Bad bug Samba Member
Posted: Wed Dec 07, 2022 1:42 pm Post subject: Superdiff in a daily driver. |
As the heading states is there anyone here running one in a true 5 days per week daily driver car. The car is IRS. |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7214 Location: Videbaek Denmark
UK Luke 72 Samba Member
Joined: September 07, 2011 Posts: 2867 Location: Little Britain
Posted: Wed Dec 07, 2022 2:38 pm Post subject: Re: Superdiff in a daily |
Thanks for the replies so far, Luke, how did you find the diff to be, is it hard to drive the car on the street.[/list] |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76911 Location: Sneaking up behind you
Posted: Wed Dec 07, 2022 2:44 pm Post subject: Re: Superdiff in a daily driver. |
I had a Superdiff in my daily for 10 years and put over 125,000 miles on it.
Changed the gear lube and found bits in it.
Took the transaxle apart and found the spider gears have seen better days.
Replaced it with a ZF LSD.
_________________ Glenn
Member #1009
#BlueSquare |
petrol punk Samba Member
Joined: August 21, 2007 Posts: 975 Location: Las Vegas, NV
Posted: Wed Dec 07, 2022 2:48 pm Post subject: Re: Superdiff in a daily driver. |
If the guy who I bought my IRS tranny from is to be believed it has a super diff. I've never had an issue or really noticed any difference from the stock diff in my other splitcase trans oval. _________________ 36hp '56 European DeLuxe oval, '70 bug 1835cc dual 36DRLA, and a '98 4x4 5spd single cab Tacoma |
Posted: Wed Dec 07, 2022 2:53 pm Post subject: Re: Superdiff in a daily driver. |
Thanks for all the replies, Glenn, a limited is not in rhe cards for me at the moment. Luke, are you running a swing axle backend car? |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Wed Dec 07, 2022 3:03 pm Post subject: Re: Superdiff in a daily driver. |
The Swing axle super diff were the problematic ones Old IRS supers no issues, Glenns was where? made in Brasil? _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
Glenn Mr. 010
Posted: Wed Dec 07, 2022 3:04 pm Post subject: Re: Superdiff in a daily driver. |
madmike wrote: |
The Swing axle super diff were the problematic ones Old IRS supers no issues, Glenns was where? made in Brasil? |
Yes. _________________ Glenn
Member #1009
#BlueSquare |
Glenn Mr. 010
Posted: Wed Dec 07, 2022 5:03 pm Post subject: Re: Superdiff in a daily driver. |
This is the side cover on my tranny. BTW, i have a Berg 5.
Member #1009
#BlueSquare |
Posted: Wed Dec 07, 2022 5:16 pm Post subject: Re: Superdiff in a daily driver. |
Glenn has a Factory HD Aluminium cover, Just as strong as some aftermarket ones _________________ 'Black Ice'Drag Buggy 'Turbo'
RickS Samba Member
Posted: Wed Dec 07, 2022 6:41 pm Post subject: Re: Superdiff in a daily driver. |
That Aluminum Super Diff is made by Dave Folts. It is really nice, uses 091 side and spider gears. Call Dave directly if you want one. I bought one from him last month for SIGNIFICANTLY LESS money then Weddle charges. The only issue is Weddle is out of stock on the HD spider gears for it. I called last week for an update and they told me they expected them last week, so should be soon. |
Clatter Samba Member
Joined: September 24, 2003 Posts: 7537 Location: Santa Cruz
Posted: Wed Dec 07, 2022 8:00 pm Post subject: Re: Superdiff in a daily driver. |
madmike wrote: |
Glenn has a Factory HD Aluminium cover, Just as strong as some aftermarket ones |
Doesn’t it have less strength now that it’s been machined down like that?
That’s done for weight savings, or maybe looks?
I remember the old Transform shop used to do that… _________________ Bus Motor Build
What’s That Noise?!? |
Posted: Wed Dec 07, 2022 8:08 pm Post subject: Re: Superdiff in a daily driver. |
A super diff won’t drive any different than a regular 2-spider diff.
Unless it’s a cheap POS and breaks, locking things up,
(Like a lot are nowadays, especially swing axle).
It’s not a TBD or LSD or spool…
Late Vanagons came stock with a 4-spider a.k.a. “Super” diff. _________________ Bus Motor Build
Glenn Mr. 010
Posted: Wed Dec 07, 2022 8:20 pm Post subject: Re: Superdiff in a daily driver. |
Clatter wrote: |
Late Vanagons came stock with a 4-spider a.k.a. “Super” diff. |
A Super Diff is still an "open" diff. It just spreads the load across 3 spider gears instead of just 2. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Wed Dec 07, 2022 9:15 pm Post subject: Re: Superdiff in a daily driver. |
Glenn wrote: |
Clatter wrote: |
A Super Diff is still an "open" diff. It just spreads the load across 3 spider gears instead of just 2. |
Ya,
I hear ya!
Supposed to be 4 spiders,
But with the quality of most,
One’s just along for the ride..! _________________ Bus Motor Build
AlteWagen Troll
Posted: Thu Dec 08, 2022 3:45 pm Post subject: Re: Superdiff in a daily driver. |
I think there are two different part groups that are being discussed
-Gear carrier/differential housing
-Spider gear assembly
The common term 'super diff' refers to a HD gear carrier which is where the ring gear bolts to and houses the spider gear assembly. This HD casting if being used on the street needs to be drilled so there is proper oil flow over the spider gears.
Here is a comparison pic. Note how open the stock carrier is which allows the needed splash oiling on the spider gears.
Super diff shown with oiling mods
The spider gear assembly in stock form only uses two spider gears. The 4 spider gear assembly or more commonly known as the 'beef a diff' helps spread the load to more gear teeth compared to stock set up. While this 4 spider setup is the usual upgrade when installing a HD gear carrier it can also be used in the factory carrier for an upgrade as well.
Stock 2 gear setup (swing shown)
Beef a diff
_________________ Grapes of Wrath $200 Engine Rebuild
Official Dual Carb Thread
Cylinder Head Quick Reference Sheet |
