Semaphores
pre67vw
pre67vw is offline
PostPosted: Wed Sep 28, 2022 4:18 pm    Post subject: Semaphores Reply with quote
Hi All, I’d like to learn a little more about semaphores… I’ve seen the page with all the part numbers listed, but I still have questions.
I think the first Beetle semaphores (excluding anything kdf) were ‘sided’ in that each had a L and a R on them and the ends were sloped. Then some time in ‘49 (anyone know when?) they ditched the sided and became just ribbed (SWF) or grooved (HS).
Is it correct that the ribbed had two screws on the cover and the grooved had 4 rivets? Why do some have SWF logo on the lens and some have VW?
Then I have read that Zwitters had ribbed semaphores with a single screw, but I have one of these with what I think is a Dec ‘50 date code - can that be right?
Then the next version was the smooth cover.
What is a short arm or a long arm?
Then there are the convertible versions… when did these start? as most split Cabrios I’ve seen (and Hebs) have sedan semaphores, but I have seen photos of the elusive Cabrio semaphore with a VW logo on the frame (obviously not from another marque)
Thanks!
www.pre67vw.com
johnshenry Premium Member
johnshenry is offline
PostPosted: Thu Sep 29, 2022 9:11 am    Post subject: Re: Semaphores Reply with quote
The first ribbed, universal SWF (not left or right) came out in mid 1950. The first version had a a single screw and the end of the steel arm/cover wrapped around the end of the lens, and a sheet metal type screw there. This version did not have the sliding bulb access door underneath, you had to take the arm/cover off to change the bulb. These sems are fairly rare, especially the lenses since they are unique to this model.
Sometime in early '51, the more common ribbed one came out, 2 screws and the brass sliding bulb access door.
Later, the SWF was modified again. It had 2 screws, but one was hidden underneath the steel arm. It was a beveled screw that fit flush to the inner steel pivot arm. This allowed the removal of the arm with a single screw and the lens would stay attached.
Other details were the dropping of the side to side tabs at the top of the steel pivot arm sometime in 1952.
I have been restoring early sems for 15+ years and keep a spreadsheet of each sem I get get my hands on, the date code of it, and the details that it has.
John Henry
'57 Deluxe
'56 Single Cab
mk-Zero
mk-Zero is offline
PostPosted: Fri Sep 30, 2022 8:36 am    Post subject: Re: Semaphores Reply with quote
Great info! Applause Cool
Vintage Classic Specialist, Orange, CA
www.VCSresto.com
[email protected]
1952 VW Standard beetle
1955 VW Type 1, 231 hp daily driver
1956 VW Karmann Convertible Okrasa
pre67vw
pre67vw is offline
PostPosted: Sat Oct 01, 2022 5:50 am    Post subject: Re: Semaphores Reply with quote
Yep, great info, thanks John!
So this:
Am I correct in thinking this is date code MB is December '50?
What month/year did the sided semaphores end?
How does this semaphore differ from the later zwitter sem that I think also has a single screw?
www.pre67vw.com
PostPosted: Sat Oct 01, 2022 7:17 am    Post subject: Re: Semaphores Reply with quote
Yes, that is the first version of the "longnose" SWF sem, dated MB, Dec 1950. It does not have the sliding bulb access door underneath, very rare to find these with usable lenses. The earliest date coded versions of those I have seen is June 1950.
John Henry
'57 Deluxe
'56 Single Cab
pre67vw
pre67vw is offline
PostPosted: Sat Oct 01, 2022 7:36 am    Post subject: Re: Semaphores Reply with quote
Thanks John.
So what does ‘longnose’ refer to?
www.pre67vw.com
PostPosted: Sat Oct 01, 2022 7:46 am    Post subject: Re: Semaphores Reply with quote
pre67vw wrote:
Thanks John.
I call them that as the steel arm wraps all the way around the "nose" end of the lens. This semaphore is seen in the Sept 1950 Service manual.
John Henry
'57 Deluxe
'56 Single Cab
ThatVWGuy
ThatVWGuy is offline
PostPosted: Sun Apr 02, 2023 11:11 am    Post subject: Re: Semaphores Reply with quote
Should a '51 Beetle have ribbed or smooth semaphores?
PostPosted: Sun Apr 02, 2023 11:12 am    Post subject: Re: Semaphores Reply with quote
Either SWF ribbed, or SHO grooved. But not smooth.
John Henry
'57 Deluxe
'56 Single Cab
Böm
Böm is offline
PostPosted: Mon Apr 03, 2023 4:44 am    Post subject: Re: Semaphores Reply with quote
Regarding the first version SWF ”longnose” sem. Is there anyone making new lenses for them?
PostPosted: Mon Apr 03, 2023 5:17 am    Post subject: Re: Semaphores Reply with quote
Unfortunately, no.
John Henry
'57 Deluxe
'56 Single Cab
Dean Bradley
Dean Bradley is offline
PostPosted: Sun Oct 01, 2023 2:28 am    Post subject: Re: Semaphores Reply with quote
Gentlemen
Do you know if Grooved SHO pre 1951 semaphores are sided/ Handed ? My car is missing a drivers side SHO grooved semaphore, and has a original one fitted on the passenger side, car is a November 1950 export deluxe , I’m trying to ensure I get it correct
Many Thanks
The Original German Folks UK
The path of the Righteous is Never Smooth .....
finster
finster is offline
PostPosted: Sun Oct 01, 2023 3:06 am    Post subject: Re: Semaphores Reply with quote
looking at the table on the semaphore info page it lists just one part number which suggests they were not handed. seems bad design to have handed parts when there's no real need just extra cost
https://www.thesamba.com/vw/archives/info/semaphores.php
PostPosted: Sun Oct 01, 2023 5:55 am    Post subject: Re: Semaphores Reply with quote
Dean Bradley wrote:
Gentlemen
Many Thanks
No. SHO never made "sided" semaphores that I am aware of. I have been restoring them for over 20 years. What is the date code on the one SHO sem that you have?
John Henry
'57 Deluxe
'56 Single Cab
Dean Bradley
PostPosted: Sun Oct 01, 2023 9:32 am    Post subject: Re: Semaphores Reply with quote
Thanks for the information Finster , I will look at that Cool
Dean Bradley
PostPosted: Sun Oct 01, 2023 9:35 am    Post subject: Re: Semaphores Reply with quote
johnshenry wrote:
Dean Bradley wrote:
Gentlemen
Many Thanks
John Henry it’s still installed in the car, and working fine, But I can pull it an take a look, I’m determined to get the car as accurate as I can, and in my ownership I’ve been slowly tracking down the correct parts for it , Many thanks for the info though
