vwmadeinireland Samba Member
Joined: October 31, 2003 Posts: 44 Location: Cork, Ireland
Posted: Fri Jul 17, 2009 2:18 pm Post subject: Who supplies black urethane bushes for 3/4'' front sway bar? |
Who supplies black urethane bushings of size 19mm = 3/4inch for front sway bar? Don't want to use those red ones and guess there are no rubber ones avialable with 3/4'' holes?
All help very much appreciated. |
ladybug89 Samba Member
Joined: February 27, 2005 Posts: 581 Location: City of Orange,CA
Posted: Fri Jul 17, 2009 3:03 pm Post subject: |
you have to put "-BL" after the part number... but here you go
http://www.bugpack.com/content.php?id=567 _________________ 1958 bug - 1958 baja - 1962 vert - 2000 Golf |
Posted: Sat Jul 18, 2009 1:09 am Post subject: |
Thanks, that was very helpful and got me the answer. For completeness in case someone else has same wish to avoid red ones:
BUGPACK ITEM LIST
Order these with -BL behind the part numbers:
6500-010 Repl Bushing Kit, Front 12mm Bar LP/ BJ, Red
6500-011 Repl Bushing Kit, Front 3/4 Bar LP/ BJ, Red
Or even easier use:
6500-016 Repl Bushing Kit, Frt 12mm Bar LP/BJ, Black
6500-017 Repl Bushing Kit, Frt 3/4 Bar LP/BJ, Black |
Posted: Mon Oct 26, 2009 2:17 am Post subject: |
Still no luck locating these black busings
Anyone able to help me and tell me who stocks these Bugpack items? |
BUGTHUG Samba's Rented Mule
Joined: April 22, 2007 Posts: 833 Location: KANSAS toto's fire hydrant
Posted: Mon Oct 26, 2009 9:50 am Post subject: |
I'm thinking either cip1.com, or CBPerformance has the black. _________________ I know you would understand what I'm saying if you could just see my HANDS
Even the middle of the week says W T F
1963 15 window bus
1966 VW bug
1966 21 window micro bus
1969 Dune Buggy
1965 VW bug
1974 VW bug
1972 Kelmark, VW drive line
1948 Chevrolet Hearse |
vdubmyk Samba Member
Joined: October 24, 2008 Posts: 508 Location: Corona, CA
Posted: Sat Apr 18, 2020 10:35 am Post subject: Re: Who supplies black urethane bushes for 3/4'' front sway bar? |
Bringing up an old thread but has anyone come up with a black sway bar bushing for a 3/4 bar? Or has anyone found a regular rubber bushing that would work in this application? _________________ 64 stock bug, 12V (converted 6v unit), 40 hp, all documents even sales contract and dealer window sticker! |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3818 Location: Georgia
Posted: Sat Apr 18, 2020 12:36 pm Post subject: Re: Who supplies black urethane bushes for 3/4'' front sway bar? |
Buy black rubber bushings and drill the hole bigger. _________________ Volkswagen!
Let he that is without oil throw the first rod
(Compression 8.7:1) |
DeathRay64 Samba Member
Joined: February 03, 2019 Posts: 217 Location: Arizona
Posted: Wed Oct 05, 2022 9:11 pm Post subject: Re: Who supplies black urethane bushes for 3/4'' front sway bar? |
vdubmyk wrote: |
Bringing up an old thread but has anyone come up with a black sway bar bushing for a 3/4 bar? Or has anyone found a regular rubber bushing that would work in this application? |
I'm looking for the same thing. Maybe drilling is the way to go? I don't know how easy that's gonna go?
Why? , because I hate urethane, because when it fails, it breaks. Rubber failure is a much safer (slower) process.
But, rubber bushings for 3/4 sway bars might require a heavy duty higher durometer rubber.
Somebody should make these. _________________ Making VW's and America great again. |
wheel607 Samba Member
Posted: Thu Oct 06, 2022 1:46 am Post subject: Re: Who supplies black urethane bushes for 3/4'' front sway bar? |
I drilled out regular VW black bushings over 10 years ago. Took about 5 minutes. You all are overthinking this. |
Joined: May 17, 2003 Posts: 4863 Location: Harmony, PA
Posted: Thu Oct 06, 2022 5:41 pm Post subject: Re: Who supplies black urethane bushes for 3/4'' front sway bar? |
DeathRay64 wrote: |
.Why? , because I hate urethane, because when it fails, it breaks. Rubber failure is a much safer (slower) process. |
Only the shit urethane cracks/crumbles. The good stuff wears out just like standard rubber.
https://www.summitracing.com/search/brand/energy-s...or%3Ablack |
Posted: Thu Oct 06, 2022 7:28 pm Post subject: Re: Who supplies black urethane bushes for 3/4'' front sway bar? |
That's interesting, I'm not averse to having my mind changed. If you can share more about why you believe this I am open to your knowledge.
My personal experience with urethane is from seeing it fail in industrial applications not involving cars. After enough stress and time, the stuff just fractures.
It does look like Summit racing carries good quality bushings. _________________ Making VW's and America great again. |
Posted: Thu Oct 06, 2022 7:36 pm Post subject: Re: Who supplies black urethane bushes for 3/4'' front sway bar? |
wheel607 wrote: |
Thanks for that kick in the butt... I needed that. It's kinda fun fretting over every detail of this build, but sometimes I have been known to overthink things... LOL
I'm probably just gonna do this. _________________ Making VW's and America great again. |
Posted: Thu Oct 06, 2022 8:48 pm Post subject: Re: Who supplies black urethane bushes for 3/4'' front sway bar? |
DeathRay64 wrote: |
It does look like Summit racing carries good quality bushings. |
UV rays effect urethane. I have seen inexpensive poor quality urethane bushings on an open frame rail buggy disintegrate in a few years.
The Energy Suspension Urethane bushings for the sway bar on my 74 Super made it 22 years before the bar actually had movement within the bushing. I got a second kit, and simply did the sway bar bushings at first. 5 years later I did the ball joints in the arms, and put the arm bushings in from the remainder of the set. The old ones were tight, but were spongy, and no longer firm as you would expect urethane to be.
Which is the new one, and which is 27 years old with 70k+ miles on it?
