THINGONER Samba Member
Joined: April 13, 2008 Posts: 674 Location: riverside ca
Posted: Sun Jun 22, 2008 3:42 pm Post subject: trailing arm washers |
I am presenly replacing my torsion arm bushings. Can someone tell me if a large flat washer is supposed to go on both sides of bushings or just the inside? Any help would be greatly appreciated. thanks. |
kubelmann Samba Member
Posted: Sun Jun 22, 2008 3:52 pm Post subject: |
Are you using stock or urethane parts? I suggest Urethane |
Posted: Sun Jun 22, 2008 4:05 pm Post subject: |
yes |
Posted: Sun Jun 22, 2008 4:06 pm Post subject: |
with a washer on each side of the bushings the bolt head does not go in all the way |
Posted: Sun Jun 22, 2008 4:50 pm Post subject: |
With stock bushings you will have jounce, bounce and undesired looseness. K-mann |
tmitoraj Samba Member
Posted: Sun Jun 22, 2008 5:17 pm Post subject: Torsion arm bushings |
I just replaced my torsion arm bushings and do not recall a washer. If you are thinking of the control arm there are two large flat washers. I used the urethane both for the torsion arm and contol arm bushings and had no trouble. The large bolt for the control arm needs to be lined up before it will go in and that took alittle work. Otherwise no problems. |
Posted: Sun Jun 22, 2008 10:27 pm Post subject: |
I found the problem, I had 2 washers stuck to the inside mounting point of trailing arm bracket. I guess the good news is that I finally found that elusive washer-the bad news? I have to install the trailing arm for the 3rd time. Thanks for the help, and yes I am installing the urethane bushings. |
Lance1970 Samba Member
Joined: July 17, 2007 Posts: 54 Location: Minden Nevada
Posted: Mon Jun 23, 2008 1:32 pm Post subject: |
Hello All-
All the books that I have warn to place both washers on the outside (by the bolt head) and I have followed that direction for some 35 years.
-John _________________ 1977 Thing (Latin America Safari)
1970 Std Resto
'74-based 2L Cobra Jet buggy
If you don't know what you are doing, please don't do it at my place without asking for help! |
waxhead Samba Member
Joined: January 19, 2004 Posts: 946 Location: Philly 'burbs
Posted: Wed Aug 06, 2014 11:16 am Post subject: |
I am about to put my trailing arms back on and wanted to remind others that the two washers go on the outboard side. I had wrongfully assumed that one washer went on each side. _________________ Mike B. |
Iguana Samba Member
Posted: Wed Aug 06, 2014 12:07 pm Post subject: |
waxhead wrote: |
I am about to put my trailing arms back on and wanted to remind others that the two washers go on the outboard side. I had wrongfully assumed that one washer went on each side. |
Firstly you weren't wrong and you can put a washer on either side.
I think in the case of washers and pivot box's it is important to understand what they do and what they are their for.
You must have one on the outside ( Bolt Head Side) as that is what holds the pivot bushing in place. If you don't have one there then the pivot bolt shoulder will push past the outer bushing and onto the inner sleeve. When it gets done up tight the bushing can then float out of the arm. If this happens then the arms can move around, the bushing gets flogged and pivot bolts come loose.
From Factory both washers go on the outside according to most manuals and pictures. In reality the purpose of the 2nd washer is to allow adjustment and it can be placed on either side to change tow in and tow out. You can run up to 3 washers ( one more than factory) on a pivot box and still be in factory spec.
The only rules to remember
1 - You must have at least one washer on the outside
2 - You must have at least 2 washers but no more than 3
3 - ALWAYS tab punch the outside of the pivot box onto the bolt head grooves to stop it coming loose.
This applies to ALL Type 1 and Type 3 IRS Trailing arms. If anyone tells you different get them to explain why they feel that way . |
Posted: Thu Aug 07, 2014 10:41 am Post subject: |
Thanks for the info Iguana - good to know! _________________ Mike B. |
jehlan Samba Member
Posted: Sat Jan 21, 2023 6:55 am Post subject: Re: trailing arm washers |
WASHER QUESTIONS STILL!!!
ALright everything I read says 2 washers on outside of trailing arms. Got it!
BUT since the nut on the frame for the trailing arm bolt sticks out from the frame when I install this way and tighten the bolt it squishes the outer rubber bushing but not the inner, and at the inner there is a space (because the metal sleeve inside the bushing hits the protruding nut).
Really looks like you need 2 inner washers (they fit there perfectly!) AND at least one (but logically 2 for strength) outer washer |
jehlan Samba Member
Posted: Sat Jan 21, 2023 7:11 am Post subject: Re: trailing arm washers |
I can put the chisel in the opening on the inner bushing! If I put 2 more washes here then the space fills up. The washers fit over the protruding nut welded on the frame |
Joined: February 21, 2003 Posts: 868 Location: Clifton Park NY Saratoga County
Posted: Wed Feb 01, 2023 11:28 pm Post subject: Re: trailing arm washers |
Put on outside _________________ Michael Basso
http://www.thingparts.com
New and Used VW Thing Parts Free advice
CALL 518 630 0173 |
