halbug Samba Member
Posted: Mon Feb 11, 2013 8:55 am Post subject: Karmann Ghia Body on 181 Chassis? |
Hi Folks,
Plan to assemble a 1965 Type 15 Karmann Ghia Convertible body to an NOS Type 181 (Kübel or Thing) IRS floor pan manufactured in Mexico. I know I will have to modify the body at the rear body mounts that bolt to the chassis shock mounts. Other than that, will it fit?
Has somebody tried this before or can tell me for certain if it will fit? Vehicle ID is no issue as the pan is NOS w/o a number yet.
Thanks for your tips and answers!
oorwullie Samba Member
Joined: May 01, 2003 Posts: 2365 Location: fribourg,switzerland
Posted: Mon Feb 11, 2013 5:00 pm Post subject: |
i dunno if it'll fit but i'd be interested to hear how you plan on registering it germany.
are you going to stamp the original 65 vert chassis number on to the new mex chassis?
gruss. |
berliner Samba Member
Joined: December 27, 2006 Posts: 440 Location: west coast canada
Posted: Mon Feb 11, 2013 8:37 pm Post subject: pan |
I believe the Thing uses the same size pan as the Ghia,but the rear body mounts may be different,due to the different years.(cut and weld)Also the Thing front end should be balljoint,while the '65 would have a link pin beam,so a new front beam would be required.I'm putting a '64 Ghia on a'72 pan so I have to use the later suspension(which is why I did it in the first place) including the IRS rear end.If the thing pan is set up for IRS,you would need IRS trans,axles and trailing/diagonal arms,to take advantage of the improved handling,OR I think you can use the swingaxle rear end from the '65.Do lots of research in the Search thingy before you start. _________________ I'm part of the problem. |
halbug Samba Member
Posted: Tue Feb 12, 2013 6:36 am Post subject: Re: pan |
berliner wrote: |
I believe the Thing uses the same size pan as the Ghia,but the rear body mounts may be different,due to the different years.(cut and weld)Also the Thing front end should be balljoint,while the '65 would have a link pin beam,so a new front beam would be required.I'm putting a '64 Ghia on a'72 pan so I have to use the later suspension(which is why I did it in the first place) including the IRS rear end.If the thing pan is set up for IRS,you would need IRS trans,axles and trailing/diagonal arms,to take advantage of the improved handling,OR I think you can use the swingaxle rear end from the '65.Do lots of research in the Search thingy before you start. |
Hi Berliner,
Yes - the adds for floor halfes always talk about usage for Karmann Ghia and Thing. I just thought somebody may have done it and could confirm the set-up. The IRS rear and balljoint front suspension are the reason for swapping pans. |
Bobnotch Samba Member
Posted: Tue Feb 12, 2013 3:14 pm Post subject: Re: pan |
halbug wrote: |
berliner wrote: |
Hi Berliner,
I've put Ghia floor pan halfs into a thing before. Yes, the jack mounts had to be removed, but that was it. You might want to do a test fit before you get too far, but it should fit. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
halbug Samba Member
Posted: Wed Feb 13, 2013 9:22 am Post subject: Re: pan |
Bobnotch wrote: |
halbug wrote: |
berliner wrote: |
Hi Berliner,
I've put Ghia floor pan halfs into a thing before. Yes, the jack mounts had to be removed, but that was it. You might want to do a test fit before you get too far, but it should fit. |
I knew somebody here must have done it before - Thanks!
My main concern where the pan halfs, the rest of the chassis seems to be alike anyhow! Good hint with the jack mounts, compared mine and they seem to be identical. Either way they will not stop me. |
myb356 Samba Member
Joined: October 14, 2004 Posts: 408 Location: bay area california
Posted: Wed Feb 13, 2013 1:03 pm Post subject: |
Yes, it fits, for sure. If you want heat, you will need to run tubes for the cables. The only other slight mod to do is seal up the roll bar holes. Search my gallery for a Ghia on a Thing chassis. |
halbug Samba Member
Posted: Wed Feb 13, 2013 2:26 pm Post subject: |
myb356 wrote: |
More good news! Thank you Nice Ghia you have there!
My chassis has heater cable tubes installed already. Seat rails will have to go. Does anyone know what the tube is for, that exits on the tunnel half way between shifter and Napoleon hat?
Other differences I noted, are reinforcement plates at the underside, just where the Napoleon hat runs out, a reinforcement bar under the rear torsion tube and battery holder. Drain holes are usually also not needed in a Ghia (let's hope!)
Here is a picture of it:
myb356 Samba Member
Posted: Wed Feb 13, 2013 8:09 pm Post subject: |
One thing I noticed... or perhaps imagined is that the rear suspension seemed to have an awful lot of down travel. Wondering if there could be a variation in the casting where the springplate goes that affects and limits up and down travel. That stiffener under the rear torsion makes a 901 5-speed swap a total pain. |
halbug Samba Member
Posted: Thu Feb 14, 2013 2:36 am Post subject: |
myb356 wrote: |
Interesting, I compared mine with a 68 IRS bug pan and the castings seem to be identical. The bar under the rear torsion bar may create myself some headache for installing Berg5 and a rear sway bar. But we will see, once I get there. Can't wait to get started
All - Thanks for confirming my plans |
c21darrel Samba Member
halbug Samba Member
Posted: Thu Feb 14, 2013 12:09 pm Post subject: |
c21darrel wrote: |
"Does anyone know what the tube is for, that exits on the tunnel half way between shifter and Napoleon hat? "
looks like someone ran the fuel line on the inner side of the Nap hat. Normally the fuel line would enter the tunnel from in front of the Nap hat, directly under your fuel tank.
Thanks but: Nope - fuel line exits tunnel on the RH side on mine (difficult to see on photo). I need to run a wire through the tube in question, because I can not see where it exits again. |
WooleyNelson Samba Member
Joined: July 13, 2012 Posts: 191 Location: Kokomo Indiana
Posted: Fri Feb 15, 2013 1:23 pm Post subject: |
as for the tube in question......could it have been for a mechanically driven tachometer? or some other guage?
seems that position on the tunnel would work to mount auxilliary guage.... |
halbug Samba Member
SilverThing Samba Member
Posted: Sun Dec 04, 2022 1:01 pm Post subject: Re: Karmann Ghia Body on 181 Chassis? |
The tube that exits between the shifter and napolean hat is used to control the defrost flap on 1974 and later 181. Unlike other VWs, 181 engine heat ran through plastic pieces and cardboard type tubes along the center tunnel. The last plastic piece sits on top of that part of the tunnel and there is a flap that directs air to either the defrost vents or out near the pedals. The control is the regular heater controls next to the parking brake. Engine heat was only available 1974 and later 181, but not all 181 got it. German Bundeswehr 181 almost never got engine heat for some reason.
Interestingly, my 1975 model 110 'Basic Beetle' has the same little indentation in the tunnel. I haven't looked at it carefully to see if there is actually a tube in there. _________________ "I like how everyone likes talking about Zeke's Thing yet he's the only one that's ever seen it." - Katie
"I've seen pictures..." - Jeremy |
halbug Samba Member
Posted: Mon Dec 05, 2022 12:57 am Post subject: Re: Karmann Ghia Body on 181 Chassis? |
SilverThing wrote: |
Interestingly, my 1975 model 110 'Basic Beetle' has the same little indentation in the tunnel. I haven't looked at it carefully to see if there is actually a tube in there. |
That is very interesting! Do you mean, the heated air in a T181 is not routed through body heater channels but rather through tubes on top of the tunnel? Never realized that! Do you have any pictures maybe?
Thank you _________________ Stealth Ghia Transformation: http://www.thesamba.com/vw/forum/viewtopic.php?p=7226044&highlight=#7226044
My Berg5: https://www.thesamba.com/vw/forum/viewtopic.php?t=730276&start=0 |
Posted: Mon Dec 05, 2022 10:20 am Post subject: Re: Karmann Ghia Body on 181 Chassis? |
Below is a link to the 181 forum discussion on heating systems. We only got the 181 here in the US for two years (1973 and 1974) and the primary difference between the two years is the heating system. The reason I mention that is that the heater forum discussion I linked only talks about 73 and 74 heaters. Elsewhere in the world, the 73/74 heater distinction isn’t as clear cut. Prior to 1974, 181 came with a BN4 heater only (no engine heat) or could optionally come with no heater at all (fairly common in Mexico). In 1974, VW introduced engine heat for the 181. In the US, all 1974s have engine heat, but that isn’t the case in other markets. The Bundeswehr almost never bought 181 with engine heat so Germans tend to refer to the two heating systems (and also the exhaust systems) as ‘BW’ and ‘Zivil’ since engine heat was more common on civil service vehicles like fire fighters and civil defense. Other militaries did buy 181 with engine heat so that adds to confusion. 1974 and later 181 could have no heat, BN4 only, engine heat only, or engine heat plus BN4. That is probably more info than you wanted, but hopefully it helps clarify things some.
https://www.thesamba.com/vw/forum/viewtopic.php?t=332848 _________________ "I like how everyone likes talking about Zeke's Thing yet he's the only one that's ever seen it." - Katie
halbug Samba Member
