RonFink51 Samba Member
Posted: Fri Sep 30, 2022 2:34 am Post subject: Problem with my directionals |
Last night I noticed that I had no directionals. When I used moved the blinker shaft, the arrow on the speedometer lit up but didn't blink. When I looked further, no directional lights where coming on in the front or rear. This was on both the left and right side but my headlights and taillights are still working.
Can anyone point me in the right direction. It is a 65 Bug still 6 Volt |
glutamodo The Android
Joined: July 13, 2004 Posts: 26307 Location: Douglas, WY
Posted: Fri Sep 30, 2022 7:02 pm Post subject: Re: Problem with my directionals |
Dash arrow light, but no flashing, usually means no power to the blinker relay.
This could be from a bad fuse, or a bad connection where that fuse sits in the fuse box (if the fuse looks good, try spinning it a bit to make contact with the mounting tabs)
Assuming stock wiring is still in place, the headlights and marker lights are not from that fuse. However, the brake lights are, as well as the wipers and horn. _________________ Andy T.
