Munden5 Samba Member
Posted: Mon Oct 03, 2022 1:29 pm Post subject: Water and sediment in old engine- Is it salvageable?Or worth it? |
Hi everybody,
This is my first post and it’s probably in the wrong place so please forgive me. I bought a 1966 VW beetle and the engine was out. Although it’s a 6 volt engine It’s doesn’t appear to be a 1300. According to the location of the serial number(on the top by the generator base) and not below it, it looks to be an engine from maybe a Type 3?
Anyway, The engine spins freely and I was going to try to start it once it’s back in the vehicle. I went to drop the oil and found tons of sludge, sediment and water. The water came out first…then the funky oil and sediment( see pics).
My questions is this. Should I even try to start this engine? Should the engine just be considered toast? Or is there something I can put in the crankcase to clean it up…then put new oil in it?
I’m not a mechanic but I can and do repairs on my own cars and my daughters 1970 VW beetle.
Let me know your thoughts!
Thanks,
Travis |
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5417 Location: Holland, MI
Posted: Mon Oct 03, 2022 1:32 pm Post subject: Re: Water and sediment in old engine- Is it salvageable?Or worth it? |
Pop the valve covers off. If the valve springs have any rust at all, I wouldn’t try and start/run it. Very high risk of scattering the entire engine when a valve spring breaks while running. You may well have a number of good useable parts there for a rebuild, but I wouldn’t gamble it all on a rusty valve spring. _________________ 1800 Type 4 Berrien 295
http://www.thesamba.com/vw/forum/viewtopic.php?t=487021 |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15309 Location: Deep in the 405
Posted: Mon Oct 03, 2022 1:34 pm Post subject: Re: Water and sediment in old engine- Is it salvageable?Or worth it? |
With all those solid chunks in the filter something is going wrong inside the engine. I'd tear it apart for a full inspection. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
RCP Phx Samba Member
Joined: November 20, 2021 Posts: 496 Location: Phoenix,AZ
Posted: Mon Oct 03, 2022 1:47 pm Post subject: Re: Water and sediment in old engine- Is it salvageable?Or worth it? |
Between the oil filter screen and the outside photo the only way to tell is to split the case! |
Posted: Mon Oct 03, 2022 2:16 pm Post subject: Re: Water and sediment in old engine- Is it salvageable?Or worth it? |
quote="Vanapplebomb"]
Pop the valve covers off. If the valve springs have any rust at all, I wouldn’t try and start/run it. Very high risk of scattering the entire engine when a valve spring breaks while running. You may well have a number of good useable parts there for a rebuild, but I wouldn’t gamble it all on a rusty valve spring.[/quote]
They look pretty darn good. What do you think? |
Posted: Mon Oct 03, 2022 2:45 pm Post subject: Re: Water and sediment in old engine- Is it salvageable?Or worth it? |
A little surface imperfection goes a long way on valve springs. I see some rust spots on the springs in the first couple pictures. I wouldn’t try and run it as it sits. I would tear it down and salvage what you can. _________________ 1800 Type 4 Berrien 295
oprn Samba Member
Joined: November 13, 2016 Posts: 12744 Location: Western Canada
Posted: Tue Oct 04, 2022 12:55 am Post subject: Re: Water and sediment in old engine- Is it salvageable?Or worth it? |
With that much gunk in the bottom I would expect on or more valves were open, that is likely where the water got in and you will have a cylinder or two with water damage. Stuck rings and piston scoring will be the result if started without cleaning them up. You might have some rusty valves and valve seats too.
As for the valve springs... mahhh... stock engine, stock springs and cam, low rpms... clean them up and see. Toss the ones with pits. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Tue Oct 04, 2022 4:26 am Post subject: Re: Water and sediment in old engine- Is it salvageable?Or worth it? |
Needs to be torn down and rebuilt. Anything else is a waste of time and money. |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Tue Oct 04, 2022 5:09 am Post subject: Re: Water and sediment in old engine- Is it salvageable?Or worth it? |
Whats the drain plate area look like ?
I've seen water eat the case their _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
NJ John Samba Member
Joined: September 21, 2007 Posts: 2224 Location: HdG, MD & NJ
Posted: Tue Oct 04, 2022 5:34 am Post subject: Re: Water and sediment in old engine- Is it salvageable?Or worth it? |
I’ve seen water eat the case around the sump plate, as Mike said. And one where the bottom of the cam gear was rotted right off. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
Emeraldlion Samba Member
Joined: April 13, 2005 Posts: 743 Location: Texarkana, TX
Posted: Tue Oct 04, 2022 6:43 am Post subject: Re: Water and sediment in old engine- Is it salvageable?Or worth it? |
Hell, life is short. You only live once. Throw some fresh oil in it, marvel mystery a few drops in the cylinders overnight. Try and fire the bad boy up and give it some rpms. If it blows it blows, if not change the oil again and run it until it does blow. _________________ 1967 Sunroof Beetle: tourist pass car
1961 SWR Kombi |
Clatter Samba Member
Joined: September 24, 2003 Posts: 7551 Location: Santa Cruz
Posted: Tue Oct 04, 2022 7:30 am Post subject: Re: Water and sediment in old engine- Is it salvageable?Or worth it? |
Salvageable?
Only one way to know;
rip it apart and see what's in there.
If nothing else you'll get some parts. _________________ Bus Motor Build
What’s That Noise?!? |
oprn Samba Member
Posted: Tue Oct 04, 2022 8:39 am Post subject: Re: Water and sediment in old engine- Is it salvageable?Or worth it? |
Or you could follow Emeraldlion's advice and end up with some tins, a few nuts and bolts and maybe a carb. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
Posted: Tue Oct 04, 2022 8:40 am Post subject: Re: Water and sediment in old engine- Is it salvageable?Or worth it? |
Lol, oh ye of little faith. _________________ 1967 Sunroof Beetle: tourist pass car
1961 SWR Kombi |
Posted: Tue Oct 04, 2022 9:25 am Post subject: Re: Water and sediment in old engine- Is it salvageable?Or worth it? |
I told my horror stories, but rebuilt both engines.
As someone posted earlier, run some fresh oil though it and give it a try. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Tue Oct 04, 2022 9:45 am Post subject: Re: Water and sediment in old engine- Is it salvageable?Or worth it? |
If it had an oil filter, yes, fill with fresh oil and send it. Without a filter, all that grit is going into the bearings and lifter bores. If you're hoping to use this on your new beetle, best to tear it down. Best case scenario you clean everything and put it all back together, but if you start it now add in a crank polish or grind and who knows what else.. _________________ modok wrote:
MuzzcoVW Samba Member
Joined: February 21, 2018 Posts: 1477 Location: Westfield, MA.
Posted: Wed Oct 05, 2022 3:39 am Post subject: Re: Water and sediment in old engine- Is it salvageable?Or worth it? |
txoval wrote: |
Agreed. Not worth the risk...especially when the hard part is done and it's out of the car |
oprn Samba Member
Posted: Wed Oct 05, 2022 5:00 am Post subject: Re: Water and sediment in old engine- Is it salvageable?Or worth it? |
Emeraldlion wrote: |
Lol, oh ye of little faith. |
More like: Oh us of little budget!
"Faith is the substance of things unseen" - we can clearly see the substance in this case! _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
Posted: Wed Oct 05, 2022 6:14 am Post subject: Re: Water and sediment in old engine- Is it salvageable?Or worth it? |
Fair enough. I guess I have saved up a lot of spare parts. I see that as part of the fun with these old things. If the budget is tight, and the skills are not there to be cracking the engine open. I had a 60 beetle from Montana that presented similarly on the valvetrain and didn't have any trouble firing up and running. Went on for a few hundred miles before I redid rings and cylinders. I will admit it did not have that amount of water inside the case though. _________________ 1967 Sunroof Beetle: tourist pass car
1961 SWR Kombi |
