AJC1967Boone Samba Member
Joined: August 16, 2022 Posts: 5 Location: North Carolina
Posted: Tue Aug 16, 2022 7:56 pm Post subject: 1969 Karmann-Ghia Gets Stuck in 4th Gear. Why? |
1969 Karmann-Ghia gets Stuck in 4th Gear. Why?
I cannot disengage out of 4th gear, I double clutch and triple clutch with no luck. I then have to pull over on the side of the road and turn off the motor and after 10 minutes, the engine and gear box cools down and then miraculously, it will disengage out of 4th gear. All other gears work fine and it is drivable, as long as I dont shift into 4th gear. Why? |
John Ghia Samba Member
Posted: Tue Aug 16, 2022 8:26 pm Post subject: Re: 1969 Karmann-Ghia Gets Stuck in 4th Gear. Why? |
I would start with checking the transmission mounts fluid level. _________________ BUS BOYZ |
Posted: Wed Aug 17, 2022 6:10 am Post subject: Re: 1969 Karmann-Ghia Gets Stuck in 4th Gear. Why? |
yes, I checked and replace the transmission/gearbox oil and it still gets stuck in 4th gear. |
Braukuche Samba Member
Posted: Wed Aug 17, 2022 7:40 am Post subject: Re: 1969 Karmann-Ghia Gets Stuck in 4th Gear. Why? |
AJC1967Boone wrote: |
Sounds like something internal. Probably rebuild time. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3819 Location: Georgia
Posted: Wed Aug 17, 2022 12:14 pm Post subject: Re: 1969 Karmann-Ghia Gets Stuck in 4th Gear. Why? |
I don’t have any magic answers for you either.
Being that it only happens while it’s warmed up it might be a simple adjustment.
But I really don’t know what I’m talking about. _________________ Volkswagen!
(Compression 8.7:1) |
Posted: Thu Aug 18, 2022 1:02 pm Post subject: Re: 1969 Karmann-Ghia Gets Stuck in 4th Gear. Why? |
OK, I am going to do some more detective work on this....
Worst case scenario, I will rebuild or replace the transmission.
I will post all updates from my findings. |
Starbucket Samba Member
Posted: Thu Aug 18, 2022 2:55 pm Post subject: Re: 1969 Karmann-Ghia Gets Stuck in 4th Gear. Why? |
Check the shift couplers for slop and is your clutch pedal adjusted with 1" of Freeplay before you feel the throw-out bearing start to move? |
Posted: Mon Aug 22, 2022 7:05 pm Post subject: Re: 1969 Karmann-Ghia Gets Stuck in 4th Gear. Why? |
Is the shift coupler the u shaped connector underneath the rear seat?
I can press down on the clutch about 1" and it disengages
also, I took images of the clutch pedal, this is how it was set up when I got the car.... not sure why this is set up this way...........
Era Vulgaris Samba Member
Joined: August 22, 2012 Posts: 1679 Location: Raleigh, NC
Posted: Tue Aug 23, 2022 5:51 am Post subject: Re: 1969 Karmann-Ghia Gets Stuck in 4th Gear. Why? |
Your brake pedal is way too far from the firewall, and your clutch pedal shouldn't need assistance to stay in place. It looks like you're probably missing the pedal stop that bolts to the floor behind the pedal cluster to limit how far both pedals can be from the firewall.
When you press the clutch pedal in, do you hear any scraping or movement noises coming from inside the tunnel? I'm wondering if any of the clutch cable tube welds have broken, allowing the tube to move which would create difficulty changing gears. _________________ Currently own:
66 Karmann Ghia, L390 Gulf Blue, under construction, here: www.thesamba.com/vw/forum/viewtopic.php?t=760505&highlight=
99 Mazda MX-5 10AE, Sapphire Blue Mica, 6 speed, LSD
Previously owned:
98 Porsche Boxster, silver, 2.5L -- 67 Karmann Ghia, Black, 1500sp -- 98 BMW Z3, Atlanta Blue Metallic, 2.8L I6 -- 75 Porsche 914, Laguna Blue, 2270cc -- 72 Porsche 914, Signal Orange, 1.7 FI -- 74 Karmann Ghia, Black, 1600dp -- 74 Triumph TR6 with O.D., sapphire blue |
Posted: Tue Aug 23, 2022 8:37 pm Post subject: Re: 1969 Karmann-Ghia Gets Stuck in 4th Gear. Why? |
I took it out for a drive today and all the gears shift smoothly into all the gears, but again, the 4th gear gets locked in until I pull over and let the engine cool down. As long as I avoid the 4th gear, the car is operable and drives ok.
When depressing the clutch pedal, there was no scraping or movement noises coming from inside the tunnel |
Marfa61KG Samba Member
Joined: July 15, 2012 Posts: 46 Location: Marfa, Texas
Posted: Wed Aug 24, 2022 12:46 pm Post subject: Re: 1969 Karmann-Ghia Gets Stuck in 4th Gear. Why? |
It's set up that way because Bubba likes it this way. Fix that pedal cluster or stay off the road. That's beyond janky my friend! |
Chad M Samba Member
Posted: Wed Aug 24, 2022 1:33 pm Post subject: Re: 1969 Karmann-Ghia Gets Stuck in 4th Gear. Why? |
Marfa61KG wrote: |
Excellent advice.
If you were to get into a collision, your insurance company would laugh at you. |
