oprn Samba Member
Joined: November 13, 2016 Posts: 12708 Location: Western Canada
Posted: Mon Aug 23, 2021 3:53 am Post subject: Re: Ram-air Cooling Ducts |
Road dust and rocks would be the result especially on gravel and dirt roads! At highway speeds you would get cool air but in traffic you could pull hot air up from under the car.
I left it off on my street Buggy but it gets covered with dirt and rocks anyway being as the engine is all in the open. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
DerrickfromNC1 Samba Member
Joined: October 24, 2008 Posts: 1300 Location: North Carolina
Posted: Mon Aug 23, 2021 4:25 am Post subject: Re: Ram-air Cooling Ducts |
craigman wrote: |
Very cool results!
I wonder what would happen if someone were to remove the front (flywheel side) tin to let in fresh air. It would a lot of fresh air into the fan and carbs.
Just a thought... |
This does work providing the decklid is propped open at the bottom to provide air flow at highway speeds. I saw a drop in cylinder head/oil temp based on my VDO gauges. Also makes it difficult to keep engine clean. |
wheel607 Samba Member
Posted: Sun Aug 28, 2022 12:39 am Post subject: Re: Ram-air Cooling Ducts |
Any updates? Its been over a year. |
Floating VW Samba Member
Joined: April 28, 2015 Posts: 1596 Location: The South Zone
Posted: Wed Dec 07, 2022 12:26 pm Post subject: Re: Ram-air Cooling Ducts |
wheel607 wrote: |
Sorry it took me so long to respond. I spent pretty much every spare minute I had last summer repairing some damage to my front left quarter panel and replacing the hinge pins on the driver's side door (which, of course, required me to design and build my own special hinge-pin removal tool, 'cause that's how I get my kicks). So the Samba kinda got put on the back burner for a while.
Anyway, the ram-air ducts continue to function beautifully! I got my CHT gauges re-connected and took my machine out for a sustained, full throttle run down a lonely stretch of state highway, so I do have some more data to offer:
Accelerating from 55 mph to a sustained average speed of approx. 98 mph, on a (mostly) flat and level road with a slight head wind, CHT's started at about 250 degrees F and climbed steadily until they leveled off at about 365 degrees F. After the CHT's stopped climbing, I only kept my foot in it for probably not more than a minute or two, 'cause my balls just aren't big enough, I suppose. But 365 degrees F was pretty impressive, I thought. I was expecting it to be at least 75 degrees higher.
As mentioned earlier, my CHT sensors aren't located exactly under the spark plugs, so keep that in mind. For what it's worth, they're located here:
https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0 _________________ "It's time you started treating people as individuals, rather than mathematically predictable members of an aggregate set, regardless of how well that works."
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Wed Dec 07, 2022 4:08 pm Post subject: Re: Ram-air Cooling Ducts |
This is really cool. So when is the kit going to become available? |
Bug53 Samba Member
Joined: February 22, 2021 Posts: 704 Location: Pawcatuck, CT.
Posted: Wed Dec 07, 2022 5:54 pm Post subject: Re: Ram-air Cooling Ducts |
Very cool design and technique.
I like it. |
Posted: Wed Dec 07, 2022 5:57 pm Post subject: Re: Ram-air Cooling Ducts |
Pruneman99 wrote: |
Hah! I've actually had several people ask me that.
I guess the best answer to that would be, whenever I get over my absolute loathing of working with composites!
Bug53 wrote: |
I like it. |
Thanks, man! _________________ "It's time you started treating people as individuals, rather than mathematically predictable members of an aggregate set, regardless of how well that works." |
