72 classic type I Samba Member
Joined: October 04, 2022 Posts: 3 Location: highland lakes,n.j.
Posted: Mon Dec 05, 2022 9:22 am Post subject: new pistons on a1300 type1 andheads, is it doable? |
i will have to look up the numbers on the 2 blocks that i have to see what size they are, here is my question will i be able to swap out the pistons and along with the heads? |
Zundfolge1432 Samba Member
Posted: Mon Dec 05, 2022 9:58 am Post subject: Re: new pistons on a1300 type1 andheads, is it doable? |
Those numbers will tell you what size it was when Nixon was President, may have been cut already but even in stock form 1600 85.5 pistons will fit those holes. 1300 heads need cut to fit the bigger cylinder. |
FritzCP Samba Member
Joined: October 23, 2005 Posts: 463 Location: Wisconsin
Posted: Thu Dec 08, 2022 4:38 pm Post subject: Re: new pistons on a1300 type1 andheads, is it doable? |
also the combustion chamber is smaller in the 1300 heads, and using them with 85.5 cylinders makes something like 9:1 comp ratio so beware of that. _________________ Fritz Custom Products
Fritz 10 - Tin Screw Torquer
Fritz 124 - Crank Pulley Puller
Fritz 70 - 6306 Bearing Puller
Fritz 44 - Dizzy Puller |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34003 Location: Conejo Valley, CA
Posted: Thu Dec 08, 2022 10:32 pm Post subject: Re: new pistons on a1300 type1 andheads, is it doable? |
FritzCP wrote: |
also the combustion chamber is smaller in the 1300 heads, and using them with 85.5 cylinders makes something like 9:1 comp ratio so beware of that. |
That will take shims to correct, or at least improve. |
