DesertG Samba Member
Posted: Sun Dec 04, 2022 10:43 am Post subject: 1965 Rear Carpet to Headliner Glued? |
Hello Guys, the prior owner replaced the carpet and headliner. The back carpet is glued to the headliner (and falling apart). Is this correct. Is there a better way to do this. Thank you.
_________________ 1965 Beetle, 1970 1600cc DP 60HP, 12v |
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4657 Location: Whittier 90602
Posted: Sun Dec 04, 2022 4:14 pm Post subject: Re: 1965 Rear Carpet to Headliner Glued? |
From stock the carpet is longer and the end is unfinished.
It rolls over the edge of the firewall and tucks into the crevice as does the end of the perforated headliner, then a piece of ~8 mm cording gets pushed in to hold them tight. _________________ -Bruce
An ounce of prevention is worth a pound of cure. |
Posted: Sun Dec 04, 2022 4:48 pm Post subject: Re: 1965 Rear Carpet to Headliner Glued? |
61SNRF wrote: |
It rolls over the edge of the firewall and tucks into the crevice as does the end of the perforated headliner, then a piece of ~8 mm cording gets pushed in to hold them tight. |
Thank you. My carpet looks to have a finished edge. How do you think I can easily fix this. Do people use screws. _________________ 1965 Beetle, 1970 1600cc DP 60HP, 12v |
carcrazed Samba Member
Posted: Sun Dec 04, 2022 6:38 pm Post subject: Re: 1965 Rear Carpet to Headliner Glued? |
On both of my bugs I glued that portion on. Haven't had an issue with it peeling back off. My 65 was installed in 1998. _________________ 1965 Herbie Replica. 1776cc dual Kads.
1961 Beetle 33,000 Original Miles
"Just When you think you are getting ahead, you're always wrong." |
Posted: Mon Dec 05, 2022 7:20 am Post subject: Re: 1965 Rear Carpet to Headliner Glued? |
carcrazed wrote: |
On both of my bugs I glued that portion on. Haven't had an issue with it peeling back off. My 65 was installed in 1998. |
Thank you. What did you glue it with. _________________ 1965 Beetle, 1970 1600cc DP 60HP, 12v |
Rome Samba Member
Joined: June 02, 2004 Posts: 9641 Location: Pearl River, NY
Posted: Mon Dec 05, 2022 7:29 am Post subject: Re: 1965 Rear Carpet to Headliner Glued? |
In 2013 I was lucky to view the red '65 Sedan seen here at Classic VW Bugs' shop in person. All original, ca. 8000 miles! Here are some close-ups of the rear carpet and headliner sections.
More photos: http://www.classicvwbugs.com/65rubyoriginal/# |
Posted: Mon Dec 05, 2022 7:34 am Post subject: Re: 1965 Rear Carpet to Headliner Glued? |
Thank you. That looks nice. I don't think I can undo what I have at this point. _________________ 1965 Beetle, 1970 1600cc DP 60HP, 12v |
61SNRF Samba Member
Posted: Mon Dec 05, 2022 1:49 pm Post subject: Re: 1965 Rear Carpet to Headliner Glued? |
Is your carpet not long enough to roll over and tuck in?
Is it glued down firmly? If it is loose perhaps you can undo it from the floor/firewall so you can pull it up and bias more material towards the top. _________________ -Bruce
Posted: Mon Dec 05, 2022 1:52 pm Post subject: Re: 1965 Rear Carpet to Headliner Glued? |
61SNRF wrote: |
Is it glued down firmly? If it is loose perhaps you can undo it from the floor/firewall so you can pull it up and bias more material towards the top. |
Thanks Bruce. I will look to see if I have slack. If I can roll if over, how to I secure it. Not necessarily looking for "correct" but easy and quick. _________________ 1965 Beetle, 1970 1600cc DP 60HP, 12v |
61SNRF Samba Member
Posted: Tue Dec 06, 2022 7:04 am Post subject: Re: 1965 Rear Carpet to Headliner Glued? |
As said stock it is long enough to roll over the edge and get wedged into the slot with a piece of cord. I suggest try that first if you can get an extra inch or two.
If you don't have cording try rope or a rolled up cloth of a discrete color.
If you can't get an extra inch or two then? _________________ -Bruce
61SNRF Samba Member
Posted: Tue Dec 06, 2022 8:36 pm Post subject: Re: 1965 Rear Carpet to Headliner Glued? |
Here's an idea.
Pull the top of the carpet down five or six inches.
Tip: If it's glued, and it's closed loop carpet, be VERY carefull not to unravel as you go.
Cut a 6" by what ever the total width of the carpet/firewall is strip of heavy fabric (old denim might do well).
Lenghwise stitch 4" of it to the carpet, with like colored thread, on the top edge of the carpet so as to extend the carpet's end by 2" or so.
Like this now you have a heavy fabric tail you can wedge into the crevasse so to hold the carpetup firmly, and like that should also finish off the bottom edge of the window headliner piece too. _________________ -Bruce
Posted: Tue Dec 06, 2022 8:37 pm Post subject: Re: 1965 Rear Carpet to Headliner Glued? |
Thanks Bruce. I will hit it this weekend. _________________ 1965 Beetle, 1970 1600cc DP 60HP, 12v |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Wed Dec 07, 2022 1:22 pm Post subject: Re: 1965 Rear Carpet to Headliner Glued? |
If you have time to investigate using screws(!) you have time to pull that one simple piece of carpet and just do it right. The hard part of this thread to read is that you asked for the right way to do it but then say, "Not necessarily looking for "correct" but easy and quick."
If the carpet is pulling away from the headliner so easily- it must not be thoroughly glued down. Therefore it should pull out easily with the back seat removed.
The seal around your rear window needs the lower edge pulled properly- easily done with a warm garage and a hook tool. _________________
EverettB wrote: |
FU#5 |
Posted: Wed Dec 07, 2022 2:29 pm Post subject: Re: 1965 Rear Carpet to Headliner Glued? |
hitest wrote: |
The seal around your rear window needs the lower edge pulled properly- easily done with a warm garage and a hook tool. |
Thank you. The nature of my comment was I don't want to open up a can of worms with the headliner. I don't have the money to hire someone to replace it. _________________ 1965 Beetle, 1970 1600cc DP 60HP, 12v |
