Iowa Mark Samba Member
Posted: Mon Dec 05, 2022 6:02 am Post subject: Brakes and turn signals on not enough wires |
I've been trying to find a thread that showed a way of running a three wire turn signal switch in an oval by using a '67 relay box. Anyone remember this posting? |
Bub Samba Member
Joined: June 10, 2004 Posts: 1155 Location: Central Washington
Posted: Mon Dec 05, 2022 1:05 pm Post subject: Re: Brakes and turn signals on not enough wires |
If your car is 12v it's WAY easier to just use a 'euro tow convertor' type box.
https://www.walmart.com/ip/US-To-Europe-Trailer-Li.../700598863
hitest wrote: |
Had a girlfriend once who shall we say, nearly arrived at the mere sight of a semaphore in action- easy to please she was... |
Posted: Wed Dec 07, 2022 9:13 am Post subject: Re: Brakes and turn signals on not enough wires |
I'm a bit confused on the use of this adapter. Do I wire it backwards to work? I have the standard dual filiment tail lights and it looks like it spits the lines out for more than just two. I seem to remember a thread that had a relay box from a '67 to get around the use of the '57 multi-wire switch. Maybe the back-up lights were repurposed on the relay? Anybody? Buller? |
Bub Samba Member
Posted: Wed Dec 07, 2022 9:41 am Post subject: Re: Brakes and turn signals on not enough wires |
Iowa Mark wrote: |
Don't get hung up on that 67' black box, while technically you could do it; it's not very straightforward- way more complicated than needed.
Yep, you just wire it backwards. I assume? I've used them before just not this exact one, and they do exactly what you're trying to accomplish.
This is probably a better example, two signals in for each tail light and one signal out.
--> I have used this exact one before, should do exactly what you want: blinks the brake light of the side that is energized while the brakes are applied.
https://www.amazon.com/CARROFIX-Powered-2-Wire-Con...mp;sr=8-20
hitest wrote: |
Posted: Wed Dec 07, 2022 10:56 am Post subject: Re: Brakes and turn signals on not enough wires |
Thank you, Bub. I'm trying to retain an old steering wheel and hub that came with my '56, along with the later steering column and blinker set up.
