Done-it-again Samba Member
Posted: Mon Sep 26, 2022 5:06 pm Post subject: Motor dies out under load |
I’m having a issue on a new to me 65 sedan 1600. It’s happened a couple of times where the motor will die under load after driving it for 30 or so minute. It will idle and I can give it throttle with no load and runs fine. It will have to sit for most of the day and all good. I thought it could be Vapor lock, but I don’t know. So I dont drive it all that far.
I’ve read about carb and distributor matching and that is a rabbit whole in its self. But could be the issue.
This is what I have. I had the motor looked over to make sure it was good and cleaned up some small oil leaks. Then I was told it needed the timing advance reduced as it was to much. Not sure if that was compensating for the issue as it didn’t happen before.
Makes me wonder if I have the wrong distributor and should go with this one.
https://www2.cip1.com/vwc-043-905-205/ That has a vacuum advance.
Any help would be appreciated.
Cusser Samba Member
Joined: October 02, 2006 Posts: 31380 Location: Hot Arizona
Posted: Mon Sep 26, 2022 6:51 pm Post subject: Re: Motor dies out under load |
Let's start with what you have already; I also run a Solex 30/31 PICT on an adapter on a 1600cc dual port engine, and mine runs good, but I use a vintage German 009 distributor.
Why is your carburetor idle solenoid unplugged?
Done-it-again wrote: |
It’s happened a couple of times where the motor will die under load after driving it for 30 or so minute. It will idle and I can give it throttle with no load and runs fine. |
I would make sure that the choke is set correctly, maybe it's too rich so dies out after warming up.
I'd also try running with the gas cap loose temporarily to see if it's a tank venting issue. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Mon Sep 26, 2022 8:05 pm Post subject: Re: Motor dies out under load |
Cusser wrote: |
I'd also try running with the gas cap loose temporarily to see if it's a tank venting issue. |
I started to take my carburetor and fuel pump off and took a picture before I got to far. I thought I was having fuel issues, but the fuel pump is good and the carb bowl was full.
I’ll have to check the choke setting and check the fuel cap. Thanks. |
