gingerporsche Samba Member
Joined: August 22, 2010 Posts: 25 Location: Sutton on sea, lincolnshire, England
Posted: Tue Sep 13, 2022 6:49 am Post subject: 6v with okrasa |
Hi, just wondering if most are still running 6v with an okrasa engine,
Mines just been newly built with ww okrasa crank-cam-top end kit plus new barrels and pistons etc..
Now finding it turns over a lot slower to start than when it was standard!
Is everyone else’s similar? |
Bub Samba Member
Joined: June 10, 2004 Posts: 1155 Location: Central Washington
Posted: Tue Sep 13, 2022 9:59 am Post subject: Re: 6v with okrasa |
Check your timing first, that can be one thing that makes the engine turn over slow. And then the usual stuff.
When I had that problem I crawl underneath and jump the starter. If it still cranks slow it's the starter. If it cranks decent it's wiring, ground, switch etc..
In my case it was the starter and I got a super cheap one from Rockauto, 4 years on and it's still great. _________________
hitest wrote: |
Had a girlfriend once who shall we say, nearly arrived at the mere sight of a semaphore in action- easy to please she was... |
PeteSC Samba Member
Posted: Wed Sep 14, 2022 5:19 am Post subject: Re: 6v with okrasa |
Mine is still 6v and cranks over fine. As mentioned check your timing (they like a lot - at least 32* max, possibly higher if your jetting allows), grounds, etc. I did add a hard start relay some time ago which greatly improved the starter performance. |
Redlabel6 Samba Member
Joined: October 17, 2016 Posts: 383 Location: Minnesota
Posted: Fri Sep 16, 2022 11:10 am Post subject: Re: 6v with okrasa |
Thanks chaps, Think it maybe time for a new battery as I’m not sure how old it is! any recommendations?and what capacity (ah) etc
All earths and wiring all look good.. |
Braukuche Samba Member
Posted: Fri Sep 16, 2022 11:52 am Post subject: Re: 6v with okrasa |
gingerporsche wrote: |
Make sure you use 2 gauge battery cables makes a big difference. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
Mr. Mike Samba Member
Joined: January 30, 2015 Posts: 513 Location: Shoreline, WA
Posted: Sat Sep 17, 2022 8:11 am Post subject: Re: 6v with okrasa |
On a sedan, I run a longer bolt (so it extends beyond the pan) under the seat for the negative ground and then run an additional cable from that bolt (with a nut) to the ground on the starter.
Cheers! _________________ 1964 Sedan 6 volt |
scotty timmerman Samba Member
Joined: January 10, 2010 Posts: 1000 Location: gigharbor W.A
Posted: Mon Sep 19, 2022 1:41 pm Post subject: Re: 6v with okrasa |
Thanks chaps, but think I’ve sorted it!
Cleaned all connections and replaced the earth on the battery an now turning over loads better 👌🏻 |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Tue Sep 20, 2022 11:28 am Post subject: Re: 6v with okrasa |
Also clean the surfaces between the starter and transaxle where they mate together and same for the starter to starter solenoid. Those grounds need to be CLEAN and DIELECTRIC GREASED to get the most out of the starter. _________________ In Stereo, Where Available! |
5500 Samba Member
Joined: October 16, 2020 Posts: 112 Location: Cape Cod
Posted: Wed Sep 21, 2022 2:12 am Post subject: Re: 6v with okrasa |
No issues with mine. Clean grounds, fresh cables and added a hot start relay to enhance starting. |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
PeteSC Samba Member
Posted: Wed Sep 21, 2022 1:25 pm Post subject: Re: 6v with okrasa |
Getting a bit off topic here, but I like the idea of not running the full starting amp load through my hard-to-find lowlight ignition switch, and instead through the more easily replaceable relay, so I run one, even with my meticulously cleaned and dialectric-greased connection points. |
Bub Samba Member
Posted: Wed Sep 21, 2022 4:24 pm Post subject: Re: 6v with okrasa |
Lingwendil wrote: |
I've never found the need to run a hot start relay on any vehicle that has clean connections. |
Same here. Except that I actually did install one not long ago on my 54' that was cranking slow. Wasn't long before my brain said:
bubs Brain wrote: |
Want to rethink that relay thing? You shouldn't need it." |
Swapped the starter and haven't needed it since. They are just a band-aid for a problem, but band-aids aren't always bad temporarily. _________________
hitest wrote: |
5500 Samba Member
Posted: Sat Sep 24, 2022 12:20 am Post subject: Re: 6v with okrasa |
In addition to running a hot relay, I fabbed new 2 gauge cables, redid all grounds with larger diameter wire, added discreet relays to the headlight,fog light, wiper circuits and replaced light bulbs with LED units. My goal was to preserve as much of the original wiring and switches as possible and prevent any catastrophic electrical failures. Engine cranks effortlessly. Don't think of it as a bandaid... more of an improvement over a primitive design. |
gsthomas Samba Member
Joined: June 22, 2013 Posts: 4 Location: Nuremberg area, Germany
Posted: Sun Jan 21, 2024 9:07 am Post subject: Re: 6v with okrasa |
The compression on my latest Okrasa build is higher so the stock-size 6V battery sometimes struggled. I upgraded to a higher capacity Optima battery and no issues since then. Also run current through relay and make sure no corrosion on both sides of the loop from battery to starter. _________________ (o\ ! /o) (o\ ! /o) (o\ ! /o) (o = i = o)
1956 1961 1962 1973 |
