Bugged Again Samba Member
Joined: July 09, 2022 Posts: 162 Location: Virginia -Hampton Roads
Posted: Fri Sep 23, 2022 5:41 pm Post subject: Engine removal with deep sump? |
I recently acquired a 63 type 1 and noticed it has a deep sump add on. Does this need to be removed before dropping the engine? I’m not familiar with this assembly and I don’t know if it can support the engine weight during removal.
Thanks in advance. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Fri Sep 23, 2022 5:44 pm Post subject: Re: Engine removal with deep sump? |
Bugged Again wrote: |
Yes you can leave it on to remove.
Just don't jack the car up using the sump. but once on jackstands its fine to leave it on
Here's my fully dressed engine sitting on the sump on a floor jack.
_________________ Glenn
Member #1009
#BlueSquare |
DeathRay64 Samba Member
Joined: February 03, 2019 Posts: 217 Location: Arizona
Posted: Fri Sep 23, 2022 5:47 pm Post subject: Re: Engine removal with deep sump? |
I left mine on. It's much easier to deal with on an engine stand than to try to remove it on the car. _________________ Making VW's and America great again. |
Posted: Sat Sep 24, 2022 5:58 am Post subject: Re: Engine removal with deep sump? |
Thanks guys. I will leave it on and not use it as the lift point during removal. I didn’t want to remove it while in the car. What a mess! |
Teeroy Samba Member
Joined: April 20, 2003 Posts: 3685 Location: Eastern WA
Posted: Sat Sep 24, 2022 7:47 am Post subject: Re: Engine removal with deep sump? |
You can lift the engine with the sump, just not the car, never lift the car by the engine, deep sump or not. _________________ Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org |
Posted: Sat Sep 24, 2022 2:43 pm Post subject: Re: Engine removal with deep sump? |
Teeroy wrote: |
You can lift the engine with the sump, just not the car, never lift the car by the engine, deep sump or not. |
Nope, never done that before but glad you mentioned it. I was just worried that the sump might get crushed supporting the engine weight alone. |
Busstom Samba Member
Joined: November 23, 2014 Posts: 3853 Location: San Jose, CA
Posted: Sat Sep 24, 2022 6:41 pm Post subject: Re: Engine removal with deep sump? |
Teeroy wrote: |
You can lift the engine with the sump, just not the car, never lift the car by the engine... |
I used to do that when I was a stupid teenager in the early 80's, not putting 2 and 2 together to realize the weight of the car was hanging by the tranny mounts. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Sat Sep 24, 2022 6:46 pm Post subject: Re: Engine removal with deep sump? |
1. You worry too much.
2. But you were smart enough to ask FIRST !!! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Sun Sep 25, 2022 11:46 am Post subject: Re: Engine removal with deep sump? |
Cusser wrote: |
2. But you were smart enough to ask FIRST !!! |
You’re right. I really do worry too much and can make problems when there aren’t any.
