Quick Towing Question - 1965
DesertG
DesertG is offline
PostPosted: Sun Nov 27, 2022 5:09 pm    Post subject: Quick Towing Question - 1965 Reply with quote
Hi Guys, I am going to most likely buy a stock height 1965 Beetle. Will this drive onto a Uhaul car hauler (not the dolly) without issues. I assume pull the car on nose first. Anything else I should know. Thank you
https://www.uhaul.com/Trailers/Auto-Transport-Rental/AT/
AirHead1966
AirHead1966 is offline
PostPosted: Sun Nov 27, 2022 5:48 pm    Post subject: Re: Quick Towing Question - 1965 Reply with quote
Without a problem.
DesertG
DesertG is offline
PostPosted: Sun Nov 27, 2022 6:24 pm    Post subject: Re: Quick Towing Question - 1965 Reply with quote
AirHead1966 wrote:
Without a problem.
Thank you. Can you tell me where you attached the front and rear chains that come with that trailer.
AirHead1966
PostPosted: Sun Nov 27, 2022 6:41 pm    Post subject: Re: Quick Towing Question - 1965 Reply with quote
I made sure that the ratchet straps were tight around the tires. Those are the main holding points. The chains are backup safety. I put the chains around the front beam and and rear torsion bars.
The car is narrow but it fits the ramps and the platform. Just have someone guide you on and off carefully. I transported it on the pictured uhaul trailer for over 150 miles without any issues.
DesertG
DesertG is offline
PostPosted: Sun Nov 27, 2022 6:43 pm    Post subject: Re: Quick Towing Question - 1965 Reply with quote
Thank you Sir. I think I want to check the lug nuts. Are they really 12mm? Do you know the torque spec.
AirHead1966
PostPosted: Sun Nov 27, 2022 6:46 pm    Post subject: Re: Quick Towing Question - 1965 Reply with quote
12x1.5 bolts, not nuts. I torque mine to 73 ft-lbs.
DesertG
DesertG is offline
PostPosted: Sun Nov 27, 2022 6:48 pm    Post subject: Re: Quick Towing Question - 1965 Reply with quote
Thank you. Hopefully this car is exactly like the owner says... Very Happy
bigdog1962
bigdog1962 is offline
PostPosted: Mon Nov 28, 2022 5:33 am    Post subject: Re: Quick Towing Question - 1965 Reply with quote
^^^This.
And mine shifted during transport on the rails. Had to get a couple of people to shove it back closer to center at the end of the trip.
I bought a tow bar - I'm not using the Uhaul trailer any more.
Oprn wrote: I'm getting to the age that any self propelled woman (no wheel chair or walker) looks HOT!! Oooo! look at that Babe! She made it from the dining room all the way to the TV room without help!! Hubba, hubba!!
AirHead1966
PostPosted: Mon Nov 28, 2022 7:56 am    Post subject: Re: Quick Towing Question - 1965 Reply with quote
How did it shift? The front of the trailer has wheel chocks, and the tires butt up against them and get pressed against them using the ratcheting straps. They should remain locked rock solid if strapped properly. The chains are just secondary safety, the straps lock the car in place.
Pruneman99
Pruneman99 is offline
PostPosted: Mon Nov 28, 2022 9:16 am    Post subject: Re: Quick Towing Question - 1965 Reply with quote
I've used the Uhaul trailer once. The track is a bit narrow for a bug, but it still fits. Just use a spotter as someone else suggested.
I didn't have any issues with the car moving at all. I'm pretty meticulous about using the straps, and using extra chains or straps.
aa390392
aa390392 is offline
PostPosted: Mon Nov 28, 2022 10:21 am    Post subject: Re: Quick Towing Question - 1965 Reply with quote
Buy a VW tow bar,,,in n out in 5 mins.
Have hauled many a cars many a miles, not 1 issue.
No drama.
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet
finster
finster is offline
PostPosted: Mon Nov 28, 2022 10:25 am    Post subject: Re: Quick Towing Question - 1965 Reply with quote
No drama.
that's assuming the tyres/bearings are up to the job....
Mike Fisher
Mike Fisher is offline
PostPosted: Mon Nov 28, 2022 11:16 am    Post subject: Re: Quick Towing Question - 1965 Reply with quote
I bought a used tow dolly for everything I tow.
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
hitest
hitest is offline
PostPosted: Mon Nov 28, 2022 11:36 am    Post subject: Re: Quick Towing Question - 1965 Reply with quote
With the U-haul trailer, go ahead and add a couple of your own ratchet straps (maybe cross them) from the torsion tubes to somewhere on the trailer- just to reduced the chance of it crab walking a little over rough roads. Small stock tires have very little practical gripping contact with the trailer rails.
Bigdog1962 and I have had similar experience I think.
FU#5
bigdog1962
PostPosted: Mon Nov 28, 2022 12:19 pm    Post subject: Re: Quick Towing Question - 1965 Reply with quote
AirHead1966 wrote:
How did it shift?
I had it ratcheted down and chocked but after 3 hours on the road and time to get it off, it was not a straight back down the ramp job. And there is no room to turn the wheel.
I like Hitest's description - crab walk.
With the rails being so narrow, any sift can make it much more difficult to get off the trailer. It can be done but I decided to not use a Uhaul trailer any more as I can't always depend on there being help to unload it.
