Joined: January 01, 2007 Posts: 16886 Location: sticksville, ct.
Posted: Wed Sep 28, 2022 10:34 pm Post subject: Re: Vanagon Subaru Conversion 2.5 Engine Flooded |
vanis13 wrote: |
P01518 is the only one that is unique.
the other two are typical in a conversion and do not affect any running issues. there are mods possibly to eliminate them by faking their signals. |
agreed
but what are we working on? 2.2? 2.5? SVX? Frankenmotor?
Who did the swap? the harness work?
Did all of this just happen or is this some pig you "got a good deal on"?
we can get this sorted, no doubt but need more info and some detailed pix would be fantastic
it would also be beneficial if you 1) know the year of your donor and 2) buy a subscription to STIS:
https://techinfo.subaru.com/stis/#/login
Alldata DIY
https://www.alldata.com/diy-us/en/diy-repair-information
both have GFF (guided fault finding) and tons of info but you need to know what you have in order for it to have the data for your swap _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Thu Sep 29, 2022 4:01 am Post subject: Re: Vanagon Subaru Conversion 2.5 Engine Flooded |
Is there anything equivalent to the VW Idiot Book for the 1990 and later Subarus? |
vanis13 Samba Member
Joined: August 15, 2010 Posts: 3100 Location: ABQ NM USA.... Except when not
Posted: Thu Sep 29, 2022 4:11 am Post subject: Re: Vanagon Subaru Conversion 2.5 Engine Flooded |
Wildthings wrote: |
I think that is called YouTube 🤣... And if there is one of love to see it as a 2.5 user
What does the VW one look like? _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
Franklinstower Samba Member
Posted: Thu Sep 29, 2022 9:30 am Post subject: Re: Vanagon Subaru Conversion 2.5 Engine Flooded |
Wildthings wrote: |
The FSM - Factory Service Manual
Available through the Subaru Forums, like the Nabisco site, etc
They have full troubleshooting flow charts _________________ '89 Westy - EJ25/22 Frank 4.44 5mt
'75 Miami Blue Sunroof FI Standard Bug |
Posted: Thu Sep 29, 2022 9:57 am Post subject: Re: Vanagon Subaru Conversion 2.5 Engine Flooded |
Franklinstower wrote: |
Wildthings wrote: |
They have full troubleshooting flow charts |
Factory service manuals don't tend to be equivalent to the Idiot Book, FSM expect you to already understand the basics, while the Idiot Book did not. |
11BC2 Samba Member
Joined: August 27, 2017 Posts: 495 Location: Cool, California
Posted: Thu Sep 29, 2022 2:29 pm Post subject: Re: Vanagon Subaru Conversion 2.5 Engine Flooded |
paulcolorado21 wrote: |
Hey All,
Looking for some advice on this issue. I cannot get my van to start or turn over. The TDI starter seems to be working great but it will not turn over even with some revving of the engine. The fuel pump is registering 30 psi, the spark plugs and coil are registering a charge. The engine smells like gas and seems like its flooded.
THE Fuel Injectors are showing constant power without the engine turned on.
Is this a problem with the ECU unit? Fuel Pump Relay? Where should I look next?
Any Help would be much appreciated, hoping to go on a big two month long trip very soon! I'm a Vanagon rookie purchased this last spring and have been loving it! |
What engine is in your vehicle?
What year/model Subaru is the engine?
The ECM?
A common issue with a hodgepodge swap is that the engine, specifically, the crank sprocket is incompatible with the ECM.
More details are needed in order to assist you.
For Reference:
Early type sprocket
Late type Sprocket
PDXnatv Samba Member
Joined: December 13, 2016 Posts: 42 Location: Portland
Posted: Fri Sep 30, 2022 9:43 am Post subject: Re: Vanagon Subaru Conversion 2.5 Engine Flooded |
P01518 code is thrown when the ECM thinks the starter is not getting power. I am going to assume the wiring harness you have has been modified by someone who didn't know what they were doing. I would pull the harness and send it and the ECM and any info you have to Jeff Robenolt he runs Auto Ventures in Wisconsin. He is a master at these engines and conversions. A properly done wiring harness matched to the correct ECM is key in having your Vanagon operational for the rest of your happy days. |
wesitarz Samba Member
Joined: August 20, 2012 Posts: 1491 Location: Victoria,B.C.Canada
Posted: Sat Oct 01, 2022 7:35 am Post subject: Re: Vanagon Subaru Conversion 2.5 Engine Flooded |
Was this engine running before? Injector pulse is controlled by the ECU. Is there power to the injectors with key off,key on and cranking? You could backprobe at the ECU connector using the ECU pinouts. Should only be with cranking. Otherwise I'd suspect the ECU. |
Posted: Sun Oct 02, 2022 6:31 am Post subject: Re: Vanagon Subaru Conversion 2.5 Engine Flooded |
Connect the two green test connectors and turn the key to ON. The fuel pump and fuel pump relay should be cycling. A fuel pressure of 30 psi seems low. With the fuel pump cycling I had cycling pressures of 35 and 40. |
