Wendle Willkie Samba Member
Posted: Sat Nov 26, 2022 6:44 pm Post subject: heater tube connection |
when you're using a header- on an as 41 case 1600 single port engine with a dog house shroud- would you run the tube straight from the heater box to the shroud? |
mikeonthebike Samba Member
Joined: December 08, 2012 Posts: 953 Location: Sacramento, CA
Posted: Sat Nov 26, 2022 6:53 pm Post subject: Re: heater tube connection |
I do on mine because I don't have a stock muffler. I have a tri mil.
I think the stock mufflers have a connector pipe to go through the tin.
I have a dual port motor |
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4421 Location: Stuck in Ohio
Posted: Sat Nov 26, 2022 9:51 pm Post subject: Re: heater tube connection |
excellent! |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Sun Nov 27, 2022 6:48 am Post subject: Re: heater tube connection |
Stainless steel,
A little trimming and bending to get them in place,
Then added the SS FS tubes to the lower SS heater box connectors,
The SS tubes don't deform, crush, or burn through.
They really never need replacement. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Sun Nov 27, 2022 9:36 pm Post subject: Re: heater tube connection |
Super Tuff! |
stewartsoda Samba Member
Joined: February 03, 2020 Posts: 88 Location: Treasure Valley, ID
Posted: Mon Nov 28, 2022 9:50 am Post subject: Re: heater tube connection |
I just put a set of those CSP extensions on my Bug and they are AWESOME.
I also noticed my aluminum flex hoses had worn holes in themselves where they went through the shroud. The extensions will solve that problem. _________________ 1972 Super Build |
Rickf1985 Samba Member
Posted: Tue Nov 29, 2022 7:56 am Post subject: Re: heater tube connection |
Can I get a little more info or links to the CSP connectors and tubing? |
jinx758 Samba Member
Posted: Tue Nov 29, 2022 5:10 pm Post subject: Re: heater tube connection |
Those are nice looking.
Technically (from the factory) there was a grommet on the hole in the breastplate tin. It is available but I used two lengths of 4mm vacuum hose, slit down the length.
Worked a treat !
Good luck ... stay safe
jinx _________________ " It's not valuable unless you learn something from an experience. " Henry Ford
It's not unlike the same difference
You can't push a rope
VALVES (cold)
POINTS
TIMING
CARB (fully warmed engine)
SCRAPE ALL GROUNDS
My Craigslist rescued 100 footer :
1971 Standard Bug
1776cc dual port
034 distributor
38mm EGAS Carburetor |
Maddel Samba Member
Posted: Wed Nov 30, 2022 7:56 am Post subject: Re: heater tube connection |
Thanks for the link. I did not realize those were over in Europe so the shipping price is the same as the purchase price! But man is it tempting! I have a friend in Germany that does import/export to the USA so I may contact him and see if I could get some stuff put in one of his containers. I really like those mufflers and fresh air tube combos! |
vamram Samba Member
Posted: Wed Nov 30, 2022 8:53 am Post subject: Re: heater tube connection |
CIP1 carries the CSP hoses for much more reasonable shipping!! I got them for my '74 Super w/a dual-riser Thunderbolt header (Haven't fitted them yet though). _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
Posted: Wed Nov 30, 2022 6:43 pm Post subject: Re: heater tube connection |
I was on cip1 site for several hours today and I covered the entire heater and exhaust sections and I did not see them? I saw all the other hoses but not these. I will look again and do a search by name. |
Posted: Wed Nov 30, 2022 6:47 pm Post subject: Re: heater tube connection |
Yep, I went back there and searched by name and sure enough, there they are. Same purchase price but much cheaper shipping plus I already have a bunch of stuff in my wishlist to get so I just added them in. Thanks for the tip!
https://www2.cip1.com/c31-255-165-csp/ |
