shadetreemech Samba Member
Joined: October 05, 2005 Posts: 777 Location: Claremont, CA
Posted: Wed Oct 05, 2022 11:08 am Post subject: Re: What did YOU do to your van today? |
During the course of a rebuilt engine install, I passed the rear bumper numerous times on the way underneath the Van. Looked like it was time for a glamour touch up.
Browsed The Samba for info, didn't wanna do fiberglass, JB Weld it is.
Started off with some cracks, some fiber showing, coupla tabs missing, nothing major. Filled, filed and sanded, then a coat of gray primer, more filling, etc. Used rattle can Rustoleum Primer & Paint, more sanding. The problem with a job like this is that every time the last coat of paint dries you see a spot that you could sand a little off, fill in a little there, times infinity. At some point you have to say, "Good enough for who it's for". At least, that's what happened here.
Dan _________________ '84 GL 1.9
'01 Volvo V70 T5
'88 Westy - "MZDRTHY" |
indianpeaksjoe Samba Member
Posted: Wed Oct 05, 2022 3:10 pm Post subject: Re: What did YOU do to your van today? |
Ok I didn’t do this, I paid to have it done, the jobs were too big.
New van cafe oil pan and gowesty big brakes.
Joe |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Wed Oct 05, 2022 5:04 pm Post subject: Re: What did YOU do to your van today? |
Snugged CV bolts to 35ft/lb after putting on some miles after recently replacing all 4 joints.
Cleared plugged tranny vent (which may explain gear oil previously found in DS boot)…
Used exhaust heat wrap tape to <finally> quiet down nagging exhaust leak at #3 head…
Finally, verified trans oil level, prepped & packed for visit & weekend meetup in S. MN…
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Mckinleyvillian Samba Member
Joined: July 22, 2021 Posts: 506 Location: Macktown, CA
Posted: Thu Oct 06, 2022 10:42 am Post subject: Re: What did YOU do to your van today? |
Appear to have cured stalling at ocassional idle and while engaging power steering with $1 piece of hose and too many hours trying to figure out this beast. Stoked. _________________ so many roads i know
all i want is one to take me home
85 Vanagon GL 1.9 stick |
jlrftype7 Samba Member
Posted: Thu Oct 06, 2022 2:02 pm Post subject: Re: What did YOU do to your van today? |
Mckinleyvillian wrote: |
Appear to have cured stalling at ocassional idle and while engaging power steering with $1 piece of hose and too many hours trying to figure out this beast. Stoked. |
Where did the $1 piece of hose go... inquiring minds want to know... CrankCase Vent hose, or some hidden vacuum hose hiding near the Aux Air Valve.... _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
Posted: Thu Oct 06, 2022 5:32 pm Post subject: Re: What did YOU do to your van today? |
Replaced my broken original headlights with the GoWesty H4 ones.
And I noticed a drop of oil on my brand new van cafe oil pan drain plug. So i tightened it down to torque and did a little test spin. All signs point to it being fixed now.
Joe |
Posted: Thu Oct 06, 2022 9:35 pm Post subject: Re: What did YOU do to your van today? |
jlrftype7 wrote: |
Where did the $1 piece of hose go... inquiring minds want to know... CrankCase Vent hose, or some hidden vacuum hose hiding near the Aux Air Valve.... |
PO had done a number with certain things pertaining to lack of emissions, like running double muffler, no cat, no 02 sensor. They'd also removed the AC components in the engine bay. When removing AC components, they'd also removed the Y hose coming off the idle boost and AC boost (on 85 1.9, white boxes behind AFM) which connected to a T/hose coming off the intake manifold. Manifold T was capped and boost valve was left open. Ran short piece of vac hose off the T (the piece i got for a buck), fitting a smaller diameter piece (which I had) into it and connecting to the idle boost valve. working well for now.
regarding the Aux Air Valve, I had checked that and the curved, almost 90* piece of hard rubber down there was definitely cracked and for now that gap is filled with some silicone.
Perfect, no. but working and not stalling, yes. driving with WAY more power, yep _________________ so many roads i know
Posted: Fri Oct 07, 2022 5:30 am Post subject: Re: What did YOU do to your van today? |
jlrftype7 wrote: |
Perfect, no. but working and not stalling, yes. driving with WAY more power, yep |
Ah, I see. Congratulations on it running great and not stalling. That's sometimes a long battle to overcome as you get rid of old leaking parts. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
Posted: Sat Oct 08, 2022 6:25 pm Post subject: Re: What did YOU do to your van today? |
removed a sticky lifter, replaced said lifter, put back together. No compression. 2 whole lashes got me up to 120 and the lifter noise has stopped. _________________ so many roads i know
Kdj Samba Member
Joined: January 28, 2017 Posts: 142 Location: Naptown
Posted: Sun Oct 09, 2022 3:42 pm Post subject: Re: What did YOU do to your van today? |
Got rid of my brown dash. Think it turned out much better then I originally thought!
Socal Vip Samba Member
Posted: Sun Oct 09, 2022 8:05 pm Post subject: Re: What did YOU do to your van today? |
Today I finish my suspension project. First time installing suspension on a Vanagon. All parts removed are original 1987 parts. Will be doing alignment tomorrow but during my test drive, night and day difference. T3 technique Anti-Sway bar with T3 HD end link made a huge difference. Powerflex from T3, Schwenk Springs and Bilstein XHD from Gowesty. Also replace the powesterring rack bushing with Powerflex.
Robsmaze Samba Member
Posted: Sun Oct 09, 2022 9:12 pm Post subject: Re: What did YOU do to your van today? |
Removed cabinets and rear bench for the local VW specialist to replace panels, repair some pretty nasty rust and give her a new paint job.
Apparently the cabinets and rear seat haven’t been removed since the last ‘80’s because I found this gem:
Pretty certain the last time I saw don Johnson was 1988!
Here is the long shot of the removed equipment:
And an overview of the rusty destruction behind the cabinets:
_________________ ‘87 2WD 2.1L Westy
‘87 2WD 1.7L Diesel Doka (euro spec) |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4351 Location: United States, Iowa
Posted: Mon Oct 10, 2022 8:45 am Post subject: Re: What did YOU do to your van today? |
[Yesterday] I inspected my house battery charge wiring, found one a bit overheated looking, so I replaced it with nice fat wire and appropriate lugs. I'll keep an eye on it to see how it is looking.
Next, I fished a new supply +wire for house battery power to my over-the-slider white+red lights+2xUSB ports module that I have in the fresh air outlet.
Last, I tested the dash light that indicates low fluid level, by using turkey baster to remove a couple quarts of coolant from my aluminum expansion tank. Blinky light did the blinky thing like it should, test complete and coolant back into tank. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Kdj Samba Member
Posted: Tue Oct 11, 2022 4:41 pm Post subject: Re: What did YOU do to your van today? |
Loaded up to head to the New River for bridge day
Posted: Wed Oct 12, 2022 9:40 am Post subject: Re: What did YOU do to your van today? |
just here to state that the aux air valve on my 1.9 is a royal PITA. y'all know the drill. let's see how she does or doesn't stall today _________________ so many roads i know
brickster Samba Member
Joined: January 05, 2004 Posts: 512 Location: CO, USA
Posted: Wed Oct 12, 2022 4:10 pm Post subject: Re: What did YOU do to your van today? |
Low tire inspection revealed 2 screws. Plugged, inflated, ready to go..
Posted: Sat Oct 15, 2022 1:23 pm Post subject: Re: What did YOU do to your van today? |
I filled up my washer fluid for the first time, and it all poured out of the tank. New tank and gaskets and it all works.
Also I replaced my broken e brake cover.
blyhigh Samba Member
Joined: April 13, 2006 Posts: 121 Location: The Beaver State of Mind
Posted: Sat Oct 15, 2022 7:17 pm Post subject: Re: What did YOU do to your van today? |
303'ed my CV joint boots _________________ '89 Syncro Westy |
Posted: Sun Oct 16, 2022 4:11 pm Post subject: Re: What did YOU do to your van today? |
On the '87, I finally got the ONE WIRE pulled to move my cockpit accessories over to the House Battery. How come it took me two hours today, as well as 23 months since I put the House Battery in to do it? Ugh!
Just in case, I puled three wires. I don't want to be lacking if/when I decide to run more connections from cockpit to cabin! All tucked in under the carpet and front heater housing cover. Nothing to see here. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
SlalomVan Samba Member
Joined: March 28, 2006 Posts: 127 Location: Seattle, WA
Posted: Fri Oct 21, 2022 3:00 pm Post subject: Re: What did YOU do to your van today? |
Put these wheels and tires on the "project" van. Much better!
Build thread coming soon detailing the work done slowly over the last two years to get the "project" out of a barn and back on the road. _________________ 1989 Vanagon GL - 2.1 (White - "Northlake" Totaled/Gone)
1988 Vanagon GL Wolfsburg (Orly Blue - "Poulsbo" - Sold)
1989 Vanagon G - 2.1 (White - "Kingston") - Full rebuild underway - Last on the road in 1997 |
