GratefulPhish Samba Member
Joined: July 20, 2020 Posts: 175 Location: Philadelphia
Posted: Wed Oct 05, 2022 6:41 pm Post subject: Fuel hose replacement suggestions |
Put all new fuel hoses in two years ago and had one burst on me today. I’m looking at the ones on the site below but don’t know the correct sizing. I have a stock ‘73. Need to replace the line from the wheel well where the fuel filter is back to the fuel pump. Appreciate it.
https://belmetric.com/search-result/?search_query=Fuel+hose
Last edited by GratefulPhish on Wed Oct 05, 2022 7:22 pm; edited 2 times in total |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Wed Oct 05, 2022 6:45 pm Post subject: Re: Fuel hose replacement suggestions |
GratefulPhish wrote: |
Put all new fuel hoses in two years ago and had one burst on me today. |
Let us know if this was German fabric covered fuel hose that burst, and where you bought it.
I've been more fortunate with fuel hose myself, and Arizona gas has 10 to 15% ethanol. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Wed Oct 05, 2022 6:46 pm Post subject: Re: Fuel hose replacement suggestions |
It was braided hose that I assume I got from jbugs but I can’t find an order confirmation from there. |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Thu Oct 06, 2022 12:51 am Post subject: Re: Fuel hose replacement suggestions |
That's the one you want.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
hulbyw Samba Member
Joined: April 24, 2021 Posts: 127 Location: Australia
Posted: Thu Oct 06, 2022 3:09 am Post subject: Re: Fuel hose replacement suggestions |
I always thought ACVW's used 5.5mm ID fuel hose. Am I incorrect? |
Ovally Samba Member
Posted: Thu Oct 06, 2022 3:51 am Post subject: Re: Fuel hose replacement suggestions |
hulbyw wrote: |
I always thought ACVW's used 5.5mm ID fuel hose. |
Correct.
Regards. _________________ VW Bug Oval 1953
VW Bug 1200 D motor
Porsche 911S MFI 1970
Mazda 929 Hardtop 1977
Mercedes SLC 180 Roadster 2018 |
Nicholas D Samba Member
Joined: November 06, 2012 Posts: 225 Location: Charleston, SC
Posted: Thu Oct 06, 2022 4:07 am Post subject: Re: Fuel hose replacement suggestions |
This line was suggested to me by Aeromech (he knows his stuff) over in the bay window forum and I've been running it without problem. It fits perfectly at 5.5mm ID
https://www.ebay.com/itm/Honda-Motorcycle-Fuel-Lin...0zvpz00004 _________________ 71 Westfalia
73 Beetle |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15987 Location: North Florida, USA
Posted: Thu Oct 06, 2022 7:35 am Post subject: Re: Fuel hose replacement suggestions |
Here's my $0.02....
5.5mm ID is the stock size fuel hose for cars that came with carburetors. FI cars upgraded to 7mm ID.
The 5mm ID hose linked above will work fine and is specifically rated for ethanol enhanced gasoline.
Either externally cloth braided or internally reinforced hoses are both fine. The external braided type is slightly better at handling abrasion.
Avoid "all rubber" hoses with no reinforcement. These should only be used for vacuum.
Ethanol (alcohol) will eat away OE rubber hoses not rated for ethanol. This happens when the fuel evaporates. Most/many locations around the US sell only E10, E15 or E85 gasoline blended with ethanol. Few locations still sell "Ethanol Free" gasoline. If you can only get ethanol enhanced gasoline you should be looking for hoses rated for use w/ alcohol/ethanol fuels... or plan to replace your hoses yearly.
If you always run your ACVW on "Ethanol Free" gasoline, use whatever fuel hose you like.
The Honda 5.5mm hoses are probably a better fit (size wise), but that eBay link does not indicate if the hose is rated for use w/ ethanol or not. Be wary.
Regardless of the hose size/type, install hose clamps on the ends of the hoses to ensure they don't vibrate loose. Yes, I know... VW did not use hose clamps, but they were cheap and trying to save $$ . You can afford to install clamps as insurance; making sure the hoses do not comes loose and start a fire. _________________ AshMan40
Cusser Samba Member
Posted: Thu Oct 06, 2022 1:48 pm Post subject: Re: Fuel hose replacement suggestions |
I'd be really surprised if most/all fuel hoses sold in USA these days would NOT be ethanol-resistant. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Thu Oct 06, 2022 5:00 pm Post subject: Re: Fuel hose replacement suggestions |
Ordered the braided 5mm, they didn’t have the 5.5. Appreciate all of the responses, this place surely is an amazing community. |
