classicbug Samba Member
Posted: Fri Nov 25, 2022 4:46 pm Post subject: Fix hole in dash |
Hi, "a friend" made a hole in the dash while trying to install a grab handle.
What's the best way to repair this?
carcrazed Samba Member
Posted: Fri Nov 25, 2022 5:06 pm Post subject: Re: Fix hole in dash |
The best way is to strip back the paint and weld a piece in...fill and sand, then paint. Probably not the answer you wanted to hear, but that is the correct way. I am sure people will chime in with some variants. _________________ 1965 Herbie Replica. 1776cc dual Kads.
1961 Beetle 33,000 Original Miles
"Just When you think you are getting ahead, you're always wrong." |
pastellgreen Samba Member
Joined: January 06, 2012 Posts: 1049 Location: Germany
Posted: Sat Nov 26, 2022 12:16 am Post subject: Re: Fix hole in dash |
I'm also through this. 4 holes in and under the dash, also expanded radio cut out. I only repainted the center section we repaired with a spray can. The inserts and glove box door are original paint.
TornadoRed06 Samba Member
Joined: August 30, 2020 Posts: 198 Location: Porto - Portugal
Posted: Sun Nov 27, 2022 8:18 am Post subject: Re: Fix hole in dash |
Or, if you whish no further body and paint messing, you could "patch it" with some cardboard/plastic thing and cover it with some insignia or otherwise sticker, and call it done. An appropriate period sticker as an example, I mean: unwind window, before closing door. |
AirHead1966 Samba Member
Joined: October 17, 2019 Posts: 568 Location: Triad Area NC
Posted: Sun Nov 27, 2022 9:05 am Post subject: Re: Fix hole in dash |
classicbug wrote: |
The best way would be to have your "friend" fix it. |
iowegian Samba Curmudgeon
Joined: February 16, 2005 Posts: 9829 Location: Somewhere between Dubuque and Keokuk
Posted: Sun Nov 27, 2022 9:09 am Post subject: Re: Fix hole in dash |
TornadoRed06 wrote: |
Good idea. A "Tourist Badge" from Tomi would be perfect. https://www.thesamba.com/vw/classifieds/detail.php?id=2453780
They are very thin and you should be able to easily bend one to conform to the radius of the dash "rib".
The oblong badges in my photo measure 1 1/2" x 1 1/4"
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Sun Nov 27, 2022 8:18 pm Post subject: Re: Fix hole in dash |
I'd just stick a bandaid over it and write "ouch" with a sharpie on the dash. But my car isn't nearly as nice |
Dusty1 Samba Member
Posted: Mon Nov 28, 2022 9:32 am Post subject: Re: Fix hole in dash |
carcrazed wrote: |
The best way is to strip back the paint and weld a piece in...fill and sand, then paint. Probably not the answer you wanted to hear, but that is the correct way. I am sure people will chime in with some variants. |
It's relatively easy to cut a sheet metal patch with the right shape and contour and weld it in. That's where the fun begins. You'll want to remove the windshield, the grab handle and the glove box before welding. You'll ruin your windshield with spatter, you may melt your grab handle and you may set your glovebox on fire.
The good news is the welds can be ground and filed down with all that stuff out of the way. I wouldn't use any fill at all.
Or:
Glue a silver coin over the hole with silicone adhesive. A pre- '65 silver quarter will cover a relatively large hole. I keep Mexican 5000 peso coins on hand for larger holes.
Or:
Use a glass eye intended for taxidermy behind the hole. It would be hilarious to stick an LED behind the eye so it lights up.
Posted: Mon Nov 28, 2022 3:46 pm Post subject: Re: Fix hole in dash |
An easy way to fix this without welding would be to:
1. Cut a thin piece of metal, a little larger than the hole, and press it over the hole from inside the trunk so that it generally assumes the same contour as the missing dash piece; it does not have to be perfect.
2. Then, use JB weld to glue the contoured metal piece from inside the trunk so that it covers the hole. The metal patch will of course not sit fully flush with the dash surface. That is OK.
3. After JB Weld cures, use Bondo to fill the repair. Contour and sand the Bondo. It will be just like how it used to look.
4. Paint the dash. |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34022 Location: Conejo Valley, CA
Posted: Mon Nov 28, 2022 3:52 pm Post subject: Re: Fix hole in dash |
Do you need to stop your mind from wandering where it will go?
splitjunkie Samba Member
Posted: Tue Nov 29, 2022 4:39 am Post subject: Re: Fix hole in dash |
AirHead1966 wrote: |
I would do something like this before I welded a patch in. As stated earlier, you would have to pull the windshield and welding will cause a lot of damage to the surrounding paint. This area isn't structural, exposed to the elements, or easily visible from the inside of the trunk. If you are very careful you could limit the damage from sanding the patch area to the area that is already damaged. Welding and grinding will scorch the paint much further. You would also have to worry about warping the metal. If you don't know what you are doing, you could create a much bigger problem for very little gain.
I would make the metal patch as close to the same thickness of the dash metal as possible though to keep the expansion rates of the metal as close as possible. _________________ Chris
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Tue Nov 29, 2022 6:27 am Post subject: Re: Fix hole in dash |
Cardboard taped over the windshield will work so you don't have to remove it. But you will definitely need to get welding blankets and such to cover the inside.
The suggestions for a "non welded" repair are good. Look at an epoxy type filler (think boat repair) not an automotive filler(bondo) as the Bondo stuff usually shrinks and cracks at the seam. Epoxy a little square of cloth over the hole from the inside, and when it's dry fill the hole on the dash side. _________________ modok wrote:
VW_Driver Samba Member
Posted: Wed Nov 30, 2022 7:36 pm Post subject: Re: Fix hole in dash |
I would recommend 3m panel adhesive. I had a car that had a bad hole cut in the dash I used it to put in a new one. You could bend a piece of sheet metal to fit then 'glue' it in, sand and paint, avoids the heat of a welder. Here is a video https://youtu.be/schvDSIxQnA
Here is a pic of my finished radio
Posted: Thu Dec 01, 2022 4:39 am Post subject: Re: Fix hole in dash |
VW_Driver wrote: |
I would agree but that stuff is quite expensive. For such a small patch, JB Weld should work fine but if he wants to spend the money, the 3M adhesive would be the way to go. _________________ Chris
davidw99 Samba Member
Joined: September 04, 2003 Posts: 696 Location: Boston, MA
Posted: Thu Dec 01, 2022 10:17 am Post subject: Re: Fix hole in dash |
pastellgreen wrote: |
Nice job. I'm going to have to do this with mine. _________________ Dave
'73 Saturn Yellow Sports Bug that has undergone a full pan off restoration. "Herbert IV."
'67 Sedan. "Bellamy." Currently being "refreshed" and recently repainted. |
