Stever1 Samba Member
Joined: April 23, 2012 Posts: 18 Location: Connecticut
Posted: Mon Sep 26, 2022 12:32 pm Post subject: broken cable to '77 beetle trunk hood |
I just bought this standard beetle and the trunk lid is stuck with a broken cable. Unfortunately, there is a spare tire in the trunk and even though I've opened the access port below, I can't seem to move the tire out of the way. Has anyone ever done this in a standard beetle? |
APPLEGREENVW Samba Member
Joined: November 30, 2003 Posts: 2387 Location: Seekonk,Massachusetts USA
Posted: Tue Sep 27, 2022 3:43 am Post subject: Re: broken cable to '77 beetle trunk hood |
Cutting the handle off will be my last resort. I want to exhaust all other possibilities first. It may seem a waste of time, but I don't want to destroy the original handle if I can figure out another way. Right now I'd like to see if it's even possible to move the spare tire. |
busman78 Samba Member
Joined: August 17, 2004 Posts: 4522 Location: Oklahoma City, OK
Posted: Tue Sep 27, 2022 4:11 am Post subject: Re: broken cable to '77 beetle trunk hood |
Is the cable broken at the latch or is it the pull lever is not working as in floppy at the glove box? If the cable is still attached to the latch and the glove box is kind of ugly I would trash the glove box and pull the cable.
Spare cannot be lifted out of the way, with the spare in place drilling a small acces hole in the right wheel well to slip a stiff wire pull in from is also out.
Not a lot of options. |
Posted: Tue Sep 27, 2022 5:14 am Post subject: Re: broken cable to '77 beetle trunk hood |
Cable must be broke at the latch. I'm able to get to the cable from just inside the radio opening and pull on it with no effect. Sounds like you're certain the spare can't be moved? I had tried moving it from the access hole behind, but no luck. |
baldessariclan Samba Member
Joined: October 14, 2016 Posts: 1378 Location: Wichita, KS
Posted: Tue Sep 27, 2022 7:00 am Post subject: Re: broken cable to '77 beetle trunk hood |
Stever1 wrote: |
Why? Hood handles aren't all that uncommon -- you can find both original German NOS and/or good used ones fairly easily. And there are good instructions in the orange Bentley shop manual on how to cut and remove it.
All that said, you might still be able to move the spare tire around a bit from the outside, via manipulation thought the various access holes in the front. However, the covers and securing fasteners for all those holes are generally accessed from inside the trunk area - don't know how you could easily remove any of them from the outside - ? And it's been my experience that the spare tire is often wedged fairly tightly into the spare wheel well - usually a two-handed affair, involving a bit of muscle flex, to remove them in the first place. Trying to get one like that to budge through those little access holes? Hmmm -- good luck... _________________ 1971 Standard Beetle — fairly stock / driver
baldessariclan -- often in error, never in doubt... |
Posted: Tue Sep 27, 2022 7:25 am Post subject: Re: broken cable to '77 beetle trunk hood |
Good points. I guess I'm just being stubborn in not wanting to cut the handle. I've seen some references of people able to move the tire, but mine seems wedged in pretty tight. I'm going to give it one more try this weekend and if not successful, off comes the handle. |
lboos Samba Member
Joined: November 20, 2015 Posts: 410 Location: Marietta GA.
Posted: Tue Sep 27, 2022 8:05 am Post subject: Re: broken cable to '77 beetle trunk hood |
I've tried it all, cut the handle. |
