Sodo Samba Member
Joined: July 06, 2007 Posts: 9606 Location: Western WA
Posted: Wed Aug 17, 2022 10:59 pm Post subject: Mouse Blockers! for Vanagon front air intake (3D printed ABS) |
Mice enter the van here behind this plastic screen.
You can fit 2or 3 fingers in the gap.
People have been blocking this access for years, with various methods.
I siliconed some steel screen over the area.
It's not difficult to block that easy mouse access, but it never really looks good.
I asked my nephew Nico if he wanted to design a Vanagon part to 3D print and he went after it.
There were lots of iterations.
It's not simple geometry, but he's a young feller, he doesn't really know what's difficult.
Nico will be selling them somehow, somewhere, soon, maybe I can list them in the classifieds.
This solution looks good and is super easy to install.
Remove the grille by releasing the 5 grille clips 90°.
Set the blockers in place, screw the blockers to the screen, and then snap the grille back on.
It's a 5 minute job.
We'll make a video.
You screw them to the grille thru the grille lattice.
Interested to hear any comments.
Especially how much you'd happily pay for them.
Nico is only 20 years old but he's a lot like us, foolishly rebuilding a BMW E30 station wagon. _________________
....KTMs, GasGas, SPOT mtb
bobhill8 Samba Member
Posted: Thu Aug 18, 2022 2:58 am Post subject: Re: Mouse Blockers for the Vanagon fresh air intake |
Cool design. I was just thinking this morning that some of the best mods to my van had been items designed by Samba folks. I also just found a ton of little Maple helicopter seeds in my top bunk when my daughter went to sleep up there recently. I would say at least $30, and once you've had mouse damage, you would wish you had spent a lot more. Nice work Nico. _________________ 1986 Westy
1971 Squareback |
do.dah Samba Member
Joined: August 27, 2015 Posts: 444 Location: Washington
Posted: Thu Aug 18, 2022 6:34 am Post subject: Re: Mouse Blockers for the Vanagon fresh air intake |
Interesting. As I recall, when I mouseproofed mine, that gap is a pretty substantial, triangular shape. I'll hafta take a look again, but, I don't think this would block my gap near as nicely as what it seems to do on yours.
I had some fine meshed expanded metal that I cut and bent and crimped into place to block that access.
I also clipped some airfilter media behind that grill. Seems to keep the inside of my van, much less dusty. |
Pchill2 Samba Member
Joined: November 19, 2021 Posts: 405 Location: Georgia
Posted: Thu Aug 18, 2022 6:47 am Post subject: Re: Mouse Blockers for the Vanagon fresh air intake |
Great design and resolution on the print. How much? _________________ 87 Syncro Westy
Honda K24 swap |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32598 Location: Reading Pennsylvania
do.dah Samba Member
Posted: Thu Aug 18, 2022 7:05 am Post subject: Re: Mouse Blockers for the Vanagon fresh air intake |
I don't recall what airfilter media I used, but, it's fine mesh and polyester or some kinda synthetic.
I live in Seattle, and have had no issues regarding wetness.
It gets pretty filthy, so I hafta take it out every once in a while and wash it. |
ThinkingD Samba Member
Joined: January 21, 2020 Posts: 130 Location: Ottawa Ontario Canada
Posted: Thu Aug 18, 2022 9:15 am Post subject: Re: Mouse Blockers! for Vanagon front air intake (3D printed ABS) |
I put steel wool in the gaps for winter storage. This is an interesting year-round solution. _________________ 87 Titian Red Westfalia 2.0 VW I4 SOHC manual Ottawa, Ontario |
AndyBees Samba Member
Joined: January 31, 2008 Posts: 2330 Location: Southeast Kentucky
Posted: Thu Aug 18, 2022 10:02 am Post subject: Re: Mouse Blockers! for Vanagon front air intake (3D printed ABS) |
Nice work ...
Don't forget at the access via the top of the rear engine compartment vents on each side .......... Remove the vents ........ then stuff something in there toward the front off the vehicle...... keeps them out of the attic. _________________ '84 Vanagon Tin-top, ALH TDI. 1989 Tin-top
1983 Air-cool, 225k miles, 180k miles mine. Seven trips to Alaska from 1986 thru 2003. |
montanasurfer Samba Member
Joined: March 06, 2014 Posts: 319 Location: United States
Posted: Thu Aug 18, 2022 11:22 am Post subject: Re: Mouse Blockers! for Vanagon front air intake (3D printed ABS) |
I'd buy that. However I think you need to add a piece for the center hole where the center grill pin clips in. _________________ 1987 Vanagon GL - Wolfsburg Edition |
Sodo Samba Member
Posted: Thu Aug 18, 2022 11:51 am Post subject: Re: Mouse Blockers! for Vanagon front air intake (3D printed ABS) |
I dutifully screened my other van 12 years ago.
I never get mice in my van when all the doors are closed.
This go-around we thought the grille covered it ….
but yes it needs another printed piece.
Nice little catwalk.
Thanks!!!
I was all prepared to reply that blocking the center was an old legend!
Good thing I posted this! _________________
....KTMs, GasGas, SPOT mtb |
?Waldo? Samba Member
Posted: Thu Aug 18, 2022 3:05 pm Post subject: Re: Mouse Blockers! for Vanagon front air intake (3D printed ABS) |
It looks like the current version does not fit tightly enough to prevent mice from passing.
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4777 Location: Bemidji, MN
Posted: Thu Aug 18, 2022 3:52 pm Post subject: Re: Mouse Blockers! for Vanagon front air intake (3D printed ABS) |
when i had my airbox out, there were openings at the far end driver's and passenger side bottom of the intake scoop, observable from only INSIDE the ram air box. i didn't take any photos but will be doing another airbox this winter and can do so then. i stuffed stainless scrubbies in those far corners that i could stick my fingers thru so the front intake may not be the only entrance. i also wrapped aluminum window screen around the entire front opening and it stays in place nicely after crimping it down just with fingers.
hard to keep Satan's Little Helpers at bay... _________________ -dan
www.thefixitworkshop.com |
Sodo Samba Member
Posted: Thu Aug 18, 2022 5:28 pm Post subject: Re: Mouse Blockers! for Vanagon front air intake (3D printed ABS) |
?Waldo? wrote: |
It looks like the current version does not fit tightly enough to prevent mice from passing. |
We’ll get those areas covered up in “V16”.
Gonna make a 3rd pc for the center.
I suppose at some young age, a juvenile mouse can go thru a 1/4" hole.
But mice in general, are rated for 1/4" slots, like cooling slots in sheetmetal.
Not 1/4" pencil holes.
And not every slot.
Like if your 2 inch thick slab door is 1/4" above the floor they can't get thru that.
Any other areas that 3D printed plastic can solve? _________________
Posted: Thu Aug 18, 2022 5:39 pm Post subject: Re: Mouse Blockers! for Vanagon front air intake (3D printed ABS) |
Sodo wrote: |
Any other areas that 3D printed plastic can solve? |
- end caps for the moustache bar
- Idle control valve mount... is there a sorta rubbery filament? this IS available, kinda expensive tho.
- flywheel port cover
- spice rack clips for chili pepper lights! using Scotch tape now _________________ -dan
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12005 Location: Santa Cruz, CA
Sodo Samba Member
Posted: Thu Aug 18, 2022 6:54 pm Post subject: Re: Mouse Blockers! for Vanagon front air intake (3D printed ABS) |
Yikes I didn’t know someone else already did it!
But if ever there was a competition for mouse-blockers, Nico's is more elegant..... _________________
DuncanS Samba Member
Posted: Tue Sep 19, 2023 6:25 am Post subject: Re: Mouse Blockers! for Vanagon front air intake (3D printed ABS) |
The side and front pieces of the hardware cloth have stripped back vertical wires so they are firmly interlocked. Essentially a single piece of 1/4" hardware cloth.
Duncan |
Posted: Tue Sep 19, 2023 6:50 am Post subject: Re: Mouse Blockers! for Vanagon front air intake (3D printed ABS) |
i've got a section of aluminum window screen covering the entire opening.. you can crush it into shape to seal around the air box intake and it stays in place with no clips.
when i had the airbox out, from the interior opening of the steel airway, i stuffed stainless steel scrubbies into some nooks and crannies that seemed like the intake mesh didn't cover. _________________ -dan
