Bounty Hunter dune buggy build thread
Page: Previous  1, 2, 3, 4
dlyle
dlyle is offline
PostPosted: Mon Jun 13, 2022 9:24 am    Post subject: Re: Bounty Hunter dune buggy build thread Reply with quote
One of the things that wasn't on the to do list was a license plate light. There isn't a lot of room at the top. There is probably enough room at the bottom but I wanted a clean look. Another huge accomplishment....the car is now registered and road legal.
They make these cool bolt lights.
dustymojave
dustymojave is offline
PostPosted: Thu Jun 30, 2022 2:24 pm    Post subject: Re: Bounty Hunter dune buggy build thread Reply with quote
I like that!
It would be interesting to see a picture in the dark of that car next to something late model factory with the lights on for comparison of effectiveness.
Richard
SoCalBajas Member
dlyle
dlyle is offline
PostPosted: Fri Aug 12, 2022 3:52 pm    Post subject: Re: Bounty Hunter dune buggy build thread Reply with quote
I've been working a lot of hours on the Bounty Hunter. Made some really good progress. For starters I yanked out the old wiring and put in a Rebel harness. So far everything works except the fuel gauge. Once I verify it all works then it will all get wrapped and straightened out a bit more.
This hole isn't where the wires exit but is the access point where the tube runs to the back of the car.
dlyle
dlyle is offline
PostPosted: Fri Aug 12, 2022 3:59 pm    Post subject: Re: Bounty Hunter dune buggy build thread Reply with quote
The buggy is fighting me the whole way. Hooked the headlight switch up and no lights came on. Took the switch apart and everything had a coating or glaze on it. Cleaned it up and it now works. The toggle switches and warning lights were the same so I just replaced them.
I eliminated the speedo cable and went with a set of Classic Instruments gauges. The speedo is GPS driven with a little black receiver under the dash. Hooked it up and after about 4 minutes it had signal. It has constant 12v so once it has signal it will hold it (no need to wait again). The speedo also has a tach.
With the 3 wire turn signal switch a trailer 3 to 2 wire converter was needed so the brake and turn signals would work with the single bulb tail light set up that I have. Just behind that is the GPS box. If you look up past that at the fuel filler tube you can see I removed the filler. The filler hose wasn't adjusted right so I was getting fumes in the buggy. I think I'll be able to push the tube up a bit more so it seals against the filler on the top side and the tank side.
I'd like to take the hood off to replace my fuel tank and sender but when the buggy was painted the hood was left in place. The only way to get them apart would be by cutting in to the paint and making a mess. I may eventually do it because there isn't room to swap out the fuel sender and that bugs me. I did manage to get the tank clean. Filled it with Evapo-rust and let it soak for a week. Drained it and all the rust was gone.
EVfun Premium Member
EVfun is offline
PostPosted: Fri Aug 12, 2022 7:11 pm    Post subject: Re: Bounty Hunter dune buggy build thread Reply with quote
The VW reserve tap is available new and it fits in the later tanks. In my first buggy I used that, with an original reserve tap handle from the wrecker, instead of a fuel gauge. In my case it was because the builder created a fuel filler that bolted to the original fuel gauge hole -- sender not possible.
Wildthings wrote:
dlyle
dlyle is offline
PostPosted: Fri Aug 12, 2022 9:01 pm    Post subject: Re: Bounty Hunter dune buggy build thread Reply with quote
Wow, I knew nothing about reserve taps but that sounds like a great stop gap solution. Will call WW on Monday.
dlyle
dlyle is offline
PostPosted: Tue Aug 30, 2022 2:51 pm    Post subject: Re: Bounty Hunter dune buggy build thread Reply with quote
After 3 years the motor is in the car and running. Just need to figure out the clutch so I can drive it.
https://youtube.com/shorts/ilmMZkIIb_8?feature=share
joemama
joemama is offline
PostPosted: Wed Aug 31, 2022 10:57 am    Post subject: Re: Bounty Hunter dune buggy build thread Reply with quote
Congratulations. Sounds and looks great!
dlyle
dlyle is offline
PostPosted: Wed Aug 31, 2022 11:04 am    Post subject: Re: Bounty Hunter dune buggy build thread Reply with quote
Thanks. It's been a long road...too long. I should have spent more time on it during the covid lockdown.
SteveM.
SteveM. is offline
PostPosted: Wed Aug 31, 2022 2:41 pm    Post subject: Re: Bounty Hunter dune buggy build thread Reply with quote
Sounds good! What is the issue with the clutch?
dlyle
dlyle is offline
PostPosted: Wed Aug 31, 2022 3:22 pm    Post subject: Re: Bounty Hunter dune buggy build thread Reply with quote
It's very difficult to push on the pedal. I've got the pictures and details on another thread. Basically I'm using the Transvair setup but they way it's designed seems odd to me. Not much of a mechanical advantage to the lever system they have. I'm afraid I'm going to break a pedal pushing the clutch in. None of the instructions out there have a good picture of this lever arm. The one other Transvair I saw had the cable attached right to the clutch rod.
https://www.thesamba.com/vw/forum/viewtopic.php?t=...338e808daa
The lever pivots on that bottom bolt. Seems like it may work better if I just attach the cable right to the clutch rod.
This is another way they do it with the clutch cable clamp method. This is also going through the midpoint of the lever arm.....seems very hard to get good leverage that way.
dlyle
dlyle is offline
PostPosted: Mon Sep 12, 2022 11:21 am    Post subject: Re: Bounty Hunter dune buggy build thread Reply with quote
I fiddled with the clutch a bit and started to run out of reasons to not give it a try and drive it. I modified the clutch cable so it hooks directly to the clutch rod....no more pivot arm. It needs a clutch return spring but it works.
This is a video of the first drive. I need to adjust the carbs as it may be idling on just one carb. Runs ok when cold and the choke is on then seems like it looses some idle speed once it's warmed up. One side of the motor is about 75 degress hotter and that seems to usually point to it not idling on both carbs.
https://youtu.be/bBVaOWy1Upo
it's funny because those front tires are so low on air I can squeeze them and they squish in my hands. Hardly any weight on the front end so they never look flat. The car seems to drive ok. Once tuned it will be fast. With the 31" tires you can go pretty fast in second gear.
MrGoodtunes
MrGoodtunes is offline
PostPosted: Tue Sep 13, 2022 9:27 am    Post subject: Re: Bounty Hunter dune buggy build thread Reply with quote
dlyle wrote:
... Hardly any weight on the front end ...
And with that big powerful engine cantilever'd out the back end; Wheelies?
dlyle
dlyle is offline
PostPosted: Tue Sep 13, 2022 9:51 am    Post subject: Re: Bounty Hunter dune buggy build thread Reply with quote
I think so. When I jack up the car at the back the front wheels come off the ground too. The center seems to be right near the rear torsion housing. That was with an empty tank so hopefully the front will stay down with a few gallons in it.
dlyle
dlyle is offline
PostPosted: Wed Jun 21, 2023 10:26 am    Post subject: Re: Bounty Hunter dune buggy build thread Reply with quote
Finally did some work on the hardtop.
This is how it started. It had an ugly hinge right in the middle.
Off to Miguel Diaz for final finishing. He did all the work...not me.
Now good as new and the same color as the interior. I don't have a picture yet but the underside looks just as nice with no visible seams or repairs.
dlyle
dlyle is offline
PostPosted: Mon Feb 10, 2025 4:23 pm    Post subject: Re: Bounty Hunter dune buggy build thread Reply with quote
The tires on the Bounty Hunter were ancient so I replaced them. It's difficult find a set that matches front to back. There just aren't a lot of options. In this case I wanted a 31" tall tire in the back and a matching brand 14" for the front. I found these Vitour Galaxy tires which were higher recommended by the Cobra guys. The rear tires came from Germany so had to wait a while to get them. I haven't driven on them yet but hopefully will soon.
These are the old tires.
Here are the new tires.
I found a perfect match for the Cragar center cap blue. It's Dupli-Color Intense Blue Pearl BCC0422 (PB3) which replaces T359. I had to touch up a few of the caps and you can't tell where the new paint is vs the old paint. It's a spray can so I spayed some in a small container and brushed it in.
Letterman7
Letterman7 is offline
PostPosted: Sun Feb 16, 2025 6:55 am    Post subject: Re: Bounty Hunter dune buggy build thread Reply with quote
Nice work so far. I have the same top for my Deserter. You might regret filling that hinge point. It's really difficult getting in and out with the top on!
dlyle
dlyle is offline
PostPosted: Sun Feb 16, 2025 8:40 am    Post subject: Re: Bounty Hunter dune buggy build thread Reply with quote
Do you mind taking some pictures of how the top attaches? I’ve got some loops at the front with kind of a threaded eyelet but can’t really tell how it should attach. Also no evidence of how it should attach at the back.
Letterman7
PostPosted: Wed Feb 19, 2025 10:06 am    Post subject: Re: Bounty Hunter dune buggy build thread Reply with quote
I actually don't have mine on yet - still in the build process. But the guy I purchased from sent some photos of the attachment point on his buggy (which he used hinges on the back so the entire top rotates upwards to get in and out, but overall attachments should be the same). At the rear, it's just bolts through the deck and into the top's lower flange. At the front, your windshield posts should have either a threaded hole or a threaded post for the top to attach to. The top should have two holes at the corners. There isn't much else holding these on!
Page 4 of 4
