Nubby Samba Member
Joined: August 28, 2010 Posts: 605 Location: Down by the river
Posted: Mon Jan 09, 2012 11:02 pm Post subject: |
I dig those rims, nice job! |
MURZI Samba Member
Joined: August 25, 2005 Posts: 5063 Location: Madisonville, La
Posted: Tue Jan 10, 2012 7:53 am Post subject: |
Three inch beam is a good compromise and easy to build. _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
pOrk Samba Member
Joined: April 03, 2011 Posts: 339 Location: Wauwatosa, Wi
Posted: Tue Jan 10, 2012 9:03 am Post subject: |
Nubby wrote: |
If thats to me, thanks! |
BrilliantA3 Samba Member
Joined: December 02, 2006 Posts: 18 Location: West TN
Posted: Tue Jan 10, 2012 11:05 am Post subject: |
So a stock beam with stock wheels running 135's and drop spindles should clear everything, right? I'm thinking of doing adjusters later for a little extra drop. With even a 2" beam you still have to change some other stuff around, right? |
nax Samba Member
Joined: March 26, 2007 Posts: 229 Location: Valencia (Spain)
Posted: Tue Jan 10, 2012 11:20 am Post subject: |
pOrk wrote: |
Nubby wrote: |
also drop spindles? |
smitty24 Samba Member
Joined: April 28, 2008 Posts: 2723 Location: Salem, Oregon
Posted: Tue Jan 10, 2012 11:35 am Post subject: |
another thing for the OP to consider is sway bar options. You can fit a 2" CB setup on a CB beam= very nice and functioning parts by the way. Another option is to use John's Whiteline sway bars...come in a 2" and 3" version. The 3" will fit a 4" beam. Swaybars make a huge difference on these cars. In all honesty, a 4" with stock brakes/wheels is not necessary. Trust me, get a 2" with some 145/65 continentals, and you will have more than adequate clearance and have the ability to set the car nearly on the ground. Wouldnt recommend that, but a 2" is more than what you need with those tires/wheels. I personally dont use super narrow beams anymore because I got sick of the ill effects of super narrow tie rods. Some bump steer never goes away, no matter what you do to help it. |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13280 Location: Tejas!
Posted: Tue Jan 10, 2012 12:43 pm Post subject: |
smitty24 wrote: |
agreed. 2 is good for stock smoothies and 145/65's. _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
buguy Samba Member
Joined: November 17, 2003 Posts: 4915 Location: Port Orange, FL
Posted: Tue Jan 10, 2012 12:50 pm Post subject: |
I also agree. I did 5" and wish I hadent. I would also not go to 135's again. 145 minimum. Maybe im just getting old. |
rubilahmadi Samba Member
Joined: August 21, 2022 Posts: 8 Location: CALIFORNIA
Posted: Wed Sep 21, 2022 8:59 am Post subject: Re: 2" Vs 4" Narrowed Beam |
For those of you who have 4” and 2” narrowed beams:
Do not you have any tire rubbing from inside of the fender
I am planning to lower my 1970 bug, keep the shocks and also change the brakes to dish. I want around 4” drop so drop spindles are not enough for me. Adjustable beams can give me 2-6” drop.
I also like to widen my tires (185 or 195 for the front) but for that I am thinking of wider fiberglass fender but that is the next stage after a successful lowering
Questions
1) Why do people go for drop spindle + adjustable beam? Do they want to drop it more than 6”?
2) If I stay with stock spindle, disk brake is the only thing that may push my tires out. Is 2” narrowed beam enough for this case. My intention is to minimize any tire rubbing from any side |
Tobias Bylund Samba Member
Joined: December 10, 2007 Posts: 202 Location: Varberg - Sweden
Posted: Wed Sep 21, 2022 11:09 pm Post subject: Re: 2" Vs 4" Narrowed Beam |
1) If you use both an adjustable beam and drop spindles you can dial in a nice height without bottoming the shocks out completely, if you slam the beam using stock spindles you will run out of travel on the shocks and have a really bouncy and harsh ride. 2.5" of drop from spindles + 1.5" from adjusters gives you 4" drop and lots of usable travel from your shocks
2) there are some zero offset disc brake kits, but yeah typically you will increase front track with 1/2 per side, so depending on wheel width/ET a 2" narrowed beam might not move the wheel inward all that much |
DerrickfromNC1 Samba Member
Joined: October 24, 2008 Posts: 1302 Location: North Carolina
Posted: Thu Sep 22, 2022 10:12 am Post subject: Re: 2" Vs 4" Narrowed Beam |
rubilahmadi wrote: |
Questions
I would suggest you get and install your widened fenders b4 u make a decision on your beam width and lowering methods. This way you can build/buy everything to fit to the clearances of the fenders…..such as wheel width and offset, ride height, and aftermarket brake offset.
Here’s mine which includes 1” widened fenders, 2” adjustable narrowed beam, 18”x7.5” Porsche wheels, CB 2” drop disc spindles. The Porsche wheels have a lot of positive offset which required me to add a 1/2” spacer to get the perfect fitment I was looking for. Had I gone with a 4” beam the wheels would have set way too deep within the fenders causing all kinds of interference problems in the inner fender area requiring spacing the wheels out 1.5”
The plus side of the 4” beam is that you can always space your wheels back out. Not a lot of options to tucking them back under your fenders!
This next pic is with a 1” spacer.
Posted: Thu Sep 22, 2022 9:39 pm Post subject: Re: 2" Vs 4" Narrowed Beam |
Thanks for great information
My first priority is to have disk brake, lower it by ~4” without any turn radius reduction or tire rub.
From what you have said so far it seems 2.5” drop spindle + 2” narrowed adjustable beam serve my purpose.
Even though DerrickfromNC1 rims look so cool I do not want to add adapter to mount the rim to 4x130 brake rotor
So I will stay with 15x5.5 4x130 rims and install 195 or 205 tires. Once I have this set up working I will check my stock fender if they rub from outside I will go for wider fender (I still prefer steel fender over fiberglass so wide fender is my last option)
Now more questions
JBug has 2” adjustable beam for $499. How is the quality of that beam compared to CB performance. Jbug’s beam gives me wider drop range (2 to 6)
2" Narrowed Beam for Ball Joint. Ratchet Style Adjusters for use w/ DROP SPINDLES
https://www.jbugs.com/product/22-2814.html
6277 2" Narrowed Front Beam (Ball Joint) with Puma™ Style Adjusters ('66-on)
https://www.cbperformance.com/product-p/6277.htm
does anybody have any feedback on EMPI disk brakes quality ?
EMPI VW Disc Brake Kit - Drop Spindle Front - 4x130 - Drilled & Slotted - 1966-77 Beetle - Ghia
https://www.jbugs.com/product/22-6141.html?rrec=true
CB does not have slotted rotor. Do you recommend spending the extra $ to get drilled and slotted rotor ?
4190 Dropped Disc Brake Kit (Ball Joint) 4 Lug '66-on Sedans & Ghias
https://www.cbperformance.com/product-p/4190.htm
in general what is your feeling about EMPI parts from JBug?
Thanks |
Posted: Fri Sep 23, 2022 5:53 am Post subject: Re: 2" Vs 4" Narrowed Beam |
Drill/slotted rotors look good but not necessary for a daily driver VW.
Have you sourced your narrow leaf springs & steering tie rods that will be required with the narrow beam. Might want to consider these guys…they can provide just the 2” beam, or a complete beam with disc brakes, steering box, leaf springs etc, all assembled or anything in between.
https://shop.kaddieshack.com/Build-A-Beam-Ball-Joi...uctId=1081
Don’t forget the 2” narrowed sway bar! |
Posted: Fri Sep 23, 2022 5:19 pm Post subject: Re: 2" Vs 4" Narrowed Beam |
Thanks for the reference
Yeah I am planning to get anything that need to be shortened
My intention of comparison was to see how people like quality of EMPI brand from Jbug (quality of stuff from Jbug in general) compared to CB performance which seems good quality |
Posted: Wed Oct 05, 2022 10:59 am Post subject: Re: 2" Vs 4" Narrowed Beam |
Ok
I am settling for drop spindle and 2" narrowed adjustable beam.
At max setting it gives me 2.5+2=4" drop. I am also eliminating swey bar (do you recommend or not?), I will adjust the rear accordingly
At this hight do I need to use shorter shocks?
What shock height, make and model do you recommend?
Different questions
Do you recommend EMPI ball joints or you go for a better brand if so what do you use?
How about trailing arm bushings? Do you go for polyurethane or old style stock rubber? Which website do you recommend for rubber and bushings? |
devildog86 Samba Member
Posted: Thu Aug 10, 2023 12:40 pm Post subject: Re: 2" Vs 4" Narrowed Beam |
pOrk..I like the set up of your wheels, what size are the wheels and tires? |
