VW_Type181 Samba Member
Joined: October 26, 2022 Posts: 6 Location: Bakersfield
Posted: Wed Oct 26, 2022 9:05 pm Post subject: 71 Thing Swing Axle Lift |
I recently purchased his 71 Thing. It came with a swing axle rear suspension and no reduction boxes. This caused the rear end to sit lower and the wheels are set in to far in. I would like to raise the rear suspension up 2 to 3 inches to level up the vehicle and push the tires outward so they are in line with the front tires. What’s the best way to accomplish this?
Do I add back the reduction boxes, install adjustable spring plates, or adjust existing spring plates, or is there a better option out there? Longer axles or spacers?
FJBLF Samba Member
Posted: Thu Oct 27, 2022 4:26 pm Post subject: Re: 71 Thing Swing Axle Lift |
I would add back the GRB's. It is the original set up for your car anyways.
I have a '72, most 181's are CVJ... we are few and far in between from the first gen.
Here you have a video of when I rebuild mine. I hope you find it useful.
Please follow and like my chanel
_________________ 1972 VW 181 SAFARI 1500 cc GRB Trans-axle |
Bryan67 Samba Member
Joined: January 01, 2003 Posts: 2940 Location: Fresno, Ca.
Posted: Thu Oct 27, 2022 7:33 pm Post subject: Re: 71 Thing Swing Axle Lift |
Don`t forget that if you just add reduction boxes to your existing transaxle, You will have four reverse gears and one forward. You need to flip the ring and pinion as well. _________________ If you`re going to do something, do it right. |
Posted: Thu Oct 27, 2022 8:29 pm Post subject: Re: 71 Thing Swing Axle Lift |
Thanks Bryan67, great video. Did you put in a freeway flyer and what size engine did you install. How’s your speed with the GRB’s? One last question, are Thing’s GRB’s the same as buses or do I need to find thing only? |
Posted: Fri Oct 28, 2022 8:32 am Post subject: Re: 71 Thing Swing Axle Lift |
VW_Type181 wrote: |
You got me mixed up with FJBLE _________________ If you`re going to do something, do it right. |
FJBLF Samba Member
Posted: Fri Oct 28, 2022 5:10 pm Post subject: Re: 71 Thing Swing Axle Lift |
VW_Type181 wrote: |
It is the same original gear ratio that came with it, just replaced the worn parts.
The 181 GRBs part number starts with 181, which means it is 181 exclusive, but it is very simmilar to a 36mm GRB set up from a Bus.
The comment above is correct, if you add GRB's to your current Gearbox you'll end with 4 reverses and one forward... to make it work you have to swap the differential to the other side.
Your best bet is to get a "Small Nut" 36mm bus transimision (Drum to Drum) and mount that.
I hope that helps. _________________ 1972 VW 181 SAFARI 1500 cc GRB Trans-axle |
Posted: Fri Oct 28, 2022 7:53 pm Post subject: Re: 71 Thing Swing Axle Lift |
FJBLF Thanks for the info, it’s a big help. Time to start searching for some GRBs |
FJBLF Samba Member
Posted: Sat Oct 29, 2022 4:09 pm Post subject: Re: 71 Thing Swing Axle Lift |
VW_Type181 wrote: |
Search the parts clasifieds for the split window Bus, 50 to 63 Bus, You are looking for a Drum to Drum 36MM (Small Nut) transaxle. If I was on your place I would have it sent to these guys to have it rebuilt for you,
then is just a matter of mounting it.
Those guys can also make the "Freeway Flyer" mod you were asking for
https://ranchotransaxles.com/ _________________ 1972 VW 181 SAFARI 1500 cc GRB Trans-axle |
