. The average dealership these days make far more money off service than car sales. I frequently take a Dodge work vehicle to a Ford dealership for service because it is out of my way by a few interstate exits to take it to a Jeep or Dodge dealer. So far that has just been brakes, fluids, and suspension, not anything serious. Their oil change rates are even as cheap as the local quicky lube like places and I don't have to wonder what they really have in those 55 gallon drums that they pump into my engine. I doubt that they'd do any very nuanced work like rebuilding a transmission though, but I doubt any dealerships rebuild transmissions anymore anyway.
r39o wrote: |
I just slapped them on. No rub. Correct balls on nuts. |
trying to resist......
THAT'S WHAT SHE SAID!!!!!! _________________ Ohio Valley Tribe, Full Moon Bus Club https://www.facebook.com/groups/294422277314227/
https://www.facebook.com/groups/FullMoonBusClub
RIP Bob Hoover https://www.thesamba.com/vw/forum/viewtopic.php?t=427791
Hoover Sermons: https://www.vwsage.com/images/vwsage/Bob%20Hoovers%20Sermons.pdf |
