viiking Samba Member
Joined: May 10, 2013 Posts: 2668 Location: Sydney Australia
Posted: Sat Sep 24, 2022 4:18 pm Post subject: Door alignment - latch mechanism on or off? |
I have new heater channels welded at front and back of my body waiting to mate the pan and body back up. I am waiting to weld the rest of it (A and B pillars, 1/4 panels) to make sure the pan and doors line up.
The doors have new door pins, have good gaps but need to be lifted up half an inch to align the trim holes with the body. I can do this easily with a clamp.
Question. Should I fit the door striker and latch and achieve this "lift" then weld. Or should I align the doors without the striker and latch, force the door up to align and then weld.
When I watch the Bug Me videos, they always seem to have all of the door mechanisms in place so it is not obvious how much the door mechanism helps to achieve the trim hole alignment. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
mukluk Samba Member
Posted: Sun Sep 25, 2022 12:08 pm Post subject: Re: Door alignment - latch mechanism on or off? |
I would prefer to get the door aligned without the striker in place before welding. In my mind this method would better insure the body would be in the correct position. Using the striker to hold the door in place could have the body slightly tweaked and leave you relying on the striker to nudge it into proper position, thus adding extra stress and wear to the latches and hinges over time. _________________ 1960 Ragtop w/Semaphores "Inga" |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9966 Location: Huntington Beach, CA
Posted: Sun Sep 25, 2022 10:31 pm Post subject: Re: Door alignment - latch mechanism on or off? |
mukluk wrote: |
I would prefer to get the door aligned without the striker in place before welding. In my mind this method would better insure the body would be in the correct position. Using the striker to hold the door in place could have the body slightly tweaked and leave you relying on the striker to nudge it into proper position, thus adding extra stress and wear to the latches and hinges over time. |
x2
The door should work effortlessly when everything is aligned properly. No stress from anywhere! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
