Marcdeb Samba Member
Posted: Mon Aug 01, 2022 5:19 pm Post subject: Re: 68 Regatta Blue Karmann Ghia Vert 22,350 Original Miles |
Ian Godfrey wrote: |
Marc, is it possible that's a firewall seal? not an engine tin seal.
has it got 2 'flaps'? |
No, I'm certain it's the deck seal with two flaps - the same one I've seen referred to as the "K" style. I'm sure it will do the job, but I expected I was paying extra for the German quality which would include being an exact reproduction.
I looked through pictures on BAT and I see some like my original that have longer flaps and others that have shorter flaps like this one. I bought it from CIP1 and to be honest, I've not had the best of luck with CIP1. They're not very friendly on the phone.
In this same order that arrived today, I also bought a locking gas cap which doesn't work. Good thing I didn't test it on the car as it will not unlock. _________________ Marc
71 Karmann Ghia Cabrio
Previously Owned:
2011 VW EOS Hard Top Conv
2008 Saab 9-3 2.0T Conv
2003 Saab 9-3 SE Conv
2001 Saab 9-3 Conv
1998 BMW 3 Series Conv
1997 Saab 900 Conv
1997 Mazda Miata
71 Ghia Vert Restoration: https://www.thesamba.com/vw/forum/viewtopic.php?t=726710&postorder=asc |
Posted: Wed Aug 03, 2022 10:58 am Post subject: Re: 68 Regatta Blue Karmann Ghia Vert 22,350 Original Miles |
Spent a quite a few hours under the car yesterday and today. I cleaned the underneath of the engine and transmission and then changed the transmission gear oil. Not hard to do, but it really is a messy job. I was certain I had a 17mm hex socket, but turns out I did not. I have a friend who used to be VW Mechanic 40 years ago and he had the actual Snap-on tool that the VW Dealers used.
The bottom of the transmission pan was really coated with oil. Years and years of leaking. I'm sure I'll have to pull the engine eventually to address the leaks. For now, I'm glad to see it cleaned up and know that the maintenance is done. I was also happy to see that there wasn't any metal particles on the drain plug magnet. Looks a lot better.
I also put a new fuel filter under the car and removed the one in the engine compartment.
I think the fuel line by the transmission was original as it had undercoating on it. Good thing I changed it, I noticed that it was a little wet at the firewall end where it went onto the hard line and as soon as I touched it, it started dribbling fuel on the ground.
I was hoping to put the fuel filter above the axle like I've seen in pictures, but with the AutoStick, there's a large vacuum cannister that takes up most of the space, so I it's kind of out of sight, above the heat tube.
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
obus Samba Member
Joined: March 08, 2001 Posts: 11071 Location: just off Garden State Parkway Exit 81
Posted: Mon Aug 08, 2022 11:59 am Post subject: Re: 68 Regatta Blue Karmann Ghia Vert 22,350 Original Miles |
Over all for sitting in storage for 10 or 15 years (not sure how long) between 198? to 1997, and then again 23 years between 1999 and 2022, I'm surprised that Regatta is in such good shape mechanically.
As I'm progressing through maintenance, I'm coming across some stuff that I've not read about before and I'm curious to find some answers to some questions.
I know about the oil breather tube with the rubber boot near the thermostat, but don't really understand it completely. How much seepage of oil is normal? Isn't this contributing to "oil leaks" or should there not be enough oil coming out to ever cause drips under the car? The rubber boot is missing on my car but I'll be replacing it.
I noticed that my 68 has what appears to be a rubber plug on the bottom of the tunnel near the forward end of the fork. Never noticed this before. I checked my 71 and it has a hole but no plug. Are these plugs available? And is it basically just a drain? Or is it to access something at that location?
Naturally the car does have oil drips. It would be amazing if it didn't. I see that some of the valve rod tubes have leaky seals, but it's seems like it's just enough to cause the tube to be wet but and not actually dripping. Should I be concerned?
I'm contemplating pulling the engine in the fall just to sort things out, clean everything up, fix some of the leaks, and paint or powder coat the tins. I'm not concerned with making the engine compartment look new, just preserve and keep things clean. _________________ Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
Ian Godfrey Samba Member
Joined: September 25, 2006 Posts: 1137 Location: Melbourne Australia
Posted: Mon Aug 08, 2022 4:31 pm Post subject: Re: 68 Regatta Blue Karmann Ghia Vert 22,350 Original Miles |
Re the oil breather. As the engine get more worn (piston rings) you get some 'blow by' which increases crankcase pressure which leads to more oily air coming out that breather. Most of the oily air goes to the air cleaner. Usually there would be only occasional drips underneath. I wouldn't worry about the push rod tubes until you need to do other work on the engine like a valve job.
The plug in the bottom of the pan is new to me, most pans have the drain hole in case some water got in etc. Is the plug a loose fit so water could get out, or tight? |
Posted: Mon Aug 08, 2022 6:07 pm Post subject: Re: 68 Regatta Blue Karmann Ghia Vert 22,350 Original Miles |
So cleaning the bottom of the oil breather tube once in while would make sense then.
I had never noticed the plug at the fork either. However I looked through some pictures on BAT and found plenty of other Ghias that also have the plug.
Thanks for advice. Very helpful. _________________ Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
rbsurfguy Samba Member
Joined: August 10, 2008 Posts: 1757 Location: Fairfax, Northern Virginia Formerly Huntington Beach, SoCal
Posted: Tue Aug 09, 2022 4:02 am Post subject: Re: 68 Regatta Blue Karmann Ghia Vert 22,350 Original Miles |
Hi Marc, I am interested in those lines coming off your oil pump, first pic above of underside of engine. I don't ever remember seeing that set up, of course I don't remember ever having a perfectly stock motor myself. It looks like the line running up to the right connects to your oil bath/air cleaner, but where does the other line go, the one running straight up?
Is this set up due to having an auto stick, or because it is an early model. Just curious.
Jeff _________________ 1971 Ghia convertible (Body off rebuild)
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Jeff's 71 Vert Restoration/Reassembly http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight= |
Posted: Tue Aug 09, 2022 4:15 am Post subject: Re: 68 Regatta Blue Karmann Ghia Vert 22,350 Original Miles |
Hi Jeff,
Correct, these lines are for the AutoStick transmission. The transmission uses two lubricants, there's regular Hypoid Oil in the transmission itself, and then there's the Automatic Transmission Fluid. The lines you see are for circulating the automatic transmission fluid. The oil pump on cars with an Autostick is a double pump.
One of those 2 lines runs back to the ATF reservoir in the engine compartment and the other line runs to the transmission. _________________ Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
Posted: Tue Aug 09, 2022 12:39 pm Post subject: Re: 68 Regatta Blue Karmann Ghia Vert 22,350 Original Miles |
Excellent. It's been a few years since I've seen an autostick, so good to learn something about how it works. Thanks Marc!
2012 Passat-Sold
Posted: Thu Aug 18, 2022 1:44 pm Post subject: Re: 68 Regatta Blue Karmann Ghia Vert 22,350 Original Miles |
Unfortunate that the original generator was tossed when a new one was installed but I was able to find a correct original generator dated January of 1968.
Pretty close to the cars build date of April 1968. It was filthy when it arrived.
I cleaned it up and had it checked by a local shop. He put new bearings in it and gave it a clean bill of health.
Now I'm looking to buy some push on connectors. Does someone know of a source for these?
New if they exist, or maybe some old connectors salvaged from old wiring. One terminal is wider and thicker
than the other. _________________ Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3916 Location: In Molinya Orbit
kingkarmann Samba Member
Posted: Mon Aug 22, 2022 6:11 am Post subject: Re: 68 Regatta Blue Karmann Ghia Vert 22,350 Original Miles |
Marcdeb wrote: |
than the other. |
It's great to see you returning Regatta to her original glory!
Really helps on the investment side too _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
What is your "Bespoke Reality"? |
Posted: Mon Aug 22, 2022 6:45 pm Post subject: Re: 68 Regatta Blue Karmann Ghia Vert 22,350 Original Miles |
kingkarmann wrote: |
Really helps on the investment side too |
Thanks for the comments. She deserves to have all her correct parts put back where they belong. _________________ Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
Posted: Thu Sep 01, 2022 8:51 am Post subject: Re: 68 Regatta Blue Karmann Ghia Vert 22,350 Original Miles |
Interesting detail about the 68 Karmann Ghia. Turns out it's the only year of production where it was not possible to lock access to the fuel filler. 68 is the first year of the fuel fill flap on the fender but there's no locking mechanism, just a depression for lifting the flap. When the 69's came out they had added the locking flap operated by a lever in the glove box.
Regatta arrived with a non original aftermarket cap so the original must have gotten lost. I bought a new after market locking gas cap from CIP1 but it didn't work! Imagine that!!
I then bought this NOS German made locking cap which looks more like what the regular VW cap looked like and it works great.
Correct Rebuilt original VW carburator from Tim @ Volkzbitz is in the mail and should arrive early next week. _________________ Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
Braukuche Samba Member
Posted: Thu Sep 01, 2022 12:26 pm Post subject: Re: 68 Regatta Blue Karmann Ghia Vert 22,350 Original Miles |
Nice touches! _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
Trylon Samba Member
Joined: August 16, 2019 Posts: 4853 Location: Connecticut
Posted: Thu Sep 01, 2022 9:53 pm Post subject: Re: 68 Regatta Blue Karmann Ghia Vert 22,350 Original Miles |
I love that Marc! _________________ 1973 Porsche 914 2.0
1959 Volkswagen Karmann Ghia
1979 Volkswagen Rabbit
1973 Volkswagen Bus
1970 MGB-GT
1962 Oldsmobile Jetfire
More tomfoolery on
The Karmann Ghia Fever YouTube Channel! |
Posted: Fri Sep 02, 2022 5:36 pm Post subject: Re: 68 Regatta Blue Karmann Ghia Vert 22,350 Original Miles |
Had the car out for a ride this evening, top down of course but it's cooling off already in Vermont and it made me realize I hadn't tested the heat to see if it worked. I've heard so many complaints about how bad the heat is in these old VWs so I was caught off guard. It works very well. Even with the top down at 45 mph. But is it normal for there to be an odor along with the heat? It's not a gas or oil smell, more like a hot musty smell. _________________ Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
Posted: Fri Sep 02, 2022 8:22 pm Post subject: Re: 68 Regatta Blue Karmann Ghia Vert 22,350 Original Miles |
Marcdeb wrote: |
Had the car out for a ride this evening, top down of course but it's cooling off already in Vermont and it made me realize I hadn't tested the heat to see if it worked. I've heard so many complaints about how bad the heat is in these old VWs so I was caught off guard. It works very well. Even with the top down at 45 mph. But is it normal for there to be an odor along with the heat? It's not a gas or oil smell, more like a hot musty smell. |
The heater in a Ghia is very efficient.
The musty smell is likely dust that’s collected from non use. I bet if you run the heater for a while it will clear up. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Posted: Sat Sep 03, 2022 2:36 am Post subject: Re: 68 Regatta Blue Karmann Ghia Vert 22,350 Original Miles |
Braukuche wrote: |
Marcdeb wrote: |
The musty smell is likely dust that’s collected from non use. I bet if you run the heater for a while it will clear up. |
What makes the heater in a Ghia more efficient than the Beetle? Aren't the chassies mostly the same? _________________ Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
