kguarnotta  Samba Member
Joined: April 01, 2004 Posts: 1060 Location: Woodstock, NH
Posted: Fri Nov 25, 2022 1:48 pm Post subject: 12V accessory outlet - best quality? |
My Vanagon has had 2 backlit accessory outlets (I used to call them cigarette lighter outlets)
They worked ok - it was nice that the ring around them lit up when I turned my lights on. They just started giving me issues again - they are kind of junky quality, and the lights don't always work. I want to replace them, but don't want to buy more junky quality.
Things I like about the ones I have - they are backlit, to disconnect, and they are threaded in to install.
Does anyone know who makes a good quality one? Is the Go-westy one nicely made?
https://gowesty.com/products/illuminated-lighter-assembly-2
It look like theirs's is a snap in model, and you just install once. But if you have to take them out - you need to sort of break them? Maybe that is a better system?
Also - should I give up on that 12V outlet and just go for the USB adapters - https://www.amazon.com/Outlet-Automatic-Laptop-Cha...&psc=1 _________________ -Kevin
Woodstock, NH
'86 Triple Knob Syncro w/EJ22
'78 Westy
'69 Single Cab
'65 Kombi - EZ-Camper |
djkeev  Samba Moderator
Joined: September 30, 2007 Posts: 30686 Location: Reading Pennsylvania
Posted: Fri Nov 25, 2022 2:08 pm Post subject: Re: 12V accessory outlet - best quality? |
ok- I know Blue Sea - I heard they make good quality stuff. But I don't see on that has a light on it. The only one I see that lights up when you turn your headlights on - is the go westy one.
Otherwise they have a switch on them - to light up and power up when you turn them on.
I like that the ones I currently have provide charging power as long as the engine is on, and light up as long as the headlights are on.
Then again - the more I think about it, I could probably forego lighting up when I turn headlights on - I just think that looks cool - but realistically - I basically leave my phone charger plugged in all the time, so I don't need to see that outlet when it is dark out. _________________ -Kevin
Woodstock, NH
'78 Westy
'69 Single Cab
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2515 Location: North Carolina
bobhill8  Samba Member
Posted: Fri Nov 25, 2022 2:27 pm Post subject: Re: 12V accessory outlet - best quality? |
I would go with BlueSea - it's known good quality. _________________ 1986 Westy
1971 Squareback |
Posted: Fri Nov 25, 2022 2:44 pm Post subject: Re: 12V accessory outlet - best quality? |
That NAPA one looks like what I'm looking for - anyone know the quality?
And has anyone given up on these, and just gone the route of installing a USB outlet? Maybe that is more forward thinking, I'm just wondering if there is a reason not to just get the USB outlets... _________________ -Kevin
Woodstock, NH
'78 Westy
'69 Single Cab
fxr Samba Member
Joined: December 07, 2014 Posts: 2031 Location: Bay area CA
Posted: Fri Nov 25, 2022 3:11 pm Post subject: Re: 12V accessory outlet - best quality? |
I changed all mine to either Anderson Pole connectors or USB outlets. No more dodgy connections! This is not the cheapest option, but if you have quite a few 12V things to plug in (compressors, fridges, vacuum cleaners, whatever) then they make very good sense. _________________ Jim Crowther
Vespa GTS 300 |
Posted: Fri Nov 25, 2022 3:32 pm Post subject: Re: 12V accessory outlet - best quality? |
So far- I basically just have cell phone chargers, or headset chargers, sometimes I charge a tablet - but that is pretty rare. _________________ -Kevin
Woodstock, NH
'78 Westy
'69 Single Cab
Sodo Samba Member
Joined: July 06, 2007 Posts: 8130 Location: Western WA
Posted: Fri Nov 25, 2022 3:52 pm Post subject: Re: 12V accessory outlet - best quality? |
kguarnotta wrote: |
should I give up on that 12V outlet and just go for the USB adapters? |
Yes. When you hit the cig-lighter adapter wall, it’s “over”.
No need for a gangly mess of wires that flicker when you go over railroad tracks.
USB + USB-C + voltmeter in the Cig Lighter hole (how-to w/pics)
If you slide the passenger seat off the rails (much more difficult with a westy swivel but possible), there's a great place to put a "legacy" cigarette lighter socket.
The socket would be behind the passenger's legs, the hole facing forward.
Near the top, almost to the seat.
Very easy access to the battery.
In the dash is no longer a good place, now the phones plug in there.
Put the cig-socket somewhere else.
A 12v crock pot is a good reason to keep a legacy cig-lighter socket.
This is one of my favorite new toys.
You can stop at the supermarket and get a frozen lasagne, or a Chicken pot pie.
Put it in the crockpot (frozen), keep on truckin',
and in 45 mins or an hour you have a nice hot dinner. _________________
two vans:'90 Westy with '07 EJ25 '12 longblock, Peloquin TDB+locker, pressure oiled transaxle with cooler & filtration. 150Ah LiFePO
'87 Tintop with 43k strange miles, '12 smallcar EJ25,
....KTMs, GasGas, and a Stumpjumper |
Timwhy Samba Member
Posted: Sat Nov 26, 2022 5:17 am Post subject: Re: 12V accessory outlet - best quality? |
I love the idea of a warm blueberry pie upon reaching my destination (at least that is what that picture looks like). I never imagined hooking up a slow cooker to a lighter outlet in my van - I figured that would draw way too much, but never actually looked into it.
DAve - that is what I was wondering - then again a lot of these adaptors/charger things are only about $10-$20. I already have the 2 holes in my dash from a previous owner (or maybe one was originally there?)
I notice almost all of these outlets just have two electrical connectors - so they lighting part of it is not wired with the interior lights (which is a feature I like, but is not really necessary)
I think I may just go with one of these - https://www.amazon.com/gp/product/B08SQCBC2C/ref=ox_sc_act_title_3?smid=A3IBRCMNGJUPVG&psc=1
It has USB A and USB C. I think if I got the one with a switch - I'm sure I'd forget to turn it on (and not charge my phone) or forget to turn it off (and kill my battery). This one is simpler - no light, but I can live with that.
I like the suggestions of alternate locations - and that is on my list of upgrades - but for now, I just want to get my phone charger working, and the hole in my dash plugged...
thanks for the feedback. _________________ -Kevin
Woodstock, NH
'78 Westy
'69 Single Cab
jlrftype7 Samba Member
Posted: Sat Nov 26, 2022 7:22 am Post subject: Re: 12V accessory outlet - best quality? |
djkeev wrote: |
When I redid my 86 "weekender" I installed several lighter sockets at the rear seat locations.
I then got adapters to USB for them.
This worked out great for travel with the Grandkids and their various electronics that seem to always need charging.
I at that time saw the lighter socket to be more versatile, you could keep up with future changes simply buy purchasing new adapter plugs.
I'm not clear why one needs lit outlets. My PO put in a USB plug in place of the stock lighter on my 90, I find the constant glow annoying.
Rarely am I ever in a location that it is SO DARK with no ambient lighting at all.
Besides, just by instinct and feel, I know where things are inside the Van.
Dave |
I just bought a ‘lighter adapter’ that has both USB A and C ports on it for the very reason you mentioned Dave, the cords ‘are a changing’…
It’s easier than swapping our existing USB A ports out for now to have have a new dedicated C port.
The only thing I would add about that NAPA outlet that’s linked, make sure the access to that probable tiny incandescent bulb is easy to do. You”ll be changing it at some point sooner than later if you can’t put an LED bulb in its place during installation. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
Posted: Sat Nov 26, 2022 7:36 am Post subject: Re: 12V accessory outlet - best quality? |
Hey sodo - I understand this is off topic - but what kind of slow cooker/crock pot did you get?
When I looked online - I only found one by Roadpro that did not get very good reviews... _________________ -Kevin
Woodstock, NH
'78 Westy
'69 Single Cab
Gnarlodious  Samba Member
Joined: September 28, 2013 Posts: 2197 Location: Adobe Jungle USA
Posted: Sat Nov 26, 2022 7:49 am Post subject: Re: 12V accessory outlet - best quality? |
Three types. Anderson Powerpoles all around for high current devices like electric blankets and the fridge. Plus two of the old style cig lighter sockets for legacy devices. Plus barrel socket 2.1 x 5.5mm outlets for low current like lighting. Several have remote control switches which is pretty convenient.
NOTE on PowerPoles: do NOT fall for cheap imitations sold on eBay, they may not be cross compatible with the real thing! _________________ Vanagon ’83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD. |
shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3331 Location: VA/TN
Posted: Sat Nov 26, 2022 8:03 am Post subject: Re: 12V accessory outlet - best quality? |
Blue seas. Marine quality. Lifetime warranty. Especially on USB charging. Yeah we are converting to USB C but there are USB A to USB C cables. _________________ Brandon
'83.5 Westfalia "Jo Ann" EJ22e w/Peloquin
150aH LiFePo4, 330w solar, diesel heater
DM me on IG for quicker responses @brandon.r2 |
kamzcab86 Samba Moderator
Posted: Sat Nov 26, 2022 9:11 am Post subject: Re: 12V accessory outlet - best quality? |
Blue Sea dual USB socket in the dash.
Blue Sea dual USB socket in the kitchen near the drawer (replaced a PO's 12V socket).
Uniwerks 12V socket and lighted USB socket (switched) in the back (replaced fridge vent).
I've only used the 12V socket once since installing it. About 99% of my electronics use USB cords (GPS, phone, tablet, two-way radios, etc.). _________________ ~Kamz
2016 Golf GTI S
"I fear the day that technology will surpass our human interaction; the world will have a generation of idiots." ~Albert Einstein |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5391 Location: Manhattan, Kansas, USA
Sodo Samba Member
Posted: Sat Nov 26, 2022 10:01 am Post subject: Re: 12V accessory outlet - best quality? |
On plugging the hole in the dash, it couldn't be easier. $14 and crimp two spade terminals and it plugs right into your OEM socket. We're talking 10 minutes install. They are fairly easy to upgrade later, or if the $14 unit doesn't last.
SOME of them require that you enlarge the dash hole a little and some do not. Amazingly, many of the sellers are secretive about the "hole size", providing all other dimensions, so it looks complete, but omitting the hole size. The USB socket I used here was same-size as your OEM cig-lighter hole (1 1/8" or 1.12" or 28mm).
If you choose a higher power unit (like 48watt or 60 watt) I think you should choose an aluminum-bodied unit so it can cool by conducting heat to the metal dash.
But if just charging a phone, 30 watts is currently considered fast-charge!
Fast-charge is real handy those times when you 'need it'.
I'd go with the switch so you can turn it off. When camping, if you are enjoying the 'real dark' you will find the LED to be 'real friggin' bright'. I found the little plastic snap-on cover to be 'in the way' too often and cut it off. You will learn within a couple cycles that when the light is on, it's gonna charge. and when the light was off, it didn't. I like to have at least one of the sockets have a voltmeter.
kguarnotta wrote: |
I love the idea of a warm blueberry pie upon reaching my destination |
The one I got is 60 watts, it's about the same as one headlight bulb. I've seen 40 watt units too. I think 60 is just right. 45 minutes from frozen to lightly sizzling is no time at all during a roadtrip. It fills the van with "aroma". Blueberry pie, is a pleasant aroma. To me, the aroma of Lasagna was pleasant when I was hungry. Heavy garlic can be risky, and I'm prob not gonna test warming fish.
The crockpot was $33 on Amazon here (now $26) It's ultra-cheapo and one of the four plastic latches has broken, but it still works just fine. You can remove the stainless tub to wash it. I can't complain for this intro to 'the roadtrippin' method' (that long-distance truckers have known for years). I'm so happy with "the method" and 60watts, I'd like to find a high quality unit.
Search "12v lunchbox" or "12v oven". There are several that are a hot-plate that heats "your own casserole dish" which could be a better method because you can use glass casserole dishes from home. And perhaps prepare entres, freeze, and put them in the van fridge. But the total cost is less than one 2022 restaurant meal, it's not an expenditure to fuss about. Unless it fails mid-trip and leaves you wanting. We also got a 12v kettle (for water) to boil water for tea while driving, that's been nice too. Now all we need is another roadtrip.
Anyway, that's a reason to retain a legacy cig-lighter socket. _________________
