Endopotential Samba Member
Joined: February 13, 2012 Posts: 186 Location: Pacifica, California
Posted: Sun May 29, 2022 1:24 pm Post subject: Re: 2003 Eurovan stalling on highway in heat. |
Hey Eurotec,
I like the new profile pic!
You have a uncanny resemblance to one of my favorite YouTube DIY'ers Dino
https://www.youtube.com/c/HackaweekTV/about
Maybe you can start your own channel to help us work on our vans?? |
EuroTec Samba Member
Joined: August 24, 2020 Posts: 378 Location: Asheville, North Carolina
Posted: Tue May 31, 2022 4:27 am Post subject: Re: 2003 Eurovan stalling on highway in heat. |
Endopotential wrote: |
Hey Eurotec,
Not sure if you are joking but yeah, that would be me. Been at it for over 11 years now. _________________ If it ain't broke, don't fix it! |
Posted: Tue May 31, 2022 10:30 am Post subject: Re: 2003 Eurovan stalling on highway in heat. |
That is so totally awesome! I found your series about the Honda Saber cafe racer back when I was building my own. Love all the stuff you do.
Great to have you as part of the Eurovan community. Wish you were still in closer in Cali though! |
Anaxemines Samba Member
Posted: Tue Jun 07, 2022 6:09 pm Post subject: Re: 2003 Eurovan stalling on highway in heat. |
EuroTEc - First off I want to say thank you for your painstaking report of your diagnostic. The timing for me was ideal, as literally yesterday I was on my way to the Canadian border (live in Alaska) to drive down to Seattle, when after 200 miles in we started having the same symptoms you experienced, stalling when hot, hot day, no codes thrown, etc. Limped home, getting about 25 miles closer after each half-hour cool down. Long trip home!
I'm only just starting to diagnose, but your similar experience with your fuel pump makes me suspect mine.
I'm looking at a VDR fuel pump from FCPEuro to replace. Any advice on removing the union nut with the hammer/screw-driver technique? Also, did you replace the fuel pump seal?
Thanks for your thoughts. |
TheOneTrueQuux Samba Member
Posted: Wed Jun 08, 2022 7:35 am Post subject: Re: 2003 Eurovan stalling on highway in heat. |
Anaxemines wrote: |
If you mean VDO, that's a good OE brand, and among the best in the business for quality. AutohausAZ also carries them. I installed one last year, and it was identical to the one that came out, and installed easily, ran quietly, and fixed the problem I was having. |
Posted: Wed Jun 08, 2022 10:54 am Post subject: Re: 2003 Eurovan stalling on highway in heat. |
Ooops, yep, VDO, not VDR. Thanks for the feedback on their quality. |
Posted: Sun Jun 19, 2022 7:43 pm Post subject: Re: 2003 Eurovan stalling on highway in heat. |
Anaxemines wrote: |
I did not replace the seal as it was OK. I've used the hammer & screwdriver technique with good success many times. A large wide blade screwdriver is preferred. Mark where it is before you start. Don't over tighten it. VDO is the way to go. _________________ If it ain't broke, don't fix it! |
dborell Samba Member
Posted: Wed Sep 28, 2022 11:15 am Post subject: Re: 2003 Eurovan stalling on highway in heat. |
I had the same problem. I had just replaced the fuel pump cause it was making noise with a Pierburg pump form Europarts-SD. Next long trip it stalled. Mechanic there could not find anything wrong. Took it to my local mechanic and he replaced the Crank Speed Sensor...that didn't fix it! I replaced the ignition switch...that didn't fix it!
Finally I drove around town for a few yours until the stalling started happening and took it to my local mechanic so he drive it and witness the stalling. He suspected fuel pump. So we replaced the Pierburg pump with a VDO fuel pump. So far no more stalling!!!
Who expects that a new fuel pump would be faulty? |
MidnightBeggar Samba Member
Joined: January 29, 2020 Posts: 2 Location: CALIFORNIA
Posted: Sat Oct 01, 2022 9:40 am Post subject: Re: 2003 Eurovan stalling on highway in heat. |
Second link is the proper VDO pump. No, they're not cheap but it's well worth the extra cost. _________________ If it ain't broke, don't fix it! |
Posted: Sat Oct 01, 2022 1:08 pm Post subject: Re: 2003 Eurovan stalling on highway in heat. |
Thank you. I'm glad I clarified with you. Appreciate all the troubleshooting work you did.
EuroTec wrote: |
Second link is the proper VDO pump. No, they're not cheap but it's well worth the extra cost. |
