95 EV 2.5 ACU vacuum hose diagram.. anyone?
Forum Index -> Eurovan Share: Facebook Twitter
VWinny
VWinny is offline
PostPosted: Sat Nov 26, 2022 8:22 am    Post subject: 95 EV 2.5 ACU vacuum hose diagram.. anyone? Reply with quote
anyone have a vacuum hose diagram for the vacuum hoses on the engine? There are some coming off of the air filter box, fuel regulator fuel injector rail...
Got my newly rebuilt engine running good just want to make sure everything going to the MAP sensor on ECU is correct.
Thanks
1961tbird
1961tbird is offline
PostPosted: Sat Nov 26, 2022 11:30 am    Post subject: Re: 95 EV 2.5 ACU vacuum hose diagram.. anyone? Reply with quote
I would second that request.
I am considering replacing all my vacuum lines. I believe I saw some old posts on this issue but any recommendations on the type of new line to use? Silicone?
While I have not had any issues yet, I can see how these old lines become loose or come undone creating problems.
TheOneTrueQuux
TheOneTrueQuux is offline
PostPosted: Tue Nov 29, 2022 11:30 am    Post subject: Re: 95 EV 2.5 ACU vacuum hose diagram.. anyone? Reply with quote
Here you go:
I would use the stock braided cover hose, the original stuff lasted 30 years, new will as well. Silicone is more expensive, and might not stay on the vacuum nipples as well. Plus it doesn't look stock.
1961tbird
PostPosted: Wed Nov 30, 2022 5:49 am    Post subject: Re: 95 EV 2.5 ACU vacuum hose diagram.. anyone? Reply with quote
Thanks
subdewd
subdewd is offline
PostPosted: Sun Dec 04, 2022 8:38 am    Post subject: Re: 95 EV 2.5 ACU vacuum hose diagram.. anyone? Reply with quote
I've had silicone on for 5 years. Fits fine, plus different colors available to differentiate various lines. I'm not concerned about appearance personally.
VWinny
VWinny is offline
PostPosted: Fri Dec 09, 2022 7:09 am    Post subject: Re: 95 EV 2.5 ACU vacuum hose diagram.. anyone? Reply with quote
thanks
Saturn
Saturn is offline
PostPosted: Sat Dec 10, 2022 3:31 pm    Post subject: Re: 95 EV 2.5 ACU vacuum hose diagram.. anyone? Reply with quote
TheOneTrueQuux wrote:
Here you go:
For visitors from the future searching the phrase: Vacuum Hose Diagram (or Anordnung der Unterdruckleitungen)
This diagram for a 1993 Eurovan AAF 2.5L 5 Cylinder Gas Engine.
I guess with all of the additional components in the ACU engine, there was no room to have it both English and German.
Reply to topic    Forum Index -> Eurovan All times are Mountain Standard Time/Pacific Daylight Savings Time
