dborell Samba Member
Posted: Mon Dec 26, 2022 2:04 pm Post subject: Passenger side window not rolling down |
My 03 Eurovan passenger side window won't roll down. Doesn't work from the drivers or passenger door switch...must be the regulator motor? |
02Berry Samba Member
Posted: Tue Dec 27, 2022 12:59 pm Post subject: Re: Passenger side window not rolling down |
Can be any of a number of causes. Here's a conversation about it from earlier:
https://www.thesamba.com/vw/forum/viewtopic.php?t=615403 _________________ Learned to drive in a '67 Splitty.
New to '02 T4 EVW world.
Third generation camper family. |
Posted: Wed Dec 28, 2022 8:17 am Post subject: Re: Passenger side window not rolling down |
For a couple months the window would roll only half way down...then suddenly it operated normally again ....now it doesn't roll down at all. I do hear a slight noise/click in the door when the switch is pushed.
Thanks for the conversation link...I'll check it out. |
Posted: Tue Jan 10, 2023 12:36 pm Post subject: Re: Passenger side window not rolling down |
Now it's the window is working normally again! No need to fix...it fixed itself! |
gesoffen Samba Member
Joined: August 22, 2009 Posts: 139 Location: NoVA, USA
Posted: Tue Jan 10, 2023 4:32 pm Post subject: Re: Passenger side window not rolling down |
Good chance the wiring harness in your door(s) is failing. The flexing of the wiring harness when the door is opened/closed combined with the brittle insulation (due to age) frequently results in failures of electrical components and other odd behaviors.
You can repair the harness or replace. If you elect to repair, I strongly suggest you patch in replacement wires to match the existing color codes and move the joints away from the area where the harness flexes. Unless your frequently use your passenger front door, I'd suspect the drivers door and start your investigation there. |
50Splitman Samba Member
Posted: Tue Jan 17, 2023 7:55 pm Post subject: Re: Passenger side window not rolling down |
I have this same issue every few months in my 02 Weekender. All the wiring looks good, and there are no obstructions or binding in the channel or the window regulator. What works to fix it every time is taking the door panel off, unplugging and then plugging back in the window motor. Have no idea why this fixes it. The connector looks clean, not cracked, no corrosion. It's like it "resets" the motor and everything is fine again. |
TheOneTrueQuux Samba Member
Posted: Wed Jan 18, 2023 8:12 am Post subject: Re: Passenger side window not rolling down |
50Splitman wrote: |
Next time, just try tapping the motor gently. Most likely it's the vibration and torquing of the unplug and re-plug process that's fixing it and the actual problem is worn out or sticky brushes in the motor.
You might be able to just beat on the inside door panel by the motor with your hand and get it going.
If that "fixes" it, then a new motor is the permanent fix. |
