NAES Samba Member
Joined: September 10, 2003 Posts: 2120 Location: AREA-52 Southern Killafornia
Posted: Fri Dec 09, 2022 10:36 pm Post subject: Clutch cable coming up short. 57 with 12v trans |
My buddy brought over his 57 with a busted clutch cable. We threw in a stock replacement which ended up being about 1/2" short.
57 Bus. Lollipop mount. Early 12v center section w/o the t/o bearing sleeve.
Pulled the cable and it appears to be the correct 3116mm measured from the center of the clevis pin to the end of the cable. We also installed a new bowden tube that is the same length and put 3 thick washers on it as is customary. We flipped the clutch pedal piece to try and eek out a few more threads. No dice. Removed the washers on the bowden tube and tried again. We were able to get the threads started and got about 5 threads secured. Fired up the bus and it was clear the cable is still too tight. We were able to get it in gear and drive but the t/o bearing rubbing the p/p.
We ended up pushing the clutch pedal in and vice gripping it down for the night in hopes of it stretching. I've never had this much of a problem so I'm stumped. Any ideas?
NAES _________________ Barndoor Mafia
Box On Wheels
SBS #00 |
Who.Me? Samba Member
Joined: July 14, 2014 Posts: 2210 Location: UK (South)
Posted: Sat Dec 10, 2022 5:52 am Post subject: Re: Clutch cable coming up short. 57 with 12v trans |
NAES wrote: |
Pulled the cable and it appears to be the correct 3116mm measured from the center of the clevis pin to the end of the cable. |
That is the correct cable. I did mine a couple of months ago (October '56 truck with a '67 transmisssion and the lollipop mount).
It is very tight at first. I was surprised at how few threads it needed on the adjuster. The old cable must have stretched a lot in the years prior to it finally breaking...
https://www.thesamba.com/vw/forum/viewtopic.php?p=9934852&highlight=#9934852 _________________ Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786 |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Sat Dec 10, 2022 7:50 am Post subject: Re: Clutch cable coming up short. 57 with 12v trans |
NAES wrote: |
We flipped the clutch pedal piece to try and eek out a few more threads. |
the way it should be....
_________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
Touch Nicks Thing Samba Member
Joined: May 21, 2003 Posts: 2029 Location: Alexandria, VA
Posted: Sun Dec 11, 2022 5:35 am Post subject: Re: Clutch cable coming up short. 57 with 12v trans |
Best drawing ever! |
Posted: Sun Dec 11, 2022 7:13 am Post subject: Re: Clutch cable coming up short. 57 with 12v trans |
If the lever at the pedal end is the right way round. I wonder if the issue might be the clutch release arm?
Not sure if yours has the the bent arm, or if that might affect the cable fit?
The 3116mm cable works fine with the straight arm (that's what I have on my gearbox).
This thread shows the different arms https://www.thesamba.com/vw/forum/viewtopic.php?t=689546 _________________ Andy
NAES Samba Member
Posted: Sun Dec 11, 2022 11:55 am Post subject: Re: Clutch cable coming up short. 57 with 12v trans |
OK Hazet you definitely win the internet today!
I'm not sure what else to do other than leave it and let the cable stretch.
Thanks for the links who.me?
Box On Wheels
SBS #00 |
Pepperbilly Samba Member
Joined: April 08, 2017 Posts: 977 Location: Seattle, Wa
Posted: Sun Dec 11, 2022 12:33 pm Post subject: Re: Clutch cable coming up short. 57 with 12v trans |
Oh, I love the drawings! Genius stuff…
Bill |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3442 Location: San Diego
Posted: Sun Dec 11, 2022 2:11 pm Post subject: Re: Clutch cable coming up short. 57 with 12v trans |
Some of the aftermarket throw out shafts have the splines clocked wrong, making the arm in the wrong position |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14266 Location: Casa de Oro, California
Posted: Sun Dec 11, 2022 7:09 pm Post subject: Re: Clutch cable coming up short. 57 with 12v trans |
NAES wrote: |
We also installed a new bowden tube that is the same length and put 3 thick washers on it as is customary. |
Where is the washer number from? |
NAES Samba Member
Posted: Mon Dec 12, 2022 12:51 am Post subject: Re: Clutch cable coming up short. 57 with 12v trans |
Something I picked up years ago and have used ever since. Most in my circle do the same. _________________ Barndoor Mafia
Box On Wheels
SBS #00 |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22665 Location: NYC/Upstate/ROW
Posted: Mon Dec 12, 2022 7:40 am Post subject: Re: Clutch cable coming up short. 57 with 12v trans |
The washer number is chosen By the spec ofBowden cable sag, not just a fixed number. If you take some out, you can run it for a bit to stretch the cable. The sag removed clutch chatter by adding some friction to the cable, but you can eliminate said chatter with good clutch technique until the cable stretches _________________ .ssS! |
NAES Samba Member
Posted: Mon Dec 12, 2022 1:20 pm Post subject: Re: Clutch cable coming up short. 57 with 12v trans |
Just doinng wjat has worked for me in the past.
Right now there are no washers on the bowden tube and its still short. It'll get sorted soon enough _________________ Barndoor Mafia
Box On Wheels
SBS #00 |
