SpLiTmEuP Samba Member
Joined: November 23, 2005 Posts: 11 Location: Vancouver Island, B.C. Canada
Posted: Sun Nov 19, 2006 8:54 pm Post subject: Split window hoods.. |
What is the difference between a 1950's hood and an Oval window hood..
Trying to purchase one and need to know if I have the right hood.
Thanks |
billmetric Samba Member
Joined: March 16, 2006 Posts: 1061 Location: Columbus City USA
Posted: Sun Nov 19, 2006 9:54 pm Post subject: |
ok, a split hood is going to have 3 mounting bolt holes on each hinge and another one for the prop arm on the drivers side, also will have a little triangle shaped reinforcement piece where the VW emblem goes, the reinforcement triangle went away in 1956 along with the extra bolt hole for the prop, I think they went to 2 bolt hinges in '53, in '56 the prop rod used the front bolt hole for the hinge, the VW emblem on a split hood has 3 mounting slots in a triangle and before '51 there was no provision for the Wolfsburg emblem above the handle, My standard '52 split has a 1950 deluxe hood on it, anyone have a '52 standard hood to trade me before I fill in the chrome holes? _________________ There is an idea of a Billmetric; some kind of abstraction. But there is no real me: only an entity, something illusory. And though I can hide my cold gaze, and you can shake my hand and feel flesh gripping yours and maybe you can even sense our lifestyles are probably comparable... I simply am not there... |
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9364 Location: Northwood, NH USA
Posted: Mon Nov 20, 2006 7:18 am Post subject: |
Also the bracing up near the windshield is smaller on a split hood. _________________ John Henry
'57 Deluxe
'56 Single Cab |
ovalslider Banned
Joined: August 16, 2004 Posts: 97 Location: Seattle, WA.
Posted: Mon Nov 20, 2006 10:28 pm Post subject: |
I have two split hoods with everything......
1. The triangle extra support for the emblem
2. The three bolt holes for the hinges.
3 The extra bolt hole for the hood support on drivers side. (making 4)
4. The two slots for badge by hood handle.
5. They both have holes downthe center for a chrome strip.
BUT....... 1. Has 4 tabs for VW emblem
2. Has 3 tabs for VW emblem
Both are also tabs not pins.
WHY THE DIFFERENCE? _________________ The world maybe round, but mine is oval.
Now it is split in two!
Zwitter 11G Deluxe Sunroof
57 Baja (not my doing)
60 Deluxe Bug
72 Ghia Vert |
ovalslider Banned
Posted: Tue Nov 21, 2006 2:57 pm Post subject: |
bump _________________ The world maybe round, but mine is oval.
60 Deluxe Bug
72 Ghia Vert |
Posted: Tue Nov 21, 2006 3:19 pm Post subject: |
ovalslider, sell me both of them and I will try to find out ...
I'm guessing one is newer than the other, maybe the 4 slot one is a Zwitter hood _________________ There is an idea of a Billmetric; some kind of abstraction. But there is no real me: only an entity, something illusory. And though I can hide my cold gaze, and you can shake my hand and feel flesh gripping yours and maybe you can even sense our lifestyles are probably comparable... I simply am not there... |
ovalslider Banned
Posted: Tue Nov 21, 2006 6:02 pm Post subject: |
I sure hope not. Because the 3 tab is my baby and I have a Zwitter that needs the hood. I am selling the 4 tab. I'm not sure wheter to be original and use the 3 tab that needs body work. Or save money and use the perfect non original hood? If either is so. _________________ The world maybe round, but mine is oval.
60 Deluxe Bug
72 Ghia Vert |
eurodub Samba Member
Posted: Sat Apr 03, 2010 11:59 am Post subject: |
since i checked the split fender threads here, i learned what was the difference between an oval, a split and a later fender.
i know this is a very old thread, but are there size differences between a split front hood and a later hood? and i am not referring to the earlier discussed checkpoints.
did anyone take measurements as width and length? any handle holes positioning difference between a split and a later front hood?
i have troubles making my 1960 4tab front hood close shut without having large gaps on the sides, and i began wondering whether the split hood is somewhat shorter or longer? i know i have an incorrect one and maybe that's why it's so difficult aligning it. _________________ 1960 1200 model 117 deluxe ragtop
1974 T2 Westfalia Campmobile
1976 MK1 Golf |
ZwitterND Samba Member
Joined: September 08, 2005 Posts: 1451 Location: Fargo, ND
Posted: Sat Apr 03, 2010 2:35 pm Post subject: |
I have noticed a lot of gaps, mostly on the hood prop side which I assume comes from metal fatigue from folks forgetting to release the prop first and/or from times it is left open (fuel, etc.). Who hasn't seen the infamous " I forgot to release the prop rod" hood rip . When you think of the size of the hood and fairly flimsy they are it's amazing how well they do fit after 50+ years. _________________ Bill |
Bohemian Wrecks Samba Member
Joined: August 18, 2003 Posts: 24 Location: california
Posted: Thu Sep 30, 2010 9:00 am Post subject: split hood |
HI
I have a split hood with two round holes just about the handle, not slots.
It has the triagle and the third prop hole too.
Anybody know what year this would be, are the two round holes original?
thanks |
Zwittercab53 Samba Member
Joined: October 22, 2010 Posts: 49 Location: Stockholm Sweden
Posted: Fri Dec 02, 2011 8:14 am Post subject: How long did VW use 3 pins for the front hood |
Picking up on an old thread. I'm trying to find out what is the correct hood for a Zwitter and if pre or post zwitter hoods can be used providing that the right handle and trim are put on.
Three bolts for the hinges must have been exchanges for the 2 hole version during 1953. I has seen a original zwitter from dec 52. the hood had 3 boltholes but it had 2 hole hinges mounted so it must have been on its way in dec 52.
Big question is when they changed from 3 to 4 pins for the VW emblem.
As far as I know all the 3 pins were solid and the 4 pins are all cut enabling the hood colour to be visible inside the emblem. |
Ferdinand53 Samba Member
Joined: December 20, 2015 Posts: 24 Location: Louisville
Posted: Sat Oct 01, 2022 5:28 pm Post subject: Re: Split window hoods.. |
I know this is an old thread but the split hood I have has the center chrome holes but no holes for the VW emblem is this a early hood? |
finster Samba Member
Joined: May 26, 2012 Posts: 7951 Location: north o' the border
Posted: Sun Oct 02, 2022 2:47 am Post subject: Re: Split window hoods.. |
it would increase your chances of an answer if you post photos showing the inside and outside of the vw badge area and also the hinge mounts _________________ "we're here on Earth to fart around" kurt vonnegut
nothing lasts, nothing is finished, and nothing is perfect... |
Robert Chambers Samba Member
Posted: Sun Oct 02, 2022 4:41 pm Post subject: Re: Split window hoods.. |
Ferdinand53 wrote: |
This could be a standard hood that had chrome added. _________________ '63 OG 117 Herbie Replica
'56 Euro Oval Deluxe
'52 Standard Zwitter
'63 OG 117 |
Mr. OGPaint Samba Member
Joined: September 24, 2010 Posts: 823 Location: Oregon
Posted: Thu Oct 06, 2022 5:39 am Post subject: Re: Split window hoods.. |
Are the chrome holes perfectly round? Factory holes are perfect, but 99.9% of drilled holes are not if the chrome has been added _________________ https://instagram.com/mr.ogpaint
Patrick Hall |
