Willin Samba Member
Joined: October 10, 2019 Posts: 109 Location: Bozeman Mt
Posted: Wed Dec 07, 2022 9:23 am Post subject: Alternator light |
Hello
I am having an issue with the alt.light in my 73.
Rebuilt Bosch alt. New VR from laps. Pretty sure grounds all good.
In warm weather, at startup , the light will glow till I blip the throttle. So, right away.
Now that it is cold out, I notice that I have to rev. the engine more the colder it gets, to get the light to go out. I just fired up this morning at 15*F. Light will not go out. Took for a short drive and rev-ed it. Light staying on.
What is going on with cold temps. causing this?
Thanks in advance! |
busdaddy Samba Member
Posted: Wed Dec 07, 2022 10:32 am Post subject: Re: Alternator light |
Drive belt slipping? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8568 Location: All Across The Country
Posted: Wed Dec 07, 2022 11:16 am Post subject: Re: Alternator light |
Willin wrote: |
Hello
That symptom usually suggests that one of your excitor diodes has blown. It takes away about a 1/3 of your charging capacity, and requires an extra 1/3 of rpms to do the cut-in.
With the morning cold, now add a battery that is less efficient, running voltage up to the idiot light and back to get the alternator woken up.
Today, it is possible that the alternator has given it up.
Try charging the battery overnight ( away from ignition sources above freezing themperatures ), let it warm up in the kitchen for an hour , then go stick it in the bus and start immediately and see if the idiot light goes out with a little rev. If no, tap your mechanical regulator with a screwdriver handle (don't bother a solid state regulator) with the engine at a slightly elevated rpm. Still no? Alternator. _________________ www.itinerant-air-cooled.com |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2745 Location: Hamble, Hampshire, UK
Posted: Wed Dec 07, 2022 2:13 pm Post subject: Re: Alternator light |
Its also worth checking the alternator brushes are not worn down, and the brushes can move freely in the brush holders. _________________ Ancient vehicles and vessels
SGKent Samba Member
Posted: Wed Dec 07, 2022 4:06 pm Post subject: Re: Alternator light |
Some electronic parts can be defective but only show up as temperature sensitive. Go thru the alternator and VR checks as in Bentley or what Telford wrote below when it is not working to confirm the defect.
telford dorr wrote: |
Back to the original problem: likely something wrong with the alternator or regulator.
Test:
- disconnect the regulator.
- connect Df (green wire) to D+ (red and blue wires) at the regulator socket with a jumper wire (6" #18 wire with a male spade terminal on either end).
- connect a voltmeter across the battery.
- start engine (DO NOT REV) and monitor battery voltage. It should increase with engine speed. If so, then regulator is bad. Otherwise, bad alternator (diodes or brushes).
NOTE: DO NOT ALLOW battery voltage to exceed 14.4 volts! In this test, we're running the alternator wide open, regulated only by engine speed. Use caution. |
_________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Willin Samba Member
Posted: Wed Dec 07, 2022 4:34 pm Post subject: Re: Alternator light |
I will certainly check the belt.
I have done those tests before, I will try them again. Or take it the three blocks to laps to have them test. They found that my first vr was bad, and the one they sold me went bad. Maybe now the third one is bad.
I will keep an eye on things. No heat out in the big sky garage, so will have to wait for a warm day. And I don't drive it as much in winter.
Thanks again. |
Starbucket Samba Member
Posted: Wed Dec 07, 2022 5:02 pm Post subject: Re: Alternator light |
Is the trans to body ground strap clean and shinney? that's how the volts get back to the battery from a rubber mounted assembly. |
Willin Samba Member
Posted: Thu Dec 08, 2022 3:58 pm Post subject: Re: Alternator light |
There was some solar gain out there today, so I did the Telford tests.
Seems my alt. is not working.
This unit has only @4000 miles on it. PO put it in, says "rebuilt" on it, it's a Bosch. Its , maybe, 5 to 10 years old.
What happens to these? Hope this isn't the life of the rebuilds these days.
I'll need to wait for the new year for time to dig in this deeper.
Thanks! |
SGKent Samba Member
Posted: Thu Dec 08, 2022 4:24 pm Post subject: Re: Alternator light |
Willin wrote: |
Thanks! |
depends how it died and what failed. I do assume that the dash light is an original and not a led or something like that. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
timvw7476 Samba Member
Posted: Thu Dec 08, 2022 5:18 pm Post subject: Re: Alternator light |
You don't mention if your VR is the classic Bosch contact points type or a modern solid state unit. There are decent VRs in the classifieds here. Those are the ones that work, and well. (not solid-state)
Also double check the plug into the VR itself, the issue(s) I've had amount to that harness, or one of it's wires failing to seat or work loose, & the Too Long Stud Syndrome you find on rebuilt alternators when replacing one. |
Willin Samba Member
Posted: Fri Dec 09, 2022 8:17 am Post subject: Re: Alternator light |
What I meant to ask was,
If the diodes went bad, what causes them to fail?
If it's the brushes, what causes them to fail? (Thinking out loud)
Alternator is not that old, I have gone through all wiring. Unit has worked fine for the 5 years I've had bus.
VR is solid state type from O'reillys. I had one of them fail (dash light staying on), so I did the Telford Test. It showed the Alt. was bad. Went to O'reillys, and their test machine showed the VR was bad. The store replaced it with the same style.All good to go till now. That was this past summer. Easy enough for me to have them test again , before taking thing too much apart.
This could be a repeat of that scenario. Hoping for easier solution than replacing alt.
Thanks all for your time! I have received lots of good info here getting this bus back on the road!
Jim |
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3555 Location: San Diego (Encinitas)
Posted: Fri Dec 09, 2022 9:32 am Post subject: Re: Alternator light |
Willin wrote: |
If the diodes went bad, what causes them to fail? |
Main diodes: reversing the battery connections, even for an instant, will kill them. After that, lack of cooling air (damaged / missing air boot on type 4 engines).
Diode trio: these diodes can only handle around 3 amps, so any overload on the blue regulator wire will smoke them. On later bays, many things connect to this wire (indicator light, brake warning light, heater blower relay, etc.)
Quote: |
If it's the brushes, what causes them to fail? |
Mechanical wear, generally, although it takes a lot of miles to do so. They should have been replaced on any good rebuild... _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
Willin Samba Member
Posted: Fri Dec 09, 2022 6:20 pm Post subject: Re: Alternator light |
Thank you Sir! Sirs!
Have not disconnected the battery in months, and I have made sure the cooling boot is intact.
How about this? Like I mentioned at first the alt light would glow till I increased the revs. Warm weather, light goes(went) out right away. Cold temps, have to rev a little more. Would turning on the booster fan when the light was on mess the diodes up? |
Posted: Fri Dec 09, 2022 8:30 pm Post subject: Re: Alternator light |
Willin wrote: |
Bosch rebuilds are known to be hit or miss. They may reuse diodes, near as I can figure. Also, the diodes are crystal structure & prone to failure (shattering)via shock. Which I do believe a little or a lot of tapping is done when reassembling a refurb alternator like these. They also smoke a diode if the battery, either cable, gets disconnected from the battery for who knows how many minutes while running. |
Posted: Fri Dec 09, 2022 9:28 pm Post subject: Re: Alternator light |
Willin wrote: |
No, but it would likely take a higher engine speed to fire up the alternator, as the fan relay sucks up some of the startup current from the ALT indicator light. _________________ '71 panel, now with FI
Willin Samba Member
Posted: Sun Dec 11, 2022 11:05 am Post subject: Re: Alternator light |
It was warm today so I pulled the Alt.
Checked wiring to starter and to vr. All good.
I have the old alt the po gave me. The Haynes manual says the diodes must flow in only one direction. Check with test light at no more than 24 volts. It also mentions un-soldering the diodes first. I did not. I used my 20v drill battery test light.
Tested old alt. first, flow in both directions.
"new" alt same , both directions.
Obvious question is what happened?
I went ahead and bought the only alternator I could find. "Quality Reproduction " from Cip1, and they only had one.
Is there some place folks send cores in for rebuild these days?
Or are the diodes available, and straight forward to replace? |
Posted: Sun Dec 11, 2022 11:19 am Post subject: Re: Alternator light |
I would hope that a town as big as Bozeman would have a mom and pop automotive electric shop.
I believe that the diodes are going to be common enough as they are likely the same as found in other Bosch alternator of the era. In the past I have scrounged wrecking yards for alternators (not necessarily Bosch ones) that I could take diodes and other parts from, |
Posted: Sun Dec 11, 2022 11:26 am Post subject: Re: Alternator light |
Diodes are available, but hard to find. You'll need a good medium sized soldering iron, 60/40 rosin core solder, and a solder sucker to disassemble them from the diode trio board. Work carefully, as things in there are somewhat fragile. Always unsolder the diode wire from the diode trio board, not the wire from the diode. NEVER put any force on the solid wire coming out of a diode - they cannot take a joke! If you need to bend this wire, use two pairs of pliers! Also, a cheap arbor press is handy to remove and install the diodes from the heatsink plate and alternator case.
Diode trio board above negative diodes:
Positive diodes, showing new diode installed:
Positive diodes:
A test stand is handy to test the finished alternator before reinstallation!
Type 4 alternator:
Type 1/2 alternator:
Willin Samba Member
Posted: Sun Dec 11, 2022 12:21 pm Post subject: Re: Alternator light |
I will check locally, there is one shop, maybe.
I would like to have a spare around.
In the pic of the t-4 stand, looks like you were building a bike wheel? Spokes?
Thanks all for your replys !
Jim |
Willin Samba Member
Posted: Sun Dec 11, 2022 6:42 pm Post subject: Re: Alternator light |
One more questions, Please.
I looked at my wiring. Big red wire says 10g/ 5.25mm. That is smaller than the 6(mm) , listed on the wiring diagram.
Bigger wire be better? What size? |
