rebuild 2.5 or swap |
rebuild w/ turbo |
0% |
[ 0 ] |
swap w/deisel |
100% |
[ 1 ] |
swap w/ suburu motor |
0% |
[ 0 ] |
swap w/ volvo diesel |
0% |
[ 0 ] |
Total Votes : 1 |
dscott90000 Samba Member
Posted: Mon Oct 03, 2022 8:09 pm Post subject: 93 5 speed Westfalia Project (What should I carry in the van |
Just picked up this 1993 5 speed Westfalia new to me , w/ 217k new clutch , runs good, no rust. original paint-
__All fluids are clean and topped off. ___
Looking and reading posts:
1) Are yall carrying extra relays , belts , sensors?
2) what sensors should I just go ahead and order? ( which are hard to find?)(which should I check or suspect of going out quick)?
3) max tire size with a 15" wheel? Want a off-road look
4) Flashing oil pressure light ( P/O says its in the cluster possibly as he soldiered some things back there already in cluster.
5) Flashing coolant light ( P/O says its a coolant level sensor on top of trans ) engine temp stays in middle or under.
6)front wheel bearing swap ( making loud meow noise ) Too involved for dyi?
7) Any way to get lower RPMS on the hwy?
Are these 2.5s easy to drop & rebuild ? or is it better to swap them out ?
9) Any upgrades I should add to this as a semi daily driver ? Trans cooler ? Engine oil temp gauge ?
Thanks for your help
Daniel In Florida
1994Karuso Samba Member
Posted: Mon Oct 03, 2022 8:48 pm Post subject: Re: 93 5 speed Westfalia Project (What should I carry in the van |
Shift linkage bushings
Oil cooler gasket |
Stripped66 Samba Member
Joined: May 31, 2005 Posts: 3470 Location: Charleston, SC
Posted: Tue Oct 04, 2022 3:59 am Post subject: Re: 93 5 speed Westfalia Project (What should I carry in the van |
Just maintain it and drive it. _________________
66brm wrote: |
Bodacious wrote: |
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor. |
I don't think electrickery works that way |
EuroTec Samba Member
Joined: August 24, 2020 Posts: 382 Location: Asheville, North Carolina
Posted: Tue Oct 04, 2022 4:08 am Post subject: Re: 93 5 speed Westfalia Project (What should I carry in the van |
Stripped66 wrote: |
Just maintain it and drive it. |
I second that. _________________ If it ain't broke, don't fix it! |
BatesEV Samba Member
Joined: October 01, 2019 Posts: 182 Location: Los Angeles
Posted: Tue Oct 04, 2022 4:20 am Post subject: Re: 93 5 speed Westfalia Project (What should I carry in the van |
Items that fail on VW=plastic coolant flanges
I would carry your ecm and fuel pump relay, ignition switch, coil, pickup, zip ties, some wire and connectors as start. I just replaced parts and kept the old ones as spares. I had my new coil fail and the backup kept me off a truck.
I wouldn’t worry about rebuilding unless you actually have low oil pressure(check with mech gauge)
I had to solder my cluster 3 times to fix the coolant light
Wheel bearings aren’t the worst but having even a cheap bearing tool kit makes it easy
I also agree the shift linkage bushings, luckily if they fail zip ties can save you for a little. |
KillerGriller Samba Member
Joined: June 15, 2022 Posts: 52 Location: Ontario, Canada
Posted: Tue Oct 04, 2022 8:50 am Post subject: Re: 93 5 speed Westfalia Project (What should I carry in the van |
EuroTec wrote: |
Stripped66 wrote: |
I second that. |
Third'd
BatesEV wrote: |
I had my new coil fail and the backup kept me off a truck |
Is it just the coils that are finicky, or would/should you carry an extra distributor cap/rotor as well? |
wannabecamper Samba Member
Joined: May 09, 2019 Posts: 211 Location: Sunnyside, US
Posted: Tue Oct 04, 2022 9:39 am Post subject: Re: 93 5 speed Westfalia Project (What should I carry in the van |
KillerGriller wrote: |
EuroTec wrote: |
Stripped66 wrote: |
I second that. |
Third'd
Fourth! |
Posted: Tue Oct 04, 2022 11:45 am Post subject: Re: 93 5 speed Westfalia Project (What should I carry in the van |
Cap and rotor just wear out. It wouldn’t be a fail item. When I disassembled the failed coil the power wire from the module to the conector broke. |
volkybus Samba Member
Joined: November 03, 2013 Posts: 481 Location: CASTLETON VT USA
Posted: Fri Oct 14, 2022 7:49 pm Post subject: Re: 93 5 speed Westfalia Project (What should I carry in the van |
My coil failed also shift bushings..shift lever also failed twice.It it's running and driving fine I would not worry..also check drive belt .I carry a spare. LUB the gas cap also.Also check the timing belt , should be tight.if not changed early 5 cyl don't have intruder engines but later 95 on do.but the engine could have been changed..Good Luck...Bill |
Posted: Tue Oct 18, 2022 4:39 pm Post subject: Re: 93 5 speed Westfalia Project (What should I carry in the van |
my shifter just failed....
is this the bushings or the shifter it self? It just went limp while shifting into 5th now she's stuck in neutral cant get into any gears |
Joshwa Samba Member
Joined: November 18, 2015 Posts: 810 Location: North Seattle WA
Posted: Wed Oct 19, 2022 9:30 am Post subject: Re: 93 5 speed Westfalia Project (What should I carry in the van |
Probably this guy. If the bushing fails the rod just falls out.
