AirHead1966 Samba Member
Joined: October 17, 2019 Posts: 568 Location: Triad Area NC
Posted: Mon Oct 03, 2022 6:07 pm Post subject: You know what causes grinding and sloppy shifting? |
This does. Yikes!
Wonder when it was last replaced. Good thing is that my shift rod bracket is fine.
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9756 Location: Oregon
Posted: Mon Oct 03, 2022 7:05 pm Post subject: Re: You know what causes grinding and sloppy shifting? |
Where's the tension ring for the bushing?
Good thing you found the worn bushing, before it wore through the shift rod bracket. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Mon Oct 03, 2022 7:16 pm Post subject: Re: You know what causes grinding and sloppy shifting? |
The tension ring was still on the rod when I pulled it out. Still usable, not stretched. I reused the same one. Fits fine. |
frenchroast Samba Member
Posted: Mon Oct 03, 2022 8:19 pm Post subject: Re: You know what causes grinding and sloppy shifting? |
Those bushings just don't last; I'm on my third one in 54 years!
I install them with the slit pointed up so I can squirt some triflow in there once in a while. Wheel bearing grease is o.k. but the triflow is much smoother. Also check the coupler under the back seat. Mine is the original and in great shape but they can wear out. |
