skemems Samba Member
Joined: February 23, 2017 Posts: 207 Location: Portland
Posted: Tue Aug 16, 2022 6:51 pm Post subject: Another build - 1987 Westy |
Thought I would share another build on "saving" a van that was in rough condition.
My father purchased this vehicle so we can have a "project" to work on. He already owns an 86 Westy that I have helped him build. We are both very familiar with Vanagons as we have owned numerous between the both of us.
Van was purchased in the state of NY and shipped to Oregon.
Previous owner gutted the entire vehicle - interior and exterior. Project is near completion and will post pics/process as I go through some of the pictures.
Here is how it started.
Gutted from the interior, but came with the complete interior. Original 2.1 engine taken out and sitting inside.
_________________ 87 VW Westfalia - EJ25
86 VW Westfalia - EJ22
85 VW Westfalia - WBX 2.1 project |
campism Samba Member
Joined: September 07, 2007 Posts: 4492 Location: Richmond VA
Posted: Wed Aug 17, 2022 4:32 am Post subject: Re: Another build - 1987 Westy |
Looks like a challenging project. Keep us posted and good luck! _________________ '87 Westy in Wolfram Grey Metallic |
DuncanS Samba Member
Posted: Wed Aug 17, 2022 5:54 am Post subject: Re: Another build - 1987 Westy |
It's a blank stretched and gessoed canvas. Go paint the next Mona Lisa.
Duncan |
joetiger Samba Member
Joined: January 27, 2005 Posts: 5078 Location: denver
Posted: Wed Aug 17, 2022 5:57 am Post subject: Re: Another build - 1987 Westy |
_________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
Available Now! Vanagon to Louisiana--A Two-Lane Reckoning Through Past and Present
www.josephtrussell.com |
Posted: Wed Aug 17, 2022 6:33 pm Post subject: Re: Another build - 1987 Westy |
No surprise here, common rust spots. Several more were found later as windows were removed and body work started.
Posted: Sat Aug 20, 2022 8:16 am Post subject: Re: Another build - 1987 Westy |
Since the interior was already gutted it was a good opportunity to add sound deadener to the interior panels and fix the some common rust behind the sink.
At the same time while debating if I should rebuild the original 2.1 that was sitting on the floor board or go with a conversion. I came up on a good donor vehicle (2003 Legacy) in a recent accident. Decided to go this route instead.
Besides the condition of the 2.1 was unknown.
Posted: Sat Aug 20, 2022 9:46 am Post subject: Re: Another build - 1987 Westy |
I dont know much about body work, but have a good friend who works at a body shop and for trade work he did all the prep work.
Posted: Wed Aug 24, 2022 9:23 am Post subject: Re: Another build - 1987 Westy |
While body work is getting done. I started working on pulling motor and harness from donor subaru.
Also decided to go with small car bellhousing, headers and engine mount. I used the same setup on my dads conversion and has worked well (over 40k-50k on that conversion).
Body on this westy had 125k miles and tranny plug shows minimal wear.
Preping engine bay for paint as well.
valvecovergasket Samba Member
Posted: Wed Aug 24, 2022 10:52 am Post subject: Re: Another build - 1987 Westy |
next level west coast difficulty starting with an east coast van
in for more updates! _________________ MegaSquirt resource - SpitfireEFI.com
gone, but not forgotten: '83 tdi westy - swap thread |
Posted: Wed Aug 24, 2022 11:19 am Post subject: Re: Another build - 1987 Westy |
valvecovergasket wrote: |
It had factory underspray - so there was minimal rust on underside.
After several weeks, I brought back home from the paint booth (final cut and buff not done yet)
Also removed the top during body work prep and paint, and cleaned it while it was removed, a new tent was also installed.
Posted: Wed Nov 30, 2022 11:03 am Post subject: Re: Another build - 1987 Westy |
I haven't updated this thread in a while. Thought I would continue to post some of the previous progress pics as I go through them.
Installed new fuel tank, upper control arm bushings - LEMFOERDER brand- I had a set one hand from a previous build that I ended up using the GW kit on that one. And as I was purchasing parts for the subaru conversion, I came across and article on BurleyMotor sports website were they DONT recommend urethane bushing on upper control arms for some reason.
(https://burleymotorsports.net/technical-articles/the-making-of-burley-bushings/)
I personally have not had any issues with urethane bushings, but since I already had some lemfoerders on hand I just went with those.
Posted: Wed Nov 30, 2022 11:05 am Post subject: Re: Another build - 1987 Westy |
Next up was moving forward with suby 2.5 engine install.
vino de vano Samba Member
Joined: September 10, 2016 Posts: 359 Location: columbia gorge
Posted: Wed Nov 30, 2022 2:56 pm Post subject: Re: Another build - 1987 Westy |
Looking goooood _________________ what a long strange trip it's been |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9615 Location: Western WA
Posted: Wed Nov 30, 2022 3:44 pm Post subject: Re: Another build - 1987 Westy |
How about the clutch pedal mod for that smallcar bellhousing? _________________
....KTMs, GasGas, SPOT mtb |
Posted: Wed Nov 30, 2022 5:46 pm Post subject: Re: Another build - 1987 Westy |
Sodo wrote: |
How about the clutch pedal mod for that smallcar bellhousing? |
I just used the clutch spacer smallcar provides, its been working fine and personally dont mind the clutch feel.
Did you ever get your issue resolved? I remember your post below that it still overextended the slave.
(https://www.thesamba.com/vw/forum/viewtopic.php?t=770212&postdays=0&postorder=asc&start=6) _________________ 87 VW Westfalia - EJ25
Sodo Samba Member
Posted: Wed Nov 30, 2022 11:36 pm Post subject: Re: Another build - 1987 Westy |
skemems wrote: |
Sodo wrote: |
(https://www.thesamba.com/vw/forum/viewtopic.php?t=770212&postdays=0&postorder=asc&start=6) |
I think it overextended the slave because the clutch disc was new and the pressure-plate fingers start 'farther in' which means the slave 'start point' is 'farther out'. And then a proper 'amount' of fluid can over-extend the slave.
Whereas on my other van, the clutch disc was 40,000 miles old.
So the old clutch disc did not need the spacer.
But on the other van (new clutch) the new disc is thicker so it needs the spacer.
You can bet I'm putting the spacer on the old van now!
Does this make sense?
The spacer still limits the amount of fluid.
But the pedal modulates much better within that stroke.
If your clutch pedal clevis pin is worn, you have to address that someday and can drill a new hole at that time?
SOMEDAY I will measure the volumes and see if there is a pedal-pivot offset that truly eliminates the spacer.
And that would result in the softest, smoothest clutch action there is.👍🏽🙏🏽
Here is a related problem I worked on with someone else, but I can't recall who it was or what forum.
I think the guy installed a disc that was too thick and it caused the slave to over-extend.
To make sense of this you have to 'read it in the sequence' of the circled numbers.
If the disc is too thick, it can set the diaphagm spring on the pressure plate too far 'down' which in turn causes the slave start position to be too far extended.
Where a normal amount of fluid drives the slave past its limit.
So the takeaway here is, for the concentric slave/bearing, do NOT use a disc that's too thick.
What we need is a "pressure plate finger depth measurement" that ensures the slave won't be over-extended.
I hope this is understood.
It's not easy to type this problem with clarity.
The key is --- the slave bearing riding on the pressure plate fingers is 'the start point' of the slave cylinder extension.
If it starts too far extended, it will be driven past the stops. _________________
jimf909 Samba Member
Posted: Thu Dec 01, 2022 6:19 am Post subject: Re: Another build - 1987 Westy |
skemems wrote: |
I haven't updated this thread in a while. |
Holy Toledo, this looks like a fun project. Am I seeing correctly that this is a total repaint from Pastel White to Flash Silver Metallic? Savannah Beige Metallic? Something else?
_________________ - Jim
Abscate wrote: |
Posted: Thu Dec 01, 2022 3:34 pm Post subject: Re: Another build - 1987 Westy |
Sodo wrote: |
Completely, thanks.
Sodo wrote: |
Yes thats the plan.
Sodo wrote: |
Yes, let us know when you do. This allow to test the redrill of the clevis to ensure correct fluid volume. _________________ 87 VW Westfalia - EJ25
Posted: Thu Dec 01, 2022 3:38 pm Post subject: Re: Another build - 1987 Westy |
jimf909 wrote: |
skemems wrote: |
Respray of original Flash Silver Metallic. When purchased it had primer, so I kept original color. Didn’t want to deal with respraying interior, plus I really like Flash Silver Metallic.
Posted: Thu Dec 01, 2022 4:02 pm Post subject: Re: Another build - 1987 Westy |
Had a Silver Flash. My favorite color.
Duncan |
