ludsbug Samba Member
Joined: March 08, 2005 Posts: 234 Location: Gardnerville NV
Posted: Sat Nov 20, 2010 9:21 pm Post subject: |
itHaKa wrote: |
i use this, only 50 dollars , works great , and has the oil level mark
no wires, very simple
Where did you purchase the oil temp/dip stick? |
zozo Samba Member
Joined: October 15, 2005 Posts: 5217 Location: South of Ol' San Antonio
Posted: Sat Nov 20, 2010 9:39 pm Post subject: |
There's also the type that will trigger your idiot light if the oil gets too hot. It replaces the stock dipstick and wires to the existing sensor. |
johnanddes Satellite Wrangler
Joined: October 17, 2004 Posts: 692 Location: Orcutt CA
Posted: Sun Nov 21, 2010 8:02 am Post subject: |
Zozo, I think it was a little odd that Walmart carried the 12" thermo also, which is why I grabbed it when I saw it because I knew it was perfect for checking the oil. _________________ John
1969 documented numbers matching bug
1968 F250
Keepin the ISS from colliding with space junk |
aircooled Samba Member
Joined: December 02, 2003 Posts: 1290 Location: Heartland, Neb
Posted: Sun Nov 21, 2010 10:02 am Post subject: |
I tried the one Ludsbug posted and it is a high quality item. The problem I had was if you have a breather pipe the gauge won't fix between the hole for the dip stick and the breather pipe. The fix would be the indent the side of the pipe to make room. I returned it and have used a Berg Temp Dip Stick fpr several years. _________________ 67 Sun Roof / Born Sept 66 / Second Owner
67 Convertible / Born Aug 66 / Second Owner
Member of 67 Posse
Omaha Volkswagen Club
Neb VVWCA Chapter Rep
Volkswagen Club of Nebraska |
JamesDole Samba Member
Joined: July 18, 2007 Posts: 215 Location: Yakima, WA
Posted: Sun Nov 21, 2010 11:24 am Post subject: |
I run the Berg temp dipstick. It has worked great for me. Once your idiot light starts to flicker then you know it's time to back off. It it stays on with no flickering, it's time to pull over. Less then a 5-min install and wires to your oil pressure switch. |
itHaKa Samba Member
Joined: February 20, 2008 Posts: 254 Location: Argentina
Bugdog67 Samba Member
Joined: September 27, 2006 Posts: 225 Location: The Castle Anthrax
Posted: Mon Nov 22, 2010 8:27 am Post subject: |
Cool. And just in time for Christmas! |
Harris Samba Member
Posted: Mon Nov 22, 2010 8:35 am Post subject: Dip Stick Temp |
itHaKa
Does the dipstick gauge your using fit snug in the dipstick tube? |
EverettB Administrator
Joined: April 11, 2000 Posts: 69827 Location: Phoenix Metro
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
Harris Samba Member
Posted: Mon Nov 22, 2010 11:27 am Post subject: Dipstick Gauge |
Anyone using this,
Does the dipstick gauge your using fit snug in the dipstick tube? Appears to have a rubber collar for the dipstick tube |
Posted: Mon Nov 22, 2010 5:19 pm Post subject: |
Max Welton wrote: |
One size could fit all type-1s. It just needs to reach far enough to be in the oil. Doesn't matter how far it sticks up (short of interferring with the belt). |
My question sort of sucked - I was thinking about the low/high oil marks, which I think are not the same across all years. _________________ How to Post Photos
itHaKa Samba Member
Posted: Mon Nov 22, 2010 7:45 pm Post subject: Re: Dip Stick Temp |
Harris wrote: |
itHaKa
it is a little fragile gauge, so it fits loose, you can turn it easily by hand
has a rubber at the top for a seal ,
the only complaint is that it only has one oil level mark, i don´t remember if it is the lower or the full oil level mark
i am very happy with it , it tells you for sure if you are running hot, just open the lid and watch . i have been using it for a year, with no issues
highly recommended |
Harris Samba Member
Posted: Mon Nov 22, 2010 7:55 pm Post subject: Dipstick temp |
Thanks itHaKa
I appreciate it. |
mikemck Samba Member
Posted: Tue Nov 23, 2010 6:09 pm Post subject: |
Harris,
Mine fit loose on the dipstick tube.
I put some heat shrink tubing on the dipstick tube and now the gauge fits tight. |
Harris Samba Member
Posted: Tue Nov 23, 2010 7:59 pm Post subject: Dipstick Gauge |
Thanks Mikemck,
Good idea. |
Posted: Tue Nov 23, 2010 8:57 pm Post subject: |
Some heatshrink tubing has adhesive on the inside. That is the kind I used. |
otis_bartleh Samba Member
Joined: August 19, 2009 Posts: 1106 Location: Burlington, WA
Posted: Wed Nov 24, 2010 3:47 pm Post subject: |
Glad I saw that Mainely Customs dipstick, that looks pretty cool, I'd rather see a gauge that have the light trigger. But seeing Burg's small sender, having both the Burg small sender somewhere to activate the idiot light, and the gauge dipstick for accurate readings... Kinda the best of both... _________________ -Adam
'59 Mango Bus
'11 Golf TDI 6-speed
'69 Bug |
Scorcho Samba Member
Joined: May 04, 2012 Posts: 386 Location: Chicago, IL
Posted: Wed Aug 07, 2019 8:26 pm Post subject: |
glutamodo wrote: |
I tell ya, I wish that Berg warning dipstick would work for me - BUT, well, for me that thing would be going off all the time, so I won't use it. It's impossible to avoid, if I get up to freeway speeds in the summer, it's going to be well over 225. And nothing I've done on either car has made any kind of appreciable difference. |
Does it matter if it comes on DURING accceleration or only while idling after driving a while? 1600DP in bus |
scottyrocks Samba Member
Joined: August 19, 2016 Posts: 2666 Location: Long Island, NY
Posted: Tue Dec 06, 2022 10:42 am Post subject: Re: Dipstick temp. |
Just for informational purposes, on my '63 Beetle, it is 6 3/4" from the top of the dipstick hole to where it bottoms out down below.
Because of the breather tube, there is so little room for the thermometer dial that I will have to go for a thermometer with closer to a 12" shaft. _________________ “If you care for a thing long enough, it takes on a life of its own, doesn't it? Mending old things, preserving them, looking after them – on some level there's no rational grounds for it.”
– D. Tartt, 'The Goldfinch' |
