Engine Mountability
Forum Index -> Water-cooled VW Share: Facebook Twitter
81VrRabbit
81VrRabbit is offline
PostPosted: Fri Dec 09, 2022 1:06 am    Post subject: Engine Mountability Reply with quote
With little to no information on 1998-2010 motor mounts
I'm here to see what i can figure out.
Ive been told that the engine mounting brackets are the same on all bodys
mk3 mk4 mk5 meaning the VR6 1.8 1.9L and 2.0T are the same brackets
Correct me if i am wrong.
Just looking for some insight based on a swap option..
Thanks in Advance.
TDCTDI
Samba Advocatus Diaboli
TDCTDI is offline
PostPosted: Fri Dec 09, 2022 5:00 am    Post subject: Re: Engine Mountability Reply with quote
MkIII are completely different.
81VrRabbit
PostPosted: Fri Dec 09, 2022 7:53 pm    Post subject: Re: Engine Mountability Reply with quote
So with out modifications a Obd2 2.8 vr6 or a 2003.5 TDI wouldnt fix.
TDCTDI
TDCTDI is offline
PostPosted: Fri Dec 09, 2022 9:02 pm    Post subject: Re: Engine Mountability Reply with quote
Modifications to the car or engine aren’t necessary if you make your own mounts, or you can purchase them premade. Here’s one example…
https://www.fablessmanufacturing.com/products/vr6-...ag_organic
81VrRabbit
PostPosted: Sat Dec 10, 2022 1:44 pm    Post subject: Re: Engine Mountability Reply with quote
very cool thank you for your time.
volkybus
volkybus is offline
PostPosted: Tue Apr 18, 2023 9:48 am    Post subject: Re: Engine Mountability Reply with quote
Even on the mk3 one of the Cabrio mounts is different than the reg golf or jetta So who knows but if there's a will, there's a way.....Bill ....PR& VT
flyinglow94
flyinglow94 is offline
PostPosted: Fri Jul 28, 2023 4:37 pm    Post subject: Re: Engine Mountability Reply with quote
What is the application? Mk1 mounts are spacific. you would need to custom make mounts or buy some from a company. Mk2 or 3s, you can use the mk3s k member and moter and trans mounts to fit a VR (2.8, 3.2 or 3.6) or 1.8t onto a mk2 or 3. Mk4 and newer VRs hang on the frame rails but have bolt provisions for the mk3 motor and trans mount ( if your usong tbe 02J trans). If you are putting a mk4 02M in a mk2 or 3 a custom bracket is needed and available for mount trans ( you also need to cut the K members mount for the 02M trans and move it back 15-25mm)
Hope this helps.
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger Gallery Classifieds Feedback
Reply to topic    Forum Index -> Water-cooled VW All times are Mountain Standard Time/Pacific Daylight Savings Time
