Recent discovery of a new found 356 motor ID
aa390392
aa390392 is offline
PostPosted: Mon Aug 22, 2022 10:16 am    Post subject: Recent discovery of a new found 356 motor ID Reply with quote
Yes Thanks in advance, looking for knowledge on Engine ID
Auto: 1960 356
Eng KD *P*88850
Any help would be great.
Thank you..
Thomas
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet
qwerty
qwerty is offline
PostPosted: Mon Aug 22, 2022 1:27 pm    Post subject: Re: Recent discovery of a new found 356 motor ID Reply with quote
Engine number 88850 is a 1600 S (Type 616/2 T5), part of range 88321 to 89982.
This engine was originally fitted to a car as follows:
1961 (built 1961) T5 B cabriolet (Reutter) with a serial number between 154561 and 155569.
1961 (built 1961) T5 B coupe (Reutter) with a serial number between 114651 and 117476.
1961 (built 1961) T5 B hardtop (Karmann) with a serial number between 200001 and 201048.
1961 (built 1961) T5 B roadster (Drauz) with a serial number between 88921 and 89010.
1961 (built 1961) T5 B roadster (D'Ieteren) with a serial number between 89011 and 89483.
http://www.356a.com/searchengine.php?searchterm=88850&searchterm2=&submit=Start+Search
aa390392
aa390392 is offline
PostPosted: Mon Aug 22, 2022 2:57 pm    Post subject: Re: Recent discovery of a new found 356 motor ID Reply with quote
What do the letters “ K D P” represent?
55 ragtop
56 delux sedan
56 Kabriolet
janerick3
janerick3 is offline
PostPosted: Mon Aug 22, 2022 5:24 pm    Post subject: Re: Recent discovery of a new found 356 motor ID Reply with quote
KD = Kunden Dienst
Without getting into the semantics, essentially a factory-rebuilt engine.
Thanks,
Jan K.
dougdadmac
dougdadmac is offline
PostPosted: Wed Sep 21, 2022 8:43 pm    Post subject: Re: Recent discovery of a new found 356 motor ID Reply with quote
KD is usually associated with a" replaced at the factory" usually under warranty. And will often be noted on the Kardex engines stamped with AT were usually sold at dealers and probably rebuilt at the factory. Some other oddball engines out there includingat least one or two that start with POS believe it or not: https://forum.porsche356registry.org/viewtopic.php?f=1&t=49319&hilit=POS+engine+number
