sdp65 Samba Member
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17012 Location: Retired South Florida
Posted: Tue Dec 06, 2022 7:04 am Post subject: Re: Aluminum Bell Housing |
Can’t compare for you, but the GW one is for a pancake engine. My limited history of South African T3 was they we’re running in line cylinder engines. If that’s the case, the bellhousing would have a different design.
As far as clearancing, I had to clearance my diesel bellhousing for the dual mass flywheel. Don’t think it weakened it. It needed a special input shaft that likely only works with the diesel bell housing. There is another bell housing that came in the Mexico market that required a very rare input shaft. Spline and diameter where the same, but longer than the stock diesel and pancake shafts. It mounted the in-line engine straight up.
So, you do need to pay attention that you have all the parts to complete your project. _________________ ☮️ |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9517 Location: Western WA
Posted: Tue Dec 06, 2022 1:55 pm Post subject: Re: Aluminum Bell Housing |
I think I heard.... you have to grind the bellhousing (from Weddle) just a little.
AlikaT3 should know this stuff.
Alika has a Dual Mass Flywheel too. _________________
....KTMs, GasGas, SPOT mtb |
sdp65 Samba Member
Posted: Tue Dec 06, 2022 4:37 pm Post subject: Re: Aluminum Bell Housing |
Sodo wrote: |
Alika has a Dual Mass Flywheel too. |
so is the one weddle sells and the gowesty one the same? |
Sodo Samba Member
Posted: Tue Dec 06, 2022 8:39 pm Post subject: Re: Aluminum Bell Housing |
I’m not the one to ask, but I doubt GoWesty has anything for diesel. _________________
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6316 Location: Honolulu,Hawaii and France
Posted: Tue Dec 06, 2022 11:03 pm Post subject: Re: Aluminum Bell Housing |
Sodo wrote: |
The late WBX and diesel bellhousings were aluminum.
Usually when we mention SA bellhousings, it's the 5 inline bellhousing.
The aluminum one was made in Germany as far as I know, maybe they had left over stocks in RSA that got sold by vendors at some point.
The bellhousing sold by Go Westy is an aftermarket item, I don't know about the strength.
DMF's are usually a diesel feature, the subject here is a flat four bellhousing, gasser.
I wouldn't worry about the German aluminum bellhousing strength. _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
Posted: Wed Dec 07, 2022 5:46 am Post subject: Re: Aluminum Bell Housing |
@Scott. What engine are you intending to mate the transmission to? _________________ ☮️ |
AndyBees Samba Member
Joined: January 31, 2008 Posts: 2310 Location: Southeast Kentucky
Posted: Wed Dec 07, 2022 7:34 am Post subject: Re: Aluminum Bell Housing |
ALIKA T3 wrote: |
The late WBX and diesel bell housings are aluminum.
Usually when we mention SA bell housings, it's the 5 inline bell housing.
The bell housing sold by Go Westy is an aftermarket item, I don't know about the strength.
DMF's are usually a diesel feature, the subject here is a flat four bell housing, gasser.
I wouldn't worry about the German aluminum bell housing strength. |
I agree about the strength (no worries). I've been around VWs well over 50 years. I do not recall seeing or reading anything about Bell Housing failure (the oll slinger can be problematic with any bell housing).
Yep, I have a SA Bell Housing for the In-line 5-cylinder. Not sure if it is aluminum or not.... bright and shiny though. (I may list it in the classifieds sometime soon)
There .......... _________________ '84 Vanagon Tin-top, ALH TDI. 1989 Tin-top
1983 Air-cool, 225k miles, 180k miles mine. Seven trips to Alaska from 1986 thru 2003.
sdp65 Samba Member
Posted: Wed Dec 07, 2022 12:05 pm Post subject: Re: Aluminum Bell Housing |
MarkWard wrote: |
@Scott. What engine are you intending to mate the transmission to? |
Mark,
I am getting a PD TDI from FAS. (how's that for some letters!)
It s a pumpe duse Turbo Diesel. its designed to mate up to WBX bell housing, not the diesel housing nor inline SA housing and just wondering which one is the strongest, and I guess if it even matters..... |
Posted: Wed Dec 07, 2022 12:47 pm Post subject: Re: Aluminum Bell Housing |
FAS makes some nice stuff. Because they are using an adapter plate, you may be locked into using their flywheel and clutch setup. I'd ask them about the Dual Mass Flywheel. Most of us sporting TDI's have had to upgrade to that setup to keep the transmission from hammering itself to death.
I think the bellhousing Weddle or GW sells will be fine and likely won't need any clearance added. Get ready to hold on to your hat. Nothing like that torque and power. _________________ ☮️ |
