Wino24 Samba Member
Joined: April 29, 2012 Posts: 36 Location: Long Island, NY
Posted: Thu Oct 06, 2022 11:42 am Post subject: Brake rebuild kit |
Hi all...any suggestions on where to obtain brake rebuild kits in terms of quality of the parts? They're for a '71 Beetle. Thanks _________________ '71 Standard Beetle |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
Posted: Thu Oct 06, 2022 11:46 am Post subject: Re: Brake rebuild kit |
Wino24 wrote: |
Hi all...any suggestions on where to obtain brake rebuild kits in terms of quality of the parts? They're for a '71 Beetle. Thanks |
I don't buy kits. I just replace the worn out parts. For stock parts I mostly use www.wolfsburgwest.com
But, all of my cars use the same brake parts so I keep a stock of one set of everything on the shelf. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Thu Oct 06, 2022 1:45 pm Post subject: Re: Brake rebuild kit |
I've been using Wagner Thermo Quiet brake shoes and pads on all my vehicles. Replacement hardware is readily obtainable. I use existing drums unless they are scored and need machining or replacing. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Wino24 Samba Member
Posted: Thu Oct 06, 2022 3:05 pm Post subject: Re: Brake rebuild kit |
The car has been sitting a while and I needed to put new tires on it. While I had tires off I pulled one of the drums off and after looking at it decided I better just replace all the brakes and associated items (wheel cylinders, master cylinder, etc...). That's why I'm looking to get a rebuild kit. _________________ '71 Standard Beetle |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6621 Location: Houston, Texas
Posted: Thu Oct 06, 2022 3:42 pm Post subject: Re: Brake rebuild kit |
You want to take your existing master and wheel cylinders and rebuild them or when you say kit do you want a kit with all new parts in it to replace everything you have? _________________ www.vwnos.com [email protected]
Wino24 Samba Member
Posted: Thu Oct 06, 2022 3:52 pm Post subject: Re: Brake rebuild kit |
I wanted to put all new in. _________________ '71 Standard Beetle |
Cusser Samba Member
Posted: Thu Oct 06, 2022 3:56 pm Post subject: Re: Brake rebuild kit |
Wino24 wrote: |
The car has been sitting a while and I needed to put new tires on it. While I had tires off I pulled one of the drums off and after looking at it decided I better just replace all the brakes and associated items (wheel cylinders, master cylinder, etc...). That's why I'm looking to get a rebuild kit. |
And get new flex hoses, wheel cylinders, master cylinder. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
heimlich VWNOS.com
Posted: Thu Oct 06, 2022 4:07 pm Post subject: Re: Brake rebuild kit |
You'll want to get the following if you have drums all the way around:
2 new wheel cylinders for the front
2 new wheel cylinders for the rear
New master cylinder
2 rubber lines for the front
2 rubber lines for the back
Hardware kit for each of the drums
New set of shoes
There are metal lines as well but those are usually good unless you have rust.
Pick your favorite supplier and order from there. _________________ www.vwnos.com [email protected]
Q-Dog Samba Member
Posted: Thu Oct 06, 2022 4:55 pm Post subject: Re: Brake rebuild kit |
Most of the aftermarket hardware (springs, retainers etc.) are junk. Retainer pins the wrong length, springs too soft or too hard or wrong length. Clean up and reuse the originals unless yours are missing. _________________ Brian
'69 Dune Buggy
'70 Beetle |
