MsTaboo Samba Member
Joined: June 02, 2006 Posts: 4087 Location: East Kootenay, British Columbia
Posted: Fri Sep 23, 2022 7:43 pm Post subject: Factory Syncro Service Manual w/lockers |
While looking through Busmaneu's website I came across this Syncro service manual in English which has much more info than the Bentley.
Included is service for the lockers both front and rear.
And for the factory decoupler! This was a Bowden cable operated device quite different than our vacuum decouplers but shows VW had a decoupler in mind.
They label it a "Selectable 4WD" and starts at page 26.
https://busmaneurope.com/_library/_files/pdf%20files/syncro_gearbox.pdf
Pretty cool stuff I hadn't seen before, except for a brief schematic of parts. _________________ Currently:
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12005 Location: Santa Cruz, CA
Posted: Fri Sep 23, 2022 10:29 pm Post subject: Re: Factory Syncro Service Manual w/lockers |
Thank for posting this. This information will likely be lost with time without people putting it out there and resharing it.
I have seen images before but not in english or a source. |
redriverhill Samba Member
Joined: July 06, 2010 Posts: 16 Location: Vancouver B.C.
Posted: Sat Sep 24, 2022 9:58 am Post subject: Re: Factory Syncro Service Manual w/lockers |
It’s like you read my mind MsTaboo.
This is a great separate document to have.
Thanks |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6349 Location: Honolulu,Hawaii and France
Posted: Sat Sep 24, 2022 10:51 am Post subject: Re: Factory Syncro Service Manual w/lockers |
Thank you for sharing the english version
I have the french paper manual and PDF too.
At page 26 and on is indeed the decoupler, but it's vacuum actuated, which you can see on the diagrams.
The bowden cable actuation was for the PTO (power take off), and it located differently.
Here are pics I've been gathering for a while on the internet:
_________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
Posted: Sat Sep 24, 2022 11:09 am Post subject: Re: Factory Syncro Service Manual w/lockers |
Yep, I've heard of that PTO option also (thanks for the pictures, first I've ever seen!), but if you re-read the manual it clearly states the early factory decoupler had a Bowden cable engagement which then activated the vacuum portion of the setup. You can see the Bowden cable/knob connection at the three knob locker panel on pages 36 and 38 and where it connects to the low gear housing on page 40 with that odd vacuum setup.
(EDIT
Not sure why they thought they needed both a cable and vacuum lines?
It's a bit odd, picture 34-1792 and 34-1672 seem to contradict each other, with 34-1792 looking like our current vacuum only decoupler)
It looks like with their "Selectable 4WD" option there was no VC, only 2WD and part time 4WD as described on page 27. Note there's no VC in the diagram on page 26.
No mention of the PTO in this service manual. _________________ Currently:
Posted: Sat Sep 24, 2022 11:32 am Post subject: Re: Factory Syncro Service Manual w/lockers |
MsTaboo wrote: |
No mention of the PTO in this service manual. |
Ok, gotcha, yes there's an intermediary actuator that is cable actuated and then does the vacuum job , kinda like a centralized manifold #19 on the drawing.
It's a rather complex system, I wonder what the engineers were thinking
It's apparently engages automatically when low gear is engaged, but it is not disengaged later, only manually via the cable. Kinda half ass operation and pretty complex, probably why it never went into production. It'd be cool to see such prototype. _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
tjet Samba Member
Posted: Sat Sep 24, 2022 11:38 am Post subject: Re: Factory Syncro Service Manual w/lockers |
I'm trying to understand this, specifically, B.
Posted: Sat Sep 24, 2022 11:50 am Post subject: Re: Factory Syncro Service Manual w/lockers |
This was VWs idea of what is now called the "solid shaft" option that some of the hard core Syncro owners use then doing a lot of driving in sand. GW advocates this idea (they like going to Baja). However us northerners tend to prefer the AWD of the VC for snowy, icy, rainy roads.
No VC, so it's 2wd only when driving on roads and then "fixed" 4wd when selected. This binds the front diff/transmission together for instant traction on soft surfaces like sand. The slight delay in engagement of the VC sometimes causes the rear wheels to dig in before the front wheels have traction so the solid shaft idea is closer to true 4wd. It's not safe to drive on roads however with this setup, and you lose the great performance of AWD on shifting surfaces like snow covered roads that the VC provides.
Section B indicates there was automatic engagement of the coupler just by shifting into "granny" gear (cross-country gear). This is probably why the setup is so complex. _________________ Currently:
tjet Samba Member
Posted: Sat Sep 24, 2022 12:18 pm Post subject: Re: Factory Syncro Service Manual w/lockers |
I see. So they that dropped that idea as Alika mentioned. Yeah kind of a complex "auto coupler" feature, when you can just engage the coupler / decoupler (selectable 4wd) manually.
Thanks for posting this |
Posted: Sat Sep 24, 2022 12:28 pm Post subject: Re: Factory Syncro Service Manual w/lockers |
Yep, and the bean counters had them drop the whole idea in favor of just the VC which the majority of owners would prefer.
Obviously the engineers still liked the idea and came up with the simpler vacuum only decoupler we use today.
Too bad VW didn't continue to offer as an option. _________________ Currently:
tjet Samba Member
Posted: Sat Sep 24, 2022 12:40 pm Post subject: Re: Factory Syncro Service Manual w/lockers |
I wonder that rare PTO option uses the same gear and pieces that were originally designed for the automatic coupling feature, maybe repurposed. Hmmm.
I would guess a PTO option would be a requirement for military or some other "fleet" use, like forestry service.
Good stuff |
Posted: Sat Sep 24, 2022 4:08 pm Post subject: Re: Factory Syncro Service Manual w/lockers |
Looking further into this service manual it doesn't cover anything about the front locker warning system. That must have been added later.
That PTO that AlikaT3 shows seems kinda hard to use. You would need to climb under the body to attach things or need some kind of additional linkage.
I guess it could have been used for pumps or a winch? Maybe a dump truck bed option on the Sinkas? _________________ Currently:
Posted: Sat Sep 24, 2022 5:36 pm Post subject: Re: Factory Syncro Service Manual w/lockers |
The PTO was installed.for the swedish(?) market to help with sales tax.or.something like that. I have seen pictures of them and a few for sale over the years but I never got the impression that they were used for anything. |
Posted: Sat Sep 24, 2022 8:21 pm Post subject: Re: Factory Syncro Service Manual w/lockers |
syncrodoka wrote: |
Yes, it's a trick for tax reasons in Finland. It's crazy to go these extra lengths just for selling a few thousand units.
I have never seen the hydraulic bed set up, but I'm pretty sure the second hydraulic pump was set as an option where the second alternator option would lay.
To my knowledge, nothing has ever been offered to be hooked up by VW to this PTO, even as an option. I'm not aware of even an adapter to that stubby shaft sticking out of the transmission. That's the kind of things that would be on paper catalogs for special orders. _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
Posted: Sun Sep 25, 2022 9:55 am Post subject: Re: Factory Syncro Service Manual w/lockers |
Just FYI, Everett has added the manual to the Technical section, sub heading Owner's Manuals, Type 2-Bus, Owner's/Parts/Other Manuals in 1986 as a PDF. _________________ Currently:
tjet Samba Member
Posted: Sun Sep 25, 2022 2:16 pm Post subject: Re: Factory Syncro Service Manual w/lockers |
ALIKA T3 wrote: |
syncrodoka wrote: |
Another reason to love VW |
xclemjustinx Samba Member
Posted: Mon Sep 26, 2022 10:27 am Post subject: Re: Factory Syncro Service Manual w/lockers |
Does anyone know which wires (wire colors) from the sub harness go to the locker illumination switch and reverse light switch on the Syncro Trans?
I have a 1986 Doka Syncro with a rear locker only. There has been many discussions but wanted to see if anyone here in this thread knows. Thanks! |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10248 Location: N. Idaho
Posted: Mon Sep 26, 2022 12:51 pm Post subject: Re: Factory Syncro Service Manual w/lockers |
In those days it was still common for farmers to use the PTO on their 4WDs for a variety of farm tasks. Splitting wood, pumping water into irrigation ditches, that kind of thing. Many 4wds had the "port" still on their drive trains in the form of a simple cover.
VW marketed the Syncro toward rural land owners, farmers, and commercial users in many countries. As for the tax dodge - there are a lot of examples of this. Everything from shipping pickups to the USA without beds to avoid the "chicken tax", to the Subaru Brat including seats in its bed to avoid same. It was a mess for a while. So, including a $100 PTO driven component with the Syncro probably let it be taxed with an agricultural rates break in some European countries at the time that may have been a huge discount.
The output shaft was probably a common one used by various pump shafts and the like back in the day, but something you cannot find anymore as better ways have come along to do those tasks. Cool bit of history. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9604 Location: Western WA
Posted: Mon Sep 26, 2022 1:18 pm Post subject: Re: Factory Syncro Service Manual w/lockers |
I know a feller who’s had one for 20 years.
In a box of course, ‘cuz no need has arisen.
But if any of you folks come across a ‘need’….
Its the end of the “intermediate shaft” on the syncro low-gear housing.
The speed is 9/31 of the engine RPM.
So at 1860 RPM the output is 540 RPM.
~4mph in granny gear
Ok there ya go, who’s got a use for one?
A field mower for Van events? _________________
....KTMs, GasGas, SPOT mtb |
