Which is best to use with spacers lug bolts or studs and nuts?
Forum Index -> Custom Wheel/Tire Share: Facebook Twitter
tristanblue
tristanblue is offline
PostPosted: Tue Nov 29, 2022 6:53 pm    Post subject: Which is best to use with spacers lug bolts or studs and nuts? Reply with quote
Installing some aftermarket 911 style wide fives on a beetle. The rear wheels need 1/4 spacers to keep from rubbing. Will using spacers require I use lug bolts or studs with nuts or will both work.
Thanks
T
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Tue Nov 29, 2022 7:04 pm    Post subject: Re: Which is best to use with spacers lug bolts or studs and nuts? Reply with quote
Studs make.it easier to mount the tire but either will do the job
Glenn
Member #1009
#BlueSquare
hitest
hitest is offline
PostPosted: Wed Dec 07, 2022 2:27 pm    Post subject: Re: Which is best to use with spacers lug bolts or studs and nuts? Reply with quote
Does your car have a disc conversion up front? It looks the part on my monitor. The reason I ask is if so, maybe spacers to bring the rears out a little to match.
FU#5
Mike Fisher
Mike Fisher is offline
PostPosted: Sun Dec 11, 2022 12:53 pm    Post subject: Re: Which is best to use with spacers lug bolts or studs and nuts? Reply with quote
I bought longer Mercedes style lug bolts for my Fuchs wheels from www.ezaccessory.com
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
esde
esde is offline
PostPosted: Sun Dec 11, 2022 1:21 pm    Post subject: Re: Which is best to use with spacers lug bolts or studs and nuts? Reply with quote
When using spacers, I like to drill and tap two holes, so I can use a flat head machine screw to mount them to the drum. Just makes life easier down the road.
modok wrote:
Reply to topic    Forum Index -> Custom Wheel/Tire All times are Mountain Standard Time/Pacific Daylight Savings Time
