saddlesore1 Samba Member
Posted: Tue Sep 27, 2022 3:39 pm Post subject: LED Dash lights |
I received an email from one of the big 2 suppliers for LED dash lights and went down the rabbit hole. I could not believe that a compete set of lights (10) could possible cost $70 plus tax and shipping. I went to my local electronic store and was able to order the exact same items for $22 out the door. I guess the box cost $50
Starbucket Samba Member
Posted: Wed Sep 28, 2022 4:37 pm Post subject: Re: LED Dash lights |
$50.00 because it has a picture of an old Porsche |
qwerty Samba Member
Slip356 Samba Member
Posted: Thu Oct 13, 2022 5:27 am Post subject: Re: LED Dash lights |
Do you have any info on 6 volt led dash lights. All I see are 12 volt.
Slip |
Posted: Thu Oct 13, 2022 7:22 am Post subject: Re: LED Dash lights |
Slip356 wrote: |
Slip
https://www.amazon.com/ba7s-led/s?k=ba7s+led
Scroll down until you see 6volt. |
Posted: Thu Oct 13, 2022 2:50 pm Post subject: Re: LED Dash lights |
Thanks, will do more research, then order them. |
Posted: Thu Oct 13, 2022 3:02 pm Post subject: Re: LED Dash lights |
I don't think I would change the gen. light to LED unless the Mfg. states it won't affect the charging. |
Posted: Fri Oct 14, 2022 6:05 am Post subject: Re: LED Dash lights |
Star bucket, I think you are talking alternator, not generator like I have. Those with more knowledge than me will hopefully chime in.
Slip |
Posted: Fri Oct 14, 2022 7:16 am Post subject: Re: LED Dash lights |
Slip356 wrote: |
Slip
You are right, that was for alternator. |
Posted: Sat Oct 15, 2022 6:40 am Post subject: Re: LED Dash lights |
Don’t plan on changing alternator or oil light as they are plenty bright, day or night. Remaining lights are too dim, hopefully LED’S will brighten up the dash at dusk or dark. |
Posted: Sat Oct 15, 2022 6:42 am Post subject: Re: LED Dash lights |
Meant to say generator light, not alternator. Need more coffee! |
Posted: Fri Oct 28, 2022 2:28 pm Post subject: Re: LED Dash lights |
Changed all of them out. Found out the Geni light was on or off only. It takes more amps/volts to trigger than standard so I pulled it out and replaced with standard bulb. Found same thing for oil.
Other than that the dash lights up brighter. |
Posted: Fri Oct 28, 2022 3:13 pm Post subject: Re: LED Dash lights |
Good to know, haven’t ordered mine yet but will soon. Can they be dimmed like standard 6volt dash lights?
Where did you purchase them from?
So now I have three winter projects -good.
1. Led dash lights
2. Third brake light. Have purchased two 8 in 6 volt units from Stoddard.
3. A 6 to 12 volt inverter to change the cigarette lighter to 12volts to feed my Garmin & charge my cell phone when traveling.
Looks like a good winter. |
Posted: Sat Oct 29, 2022 9:56 am Post subject: Re: LED Dash lights |
Amazon has them. |
